View Full Version : DIY: Spark Plug Change.
xsnipersgox
05-04-2008, 12:28 AM
I've decided to get all the important data together on 1 post, so people don't have to hunt all around for information.
Tools Needed:
Brain
Glove/Eye protection
Jack Stand
Jack
Magnetic Spark Plug Socket - 13/16 inch or the metric equivalent.
Ratchet + Extensions
You need 3 long extensions.
One of the extensions need to be a wobble. Similar to swivel, but it's a wobble. - expo1
Anti-seize(i have no idea about copper or aluminum anti-seize, i looked around and there is no big deal, just use copper if that's available)
2 Leading Spark Plugs - RE7CL
2 Trailing Spark Plugs - RE9BT
could try www.sparkplugs.com
Spark Plug Torque Specification:
114-156 in-lbf
http://www.rx8club.com/attachment.php?attachmentid=74269&d=1144614389
Thanks to TeamRX8
Spark Plug Gap Specification
Standard : 1.15mm-1.25mm (0.046-0.049in)
Maximum: Leading 1.5mm (0.059in) Trailing 1.4mm (0.055in)
Thanks to Go48
[B]Instructions:
*write down your radio preset*
*Remove the driver's side wheel before starting*
*Disconnect the Negative Terminal on your battery*
#1 - Jack the car using a good hydraulic jack, placing a piece of wood between the jack and your frame rail. This will prevent you from denting the underside of your car. ALWAYS PLACE A JACK STAND UNDER THE CAR. THIS COULD SAVE YOUR LIFE!
http://img.photobucket.com/albums/v129/xsnipersgox/rx8009.jpg
# 2 - From underneath the car, you have a clear reach at the rear plugs. I recommend breaking them loose with the wrench, but then removing them by hand. Not only do you avoid banging your knuckles on everything, but it goes faster.
http://img.photobucket.com/albums/v129/xsnipersgox/rx8011.jpg
#3 For the front rotor, the plugs are tough to reach. Next time, I will remove the driver's side wheel, but since I didn't have my lug key with me, I still reached them by turning the wheels all the way to the right. Behind the wheel, remove the upper fastener on the rubber splash "thingy". (Oooohh....Technical terms! :D ) This is NOT a screw, but one of those that only requires a quarter turn to release it, similar to the clips on your wheel well liner. Once it pops out, gently pop out the washer by sliding a flat head screwdriver under it and twisting gently. Did I say gently? Seriously people, these things beak easy.
If you've got skinny arms, you CAN use this method, but as I said: Take the wheel off.
http://img.photobucket.com/albums/v129/xsnipersgox/rx8014.jpg
The front plugs are now visible.
http://img.photobucket.com/albums/v129/xsnipersgox/rx8012.jpg
#4 When reinstalling the plugs, be sure to apply a light coat of anti-seize to the threads.
#5 Each plug is marked with a T or an L, which indicates leading or trailing. It is VERY important they are reinstalled correctly. Double check this, and note the T and L cast into the side of the motor beside each hole. Match these up. Image for Which Wire/Coil goes to which plug here: http://img.photobucket.com/albums/v129/xsnipersgox/coil.gif
Also, you did notice that the trailing plug wires are marked with green and blue tape, right? If not, make sure upon reinstallation that you attach them correctly.
http://img.photobucket.com/albums/v129/xsnipersgox/rx8013.jpg
Original Thread: http://www.rx8club.com/showthread.php?t=31872
Thanks to : Tony Orlando
*reattach the negative terminal of the battery*
*start the car (warm it up)*
*to reset the DSC, turn wheel all the way left, than all the way right, shut down the engine*
DONE
Please Let me know if anything is inaccurate/out of date and needs update/change.
MidLife8
05-05-2008, 12:36 AM
Today I replaced my coil packs, wires and plugs using your techniques including removing the wheel for access to the plugs. That made it almost easy. Then I removed the corrugated rubber connector from the throttle body to the air intake box. That let me see and touch the coil packs.
BUT, when I started it up, it started right away and revved to 5K easily but as soon as I took it out for a test spin, the engine made sounds like predetonating or pinging or something under load and had no power. I limped home. Looked for disconnected vacuum lines and connectors. Any clues what to look for to fix this?
dannobre
05-05-2008, 12:51 AM
Check to see if you have the wires hooked up right.....
