$#ITI start to my lonf holiday weekend.
Old Aug 30, 2008 | 12:36 AM
djcharlee's Avatar
Unhappy $#ITI start to my lonf holiday weekend.
So I was on my way home from work. I got the 8 washed and took it home and finished with some spray detailer to get the water spots. Installed my pillar overlays and was done.
The weekend is here so let me fill her up. I was on E already and was on my way to the gas station, 1 block away BAM!! Car died...
Outta GAs,, more that likely, so I tried to start twice, no luck.
A few off duty Marines push my car 1.5 blocks up a small incline into the gas station.
I filled up, premium of course. I tried to start, no luck!!!
So I read on the forum that If possibly flooded, find a hill and just clutch start it....
I proceeded down a small hill, put it in 2nd and bam it started up. This was in no way an abrupt bog and start. Just a smooth start.
I get to the bottom of the hill and I hear the engine chatter. Best way do describe it is like loose metal in a metal box. it is present during acceleration and deceleration.
Well I was 2 exits from a dealer so I dropped it off there till Tuesday when all the techs get back.
Any Ideas?
I am so upset, I've only had the car for 2 weeks and I was on top of the oil too.
Old Aug 30, 2008 | 09:37 AM
VOODOO8's Avatar
Hermitage Holdout
Could be a flood, may want to try a search for "marbles in a can" sound, blown engine, etc. too. No compression = no start.
Old Aug 30, 2008 | 09:52 AM
alnielsen's Avatar
I would say a bad engine. The noise you are hearing is a seal bouncing around inside. It's an 04 so it could be outside of it's original warrenty. The engine is warrentied for 8/80 so it should be replaced under that.
Old Aug 30, 2008 | 09:55 AM
Krazed_Rx8's Avatar
If it is the engine, you'll love the new extended warranty for it
Old Aug 30, 2008 | 09:56 AM
HeavyMetal699's Avatar
I would be mad too if that happened to me. Does sound like a bad engine.
Old Aug 30, 2008 | 12:12 PM
djcharlee's Avatar
Before I got the car, I did some research so I knew I was rolling the dice. I just hope that this is not replacement engine already. Or does that matter.?
Well I will know on Tuesday. 29k wow.
Old Aug 30, 2008 | 04:58 PM
Socket7's Avatar
ಠ_ಠ
If it's a bad engine, you're covered under the 100K mile warranty for the core.
Could also be time for coils wires and plugs i suppose.
Old Sep 2, 2008 | 08:32 PM
djcharlee's Avatar
Well its not a bad engine, the tech said it is the clutch or flywheel.
I am very tempted to pick it up and have my buddies install a new EXEDY CLutch and Fidanza flywheel.
The dealer says I am looking at around $1200 with new clutch and resurfacing of flywheel.
What do you guys think?
I am just worried I will get the car and its something else.
Charlee
Old Sep 2, 2008 | 09:07 PM
VOODOO8's Avatar
Hermitage Holdout
Could be if the car initally died due to lack of gas and the rest is tied to the tranny. Should know as soon as someone cracks it open if this is really the problem.
Old Sep 2, 2008 | 10:37 PM
05rex8's Avatar
sold the 8... :(
Charlee
don't let the dealer do this....it's way overpriced
time for lightweight flywheel upgrade!
Old Sep 3, 2008 | 11:27 PM
djcharlee's Avatar
Well i had the dealer do it and I am getting the car tomorrow, <-minus the Ky
At least I got my car back!! And thats what is important. Even though my **** hurts!!
Old Sep 4, 2008 | 03:04 PM
djcharlee's Avatar
Well went to pick up car and guess what?
The engine is making noise... so I got a loner and possibly a new engine.
Carlos
Old Sep 5, 2008 | 01:18 AM
hakuna matata!
and... you paid $1,200 for something that wasn't the problem..?
Old Sep 5, 2008 | 07:28 AM
djcharlee's Avatar
Yup, seems I need a new engine. but I am getting reimbursed for clutch job and no pay for warranty work. + got my loaner.
Old Sep 5, 2008 | 10:10 AM
Shoafb's Avatar
Cool, their lack of trouble shooting got you a free clutch!
New clutch and engine.... your set.
Old Sep 6, 2008 | 03:04 AM
djcharlee's Avatar
For Real, all they had to do was
the transmission and it would have been a new drive train.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
wanted797
Aug 26, 2015 11:24 PM
harithac
Aug 26, 2015 09:24 AM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
poppinparker
Aug 10, 2015 09:20 AM
