Spring Rates
Old Jun 11, 2008 | 06:44 PM
whoneedspistons's Avatar
Spring Rates
I am curious what you guys are using for spring rates on the track.... I am trying to keep a semi comfortable (not that important) daily driving but not sacrafice performance. I am looking for what you guys are running not what I could run. Thanks
Old Jun 11, 2008 | 07:24 PM
for street tire (140+ treadwear) performance I'd recommend not exceeding 450 lb/in front and 250 - 275 lb/in rear
higher rates will run reasonably smooth on the street if the shock valving is not set very aggressive, but will overwhelm regular street tires when pushed hard
Old Jun 12, 2008 | 11:39 AM
chiketkd's Avatar
Row faster, I hear banjos
In a later thread, AlexCisneros opened up his compilation to revisions/input from other members. Those revised spring rates are listed below:
Originally Posted by AlexCisneros
I had posted these in another thread and thought it may be useful to everyone. In this manner I can edit when new information is made available and keep it up front.
All have been converted to lb/in.
Stock RX8 6spd
F 155.61 lb/in
R 112.86 lb/in
Stock RX8 Automatic
F 144.21 lb/in
R 101.46 lb/in
Mazdaspeed Spring
F 280 lb/in
R 190.4 lb/in
Tein high tech
F 184.8 lb/in
R 134.4 lb/in
Tein S Tech
F 207 lb/in
R 145 lb/in
RS*R
F 181.44 lb/in
R 122.08 lb/in
Tanabe Sustec NF210 (Normal Feel)
F 162.4 lb/in
R 112 lb/in
Tanabe Sustec GF210
F 179.2 lb/in
R 145.6 lb/in
Auto Exe
F 212.8 lb/in
R 145.6 lb/in
Espelir
F 212.8 lb/in
R 151.2 lb/in
Racing Beat
F 187 lb/in (calculated 20% Stiffer than Stock)
R 136 lb/in (calculated 20% Stiffer than Stock)
H&R
F 194~203 lb/in (calculated 25%~30% Stiffer than Stock)
R 141~146 lb/in (calculated 25%~30% Stiffer than Stock)
Eibach
F 180-187 lb/in (calculated progressive rate 15%~20% Stiffer than Stock)
R 130-136 lb/in (calculated progressive rate 15%~20% Stiffer than Stock)
--coilover--
Tein CS
F 280 lb/in
R 168 lb/in
Tein Flex
F 504 lb/in
R 392 lb/in
Tein Basic
F 448 lb/in
R 336 lb/in
HKS Hipermax II
F 448 lb/in
R 280 lb/in
JIC FLTA2S
F 448 lb/in
R 280 lb/in
JIC FLTA2H
F 560 lb/in
R 392 lb/in
Speedsource Grand Am Cup Cars changes from track to track but was
F 800 lb/in
R ??
at one point according to one of the drivers.
Link to thread: https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/spring-rates-33424/
Old Jun 12, 2008 | 03:18 PM
awesome thanks...
can anyone give me a little feed back on the spring rates that they are using.. there pros and cons
Old Jun 12, 2008 | 03:50 PM
Originally Posted by chiketkd
This post has lots of good info on Spring Rates (stock & aftermarket). Could be very useful when deciding what to purchase:
Link to thread: https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/stock-spring-rates-32731/
Some of those have since proven to not be valid, I don't think you have any direct experience on this topic so as always consider the source ...
Old Jun 12, 2008 | 05:12 PM
chiketkd's Avatar
Wasn't claiming to be knowledgeable on this subject. Just trying to help the OP out when he goes shopping for springs/coilovers that match your recommendation. What rates are incorrect? Can you update/revise the list?
Old Jun 12, 2008 | 09:10 PM
chiketkd's Avatar
I've updated post #3 with a later post with revised spring rates based on input provided by other RX8club members. I don't know the validity of these spring rates, but if any numbers are off, hopefully, the correct spring rates can be posted so that this info can be useful to others in the future.
Old Jun 13, 2008 | 02:56 AM
the person that is doing really really well on track days. in tt and ta..
is running racing beat springs and sways.. might just be the front sway.. and bilstein shocks.. hd. a ride in that car is amazing.
the other two hpde 3/4 guys are running tein basics..
Old Jun 13, 2008 | 09:19 PM
thanks swoope... it looks like we are going to have to be meeting up here shortly at some track events...
Old Jun 13, 2008 | 09:33 PM
i saw one of your center pods on wed..
you going to the dyno tomorrow?
Old Jun 19, 2008 | 12:05 AM
SouthFL's Avatar
I'm using mushy Tein H-Techs with Koni SA dampers.
Old Jun 19, 2008 | 12:20 AM
and i bet you are doing just fine!!!!
sways yet?
Old Jun 19, 2008 | 12:26 AM
SouthFL's Avatar
No sways yet. Maybe next year. Driver is the most important mod. Still working on that one.
Old Jun 19, 2008 | 06:40 PM
the only thing I would recommend other than a true motorsport coilover setup is the KW Variant3 coilover kit
455# front
280# rear
https://www.rx8club.com/group-buy-center-85/gb-kw-variant-3-coilover-suspension-110818/
IMO all that other stuff is a pig's ears blinged up to look like a neon purse
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