Z0oMzo0m
05-05-2008, 12:54 AM
i reached a 20,000 mile mark, most of it is all highway driving. when should i change my plugs? should it be done now? i noticed when i bought the car they had 2 spark plugs in the glove box? why only 2? and why any at all.. lol
Go48
05-05-2008, 06:54 AM
Depends on how the car has been driven for the 20K miles. Take one of the leading plugs out and have a look at the electrodes and the color of the center electrode insulator. If the electrodes appear "worn" or the center insulator is black or very white (brown is good), replace all the plugs. A good place to purchase these very expensive items is Sparkplugs.com. Check the dealer prices and you will see why. [BTW, if the color of the center electrode is black, there is a problem that is causing an overly-rich fuel-air mixture, or if very white, an overly-lean mixture during the combustion cycle.]
If the plugs in the glove box were new, those plugs should have been installed by the dealer prior to delivering the car to you. Standard procedure. Long story, but basically, the new cars are likely to be repeatedly shut down without fully warming up the engines when moving them in the port area and around the car lot. That can lead to engine flooding. The newly installed plugs at delivery were intended to avoid that.
They were probably leading plugs ("L" on them) since those are the key plugs for this car. The trailing plugs ("T" on them) are not as critical to startup.
quazmosis
06-26-2008, 03:47 PM
Standard [both]: 1.15mm-1.25mm (0.046-0.049in)
Thanks to Go48
What do you mean Standard and Maximum?
MidLife8
06-26-2008, 05:57 PM
Much as I hate to admit it, you were correct. I had a pair swapped. Doh!:banghead:
Thanks.
babyboyx8
12-26-2008, 07:47 PM
Thanks.
im going to remove my spark plug tomorrow and let them dry out because i my car is flooded but i have a question on those picture i see the 2 sparkplugs...are the other 2 plugs right next to the first 2 are they groupped tgether will i be able to see all 4 with the wheel off
Kane
12-26-2008, 07:55 PM
Front set is IN the motor mount area; rear set is to the right of that - you can see and get to all 4 really easy from under the car / wheel well area. Looks like this
T - * *
L - * *
With the front two resting in the motor mount bracket.
SebtownRx8
02-27-2009, 01:07 PM
Just did this Yesterday along with fresh coils. and i gotta say holy crap, i was driving a hybrid compared to now, the leading plugs had 58k on them and look like a toasted bagel with cheese burnt in the center aka i cant even see the damn probe spark wire thing. and the coils were putting up some teribal ohm numbers when i tested them. so i totally recommend this to someone who is feeling a lack of power. great diy every thing spot on.
bad thing i got 4 stitches changing the plugs, they were on so tight when i went to loosen the last leading i busted it open to the bone on my knuckle, lots of blood... and shot.. huge needle... so i'd add WEAR A PAIR OF GLOVES. its worth it. my pinky looks like a blue thumb.
Nubo
02-27-2009, 01:22 PM
Why are you disconnecting the battery for a sparkplug change?
SebtownRx8
02-27-2009, 01:23 PM
no clue i didn't do it, and i changed coils and plugs same time.
Edit:Did that once changing a start years ago. Wrench slipped and it cost me 10 stitches on my hand. @ssholes made me scrub it out with that damn brush and green cleaner crap they use, that stung a little! That big needle was not bad after that experience!
ya i got the shot first then the scrub where i got to see flesh and a little oil and dirt and road grime. i thought i cleaned it pretty well but then they just rip it open and scrub and fold back over. bad experience. aka use gloves
Mazurfer
02-27-2009, 08:06 PM
firebirdude
03-18-2009, 03:03 PM
Awesome writeup. I will be sure to knock this out soon.
Quick question, obviously vehicle abuse would dictate this.... but could someone make some notes on how often these Laser Iridium spark plugs need to be replaced?
Light abuse: XXX miles
Mediocure abuse: XXX miles
Heavy abuse: XXX miles
Track abuse: XXX miles
Maybe something like that. Then add it to the first post?
05shinka
03-18-2009, 08:29 PM
I added new coils - wires - plugs and a HKS Grounding kit 2 days ago.. its like a different car! 34K miles.
gukdoebabdoe
04-02-2009, 08:17 PM
is a spark plug socket necessary?
vglnte1
05-14-2009, 04:09 PM
good stuff here for a Rotary noob like me....couple questions...
the plugs with the grooves in them, by the electrode...are these the trailing, or leading ones?
also, where can i buy new coil packs?
vglnte1
its a good idea...some of these you really gotta torque on...and you dont want to break one off in the block...makes for a bad day
rx8cited
05-14-2009, 11:10 PM
...... the plugs with the grooves in them, by the electrode...are these the trailing, or leading ones?
Leading - see these spark plug pictures (http://www.sparkplugs.com/results_app.asp?productTypeID=1&AAIA=1416844)
...also, where can i buy new coil packs?
OEM coils (http://www.buyourmazdaparts.com/index.php?l=product_detail&p=815)
vglnte1
05-15-2009, 01:08 PM
i dont see the coils on there:eyetwitch
416to212
05-15-2009, 04:47 PM
When you guys change spark plugs do you actually check the gap before install?
Youwonder
07-17-2009, 01:36 AM
nice im going to try this in the next 1000 miless....thanks
Spirograph
07-18-2009, 08:10 PM
Also, someone mentioned in another thread that you must use the copper based anti-seize compound. How necessary is that, or is aluminum compound okay?
2wildbeta86
07-18-2009, 08:32 PM
Bump! x2 I was also wondering the same thing. Im planning on doing this tomorrow (Sunday). If you do check the gap, do u use the same coin things as you would for other spark plugs? Any info on the gapping issue would greatly help!! Thanks!!
416to212
07-18-2009, 09:07 PM
Well after waiting for a reply to my gap question and not getting any answers I justed plugged and played the spark plugs.
1500 miles later Im getting same performance and better gas mileage. No problems.
2wildbeta86
07-19-2009, 07:57 PM
Just did this today and man was that easy!! It feels good to know I did this on my own plus I just saved about a hundred bucks from the dealer. Great DIY!! "so easy even a caveman can do it"
-looks around for the Geico cavemen to see if they get mad-
Thumper3322
07-20-2009, 10:50 AM
Where you guys buying your plugs from?
Where's the best deal on the net?
nycgps
07-20-2009, 10:51 AM
forum vendors here
or go Amazon (probably the best deal right now)
Myriad
08-03-2009, 12:07 AM
So you basically just tightned and torqued and it was fine?
champi0n
09-18-2009, 06:50 PM
Wow, sparkplugs.com wanted $40 to ship them to canada.... nice...
RxMadness
10-11-2009, 02:21 PM
ok I'm about to jump into this. It'll be my first plug change. I am kind of worried about the torque/gap required for reinstalling the plugs. Should I just tighten as normal and hope the anti sieze works when it's time for the next change or is there a method to measure without a torque wrench.
neXib
10-11-2009, 04:24 PM
I'll be doing this soon, missing two of the tools though, brain and spark plug socket. Gonna have to buy one of them soon.
Spirograph
10-11-2009, 10:42 PM
Opinions on using aluminum anti-seize over copper?
I looked at the box for my new plugs a couple of weeks ago, and I think they said to not mess with the gap, that the iridium plugs are too fragile at the tip.
A torque wrench isn't too much, maybe like $15-20 at Autozone?
Spirograph
10-11-2009, 10:45 PM
I don't know if anyone mentioned this, but be careful to make sure that the rubber protective sleeve on your spark plug socket doesn't slip out of the socket and stay behind on the plug. I've had this happen with mine, and I bought a good set. I think too much dielectric grease got into it and made it too slippery.
RxMadness
10-11-2009, 11:01 PM
I'll be doing this soon, missing two of the tools though, brain and spark plug socket. Gonna have to buy one of them soon.the socket and anti-seize cost me less than $2.50 at advance. I opted out of getting the wobble since I had a swivel attachment already annd it did fine. Bashed my wrist up real good though, because I didn't take off the wheel in fear of scratching more paint off my blue lugs :icon_no2: Wish I could help you out with a brain, apparantly I should've picked one up too.
neXib
10-12-2009, 02:59 AM
Thanks for reminding me, haven't got the anti-seize either. But hey, you did it without the brain, good news :)
zaksblaklabel
11-07-2009, 06:37 PM
just changed the spark plugs, wires and coil and now car wont start. any ideas?
kingaaron
11-09-2009, 11:55 AM
Does it turn over when you start it or nothing at all?
zaksblaklabel
11-09-2009, 05:15 PM
i got it solved but thank you for responding
bugbear
11-22-2009, 01:59 PM
Hi Zaksblaklabel, what was the problem?
I've changed my front coils today and the thing won't start. Doesn't seem to be any spark at all or any attempt to catch, just spinning away.
Rote8
11-22-2009, 07:04 PM
Always check the spark plug gap on any plug you install, in any engine.
Measure the spark plug gap using wire type plug gap gauge.
• If it is more than the maximum specification, replace the spark plug.
Standard plug gap
1.15 - 1.25 mm {0.046 - 0.049 in}
Maximum plug gap
Leading side: 1.5 mm {0.059 in}
Trailing side: 1.4 mm {0.055 in}
Turbo or blown engines need around .028 - .035
NotAPreppie
12-14-2009, 08:18 PM
Holy crap! I've never had a car respond this positively to spark plugs!
It might be because one of my plugs wasn't well or completely (or at all) connected to the wire.
It looked like the plug had the rubber end of a plug wire broken off on it and then a new plug wire pressed on without removing the old "bumper" of rubber. It was the first plug I did and at first I thought, "hmm, maybe it's supposed to be there." But, I couldn't get the damn plug wire back on with it present. Removed it and, hey presto, there it goes. Then I took a closer look at the old plug. Very bad.
Front and rear leading plugs (http://homepage.mac.com/jkosi/plugpics/sparkplugs001.jpg). Can you tell which one was having an issue?
Front and rear leading plugs again (http://homepage.mac.com/jkosi/plugpics/sparkplugs002.jpg). How about now?
Front and rear leading plugs one last time (http://homepage.mac.com/jkosi/plugpics/sparkplugs003.jpg). Any takers?
all four plugs (http://homepage.mac.com/jkosi/plugpics/sparkplugs004.jpg). Left to right: rear trailing, front trailing, front leading, rear leading.
Surprisingly enough, the car ran "okay" in this configuration for at least the last 15k miles (I'm at 29k now) which is the last time I had it into the dealer to look into a minor "unsmoothness" at idle though I'm guessing it goes back to the start/plugs/battery recall I had done back in late '06. Two dealers never could solve it (new plugs, coils, ECU reflash, engine and tranny mounts) and it was so barely perceptible so I just let it slide.
Well, the thing purrs like a kitten now. I can't believe I have to wait until next spring before I can get it back out onto an autocross course. :banghead:
ChillinRard
12-15-2009, 08:01 PM
thats pretty awesome, i flooded my car out of ignorance, i wish i knew of this awesome fourm b4:wallbash:...so i ordered some new plugs and is gonnah follow some flooding instructions i found in a post n hopefully it'll start up
77mjd
12-19-2009, 03:16 PM
I really want to try this but that's the part Im worried about too. Wonder how much a dealer would charge if I would go in with the new plugs in hand? I would just add it on top of my next oil change.
NotAPreppie
12-19-2009, 03:40 PM
It took me less than 30 minutes, including moving my wife's car out of the garage to reposition my car to make room for the jack. I've replaced spark plugs on I4 engines before but this was my first rotary.
If you bring in the plugs, I can't see them charging you more than an hour of labor.
racerboy59
12-19-2009, 10:45 PM
Isn't the rule hand tighten then quarter turn? Just make sure you don't cross thread it as that will realy fuck you up, big time.
NotAPreppie
12-20-2009, 05:57 PM
You're thinking of oil filters.
For spark plugs, use your hand to initially get the threads lined up. Then use a torque wrench to set it to the torque specs in the first post.
gabrod72
01-05-2010, 12:19 PM
Just FYI here, my buddy (happens to be a great mechanic) told me to swap out the plugs asap since he just got an 8 with a blown engine... long story short, I've got a bit over 50K and am changing them out.
It turns out the local parts stores use the part number on the outside of the box for the NGK plugs. It looks like Advance Auto Parts will have all 4 plugs I need for $86. The numbers they call out are 6700 and 6701... which matches with the internet cross reference of the RE9B and RE7C...
I'm trying to get this done today or tomorrow so it turns out that the store will get them from a nearby town (Temple) and they'll be here by 2:30pm this afternoon (or so I hope.)
Huey52
01-05-2010, 12:53 PM
See the sparkplug DIY. You can do this!
Removing the driver's side wheel (jackstand) and using a wobble jointed socket wrench extension makes it a breeze. Don't forget to apply some anti-seize paste to the threads and get the leading and following 'plugs in the proper locales ('L' and 'T' cast on the engine block). Just do one at a time so you mate up the proper 'plug cable.
btw: I don't use a torque wrench, but have a long-educated feel to how tight they should be. You only gain that experience by doing.
rXter
01-16-2010, 06:34 PM
Are you talking about the station presets or some radio code that I need?
Huey52
01-17-2010, 11:01 AM
There's no need to disconnect your battery for a sparkplug change (non-constant power to the coils/'plugs), but if you do you will lose your radio/SAT station pre-sets, so write them down (or just remember them - there aren't that many ;)
ahvengeance
01-18-2010, 11:00 PM
Thanks for taking the time to post this on the forum. My 8 is on its third eng and way out of warranty. Coils just went out and the dealer wanted to charge $849 (and some chance) to replace the coils and the plugs. I ordered them myself for about $260 and will tackle this task tomorrow. I was a diesel mechanic in the military for a little over three years, so i know how to wrench, but need to research this issue. Thanks again!
ChillinRard
01-20-2010, 03:10 PM
ok i followed the sparkplug DIY and just realized by your comment that i forgot to apply some anti-seize paste to the threads, what problems will i have for not doing so? do i need to go back and do so?
Huey52
01-20-2010, 03:16 PM
Well done!!! I'lll bet you have a newfound sense of accomplishment to go along with the better performance that new 'plugs bring. :)
No huge deal. The anti-sieze is nice insurance, but most people don't apply it and can still unscrew the 'plugs when the time comes. We enthusiasts tend to change them more then the norm anyway.
Having said that, if it were me I'd go back and apply the paste, but I'm pretty anal that way. You know how to do it now so it won't take you nearly as much time as your first attempt.
ChillinRard
01-21-2010, 03:04 PM
yes thats true! i flooded my 8 the first time forceing me to change the plugs, but when i do my tune up in a coupple months ill apply it then! Well i need to change the oil bkuz i apparently have warter in it bkuz im looking at some creame looking stuff on my oil stick, so that being said i might as well go back and put some sieze on the sparks while im already down there!
CRO8TIA
01-21-2010, 05:17 PM
Milky residue on the dipstick and inside the oil filler is common S1,dont know about others.Its nothing to worry about if the oil isnt milky/sludgy looking.Caused by condensation and can be normally removed by an extended driving session,to purge the moister out of the crankcase,there is a TSB on this subject.
Huey52
01-22-2010, 08:13 AM
An oil catch can is another solution if you're concerned with the "milky oil on the dipstick", properly cited as merely water vapor condensation and harmless. Actually, the catch can has add'l value in separating residue from the intake. There's a DIY on that too. Heck, at this point there's a DIY on everything. Poke around the site and you'll find tons of great insight.
xsnipersgox
02-04-2010, 02:04 AM
i am not subscribed so i didn't see any question, but ya, i have no idea about copper or aluminum anti-seize, i looked around and there is no big deal, just use copper if thats available
04Green
02-06-2010, 12:25 PM
Kudos and Data.
Just use remove wheel process. Worked Great. No door, I just had a little curtain. Pictures of plugs posted. Large, but they are messy. I think they are just worn. I changed them at 67,700. My guess is they were original. Somewhere in here was a suggestion to tighten half a turn past contact. That is old school for non-tapered seat plugs. These are non tapered seat plugs, so that is not bad for NEW gaskets. If you pull the plugs and put them back, only 1/4 turn is needed, the gasket is already crushed.
Car took some time to start to idle right again without stalling. Tried to idle at about 500 (by the tach). Just slowly died. Doing better now.
Theory on Short Plug and Coil life...
My Mazda 6 fires a plug every other revolution, and goes down the highway at about 3,000 RPM, or 1,500 fires per minute.
My Mazda 8 fires a plug 3 times every revolution, and goes down the highway at 4,000 RPM, or fires 12,000 times per minute...
Now, these are better made plugs than any I have used before, but they are also getting close to 10x the use..
Thoughts?
Mike
PeteInLongBeach
02-06-2010, 05:50 PM
Thoughts?
Mike
Actually, the plugs fire 3 times for every rotor revolution, but this equates to 1 time per e-shaft revolution, which is what your engine RPM is based on. So, the plugs are firing twice as much as a 4-stroke piston engine, or the same as a 2-stroke piston engine.
04Green
02-06-2010, 07:34 PM
Cool, Thanks,
That would fit with the really last about half the miles as the other cars, or need to change every 30K or so...
re-rx7
02-10-2010, 02:40 PM
Just changed my girlfriends plugs on her 8. All i needed was a 13/16'' in wrench. Thats it!! Job took 30 min tops! Im use to it though i have had rx7's for awhile now haha!! Good writeup though for beginners..
GeorgiaBII
02-10-2010, 04:33 PM
Nice writeup.
I was able to get the NGK plugs for $12 each. Does anybody have a cheaper supplier?
Leejin
02-10-2010, 05:22 PM
Nice writeup.
$12?? Where did you get them for that cheap at? I searched hell and high water and found them on Amazon for like $19.
GeorgiaBII
02-10-2010, 08:07 PM
I've got a hook up at a local parts house and can get them at employee pricing.
But they are still expensive!
Leejin
02-11-2010, 10:13 AM
$48 for all four is a damn good price my friend. Just over a year ago, the goin' rate was $89.
Kaka8
02-12-2010, 12:31 PM
i search autozone and plugs cost 19.99 each,and duralast coils are 88 ,is this good price? or i need different coils?
04Green
02-20-2010, 09:05 AM
I got mine at amazon. Like $16.99 each, free shipping. They were the NGKs.
No issues so far.
mat128
03-21-2010, 03:46 PM
Use NGK iridium (stock) spark plugs (make sure to get the right ones, we use 2 different kinds for trailing and leading) and OEM coils only.
ShellDude
03-28-2010, 10:39 PM
First post needs to be updated to include additional supplies shown in my attachment.
Also, no clue how people are torquing to 120+ foot lbs with all the extensions it takes to get to the plugs through the wheel well.
I gapped to the amount specified ... .046"-.050" ... Out of the box this set of plugs were well below the .046" "standard".
http://www.rx8club.com/attachment.php?attachmentid=153633&stc=1&d=1269830262
stephenti
03-29-2010, 03:41 AM
I hope you meant 120 in-lb...
ShellDude
03-29-2010, 11:39 AM
yeah.. typo
irishshindig
07-25-2010, 06:18 PM
i was looking at spark plugs and i found DENSO ULTIMATE CLASS IRIDIUM RACING SPARK PLUG, are these good for rx-8?
irishshindig
07-25-2010, 06:19 PM
these plugs are $51 each
08blue6r
08-04-2010, 07:05 PM
well i bought plugs a couple months ago and have put it off until now, but i cant cant find where i put them. damn i guess i gotta buy some more...
ShellDude
08-04-2010, 08:31 PM
I did the exact same thing a year ago.... I still haven't found the "original" new plugs!
08blue6r
08-11-2010, 02:12 PM
Well found the plugs I lost and changed the coils and plugs in hopes that it might fix my hard starting when hot. It didn't. It's never NOT started, it always starts on the first key turn, bit sometimes it can take a couple seconds and sound like it's not gonna start.
However, it does idle alot smoother now
treitz
08-18-2010, 12:13 AM
So my car started having hard starts a few days ago. Asked around, called my loca dealer and decided to start with plugs and wires. Got them switched out (they obviously needed it, they were nasty - 33k miles) but it doesn't seam to have fixed the hard starts.
Whats next? Coils?
Huey52
08-18-2010, 07:55 AM
^ Check to see that you have the faster-spinning starter (mid-2005 build and on upgrade).
Then yes, coils and 'plug cables. Also have your battery's capacity checked.
And be sure your alternator is putting out ~14V.
IOW check your electrical power system end-to-end before getting a compression check (they'll demand same anyway, so may as well save the money and do these things yourself).
cBJr
08-18-2010, 09:07 AM
I did my spark plug change with the car on ramps. Never took a wheel off. It didn't seem that hard to me. I just had to fish a set of extensions through the wheel well cover.
treitz
08-19-2010, 10:12 AM
I didn't take the wheel off either. It wasn't too hard.
What should I be looking for on the starter? Is there actually a build date on it?
The mechanics that listened to it start don't think it sounded like the starter. And they checked the battery and said it's fine. They said that it was cranking fine, it's just not firing right, or getting the right amount of fuel.
Khaf
08-20-2010, 11:41 AM
Sorry if i am asking a stupid question but do you just pull on the plug wires to remove them or do yo need to twist or something? I am asking for both sides (plug side and coil side)
shadycrew31
08-20-2010, 11:43 AM
Thanks for apologizing and not opening a new thread...
Just pull on it, sometimes the seal is a bit tight.
Khaf
08-20-2010, 12:21 PM
Thanks Shady, I knew better not to start a new thread. I just wanted to make sure and not break anything.
mat128
08-21-2010, 05:58 PM
Don't forget to use copper anti-seize when installing new plugs or they can be hard to remove next time. I'm pretty sure this was already mentioned in this thread but just a reminder :)
Beefy98
08-30-2010, 04:39 PM
im about to buy a spark plug socket. should i get one with the swivel built-in or get a separate u-joint?
Huey52
08-31-2010, 07:11 AM
^ get a separate knuckle or universal joint. You need the flexibility a bit further away from the 'plug.
Besides, it will be useful for other projects.
bkcberry
08-31-2010, 10:57 PM
Thanks for the great DIY, changed my plugs and wires tonight.. took about an hour and a half (including a trip to auto zone for a plug socket). My '06 had 47K on it when I bought it (50K now) and the original owner had never changed the plugs :wallbash: so they were pretty nasty. It definitely idles better now, but it's still not perfect.. it sortof makes a thump sound (most notably form the exhaust) every few seconds when it's idling around 700 or 800 RPMs.
Payday is Friday so new coils are next
BTW pneumatic ratchet and impact wrench for loosening plugs and lugs make life much easier :)
PeteInLongBeach
09-01-2010, 04:27 AM
I don't think I'd be using pneumatic tools for the spark plugs. At less than 15 ft lb they shouldn't be that difficult to remove, and if they are you should proceed gently. Aluminum threads and all....
Huey52
09-01-2010, 07:54 AM
^ yep, hand torque only!!!
bkcberry
09-01-2010, 12:26 PM
I only tightened them by hand, the two on the back rotor came out no problem but the ones on the front rotor were determined to stay in there lol they were pretty difficult to get out
Huey52
09-01-2010, 12:35 PM
^ Well, I'm sure you used anti-seize paste this time, so no such issues in the future. ;)
painoracing
09-16-2010, 08:28 PM
I will change my ignition wires this weekend. I bought the Racing Beat ones. They came with small white clips to identify each wire. They have the combination of letter/number T1, T2, L1, L2. I know the L and T are for leading and trailing. But not sure which housing is #1 and #2.
Tks:dunno:
shadycrew31
09-16-2010, 11:18 PM
Coil packs from left to right
LF,TF,LR,TR
Leading front
Trailing front
Leading rear
Trailing rear
Run your wires per the above layout. Search for any other help.
painoracing
09-17-2010, 11:00 AM
LF,TF,LR,TR
Leading front
Trailing front
Leading rear
Trailing rear
Thanks. I also found a picture with the layout. I want to know if the housings usually are reffered as #1 and #2? Which one...the front one is #1? Or the numbers in the clips included are just a refference for me to help not confused the wires in one housing or the other? Tks again.
Boborino
09-20-2010, 09:46 AM
As has been echoed by tons of people, the DIY on this was more than helpful. Pulling the drivers tire and the flappy thing gave immediate access to all 4 plugs. I used a universal 3/8" swivel on my spark plug socket and it went like a breeze. Placed them in the sockets by hand so as to not cross thread first!
Now to my issue. When I pulled the tire off and looked I was staring at the Trailing plug (back rotor, top plug) with NO wire attached! (see picture). It had been idling a little rough, but nothing too harsh. The car just turned 99,001 miles, and these are the original plugs. How can this car with only 4 plugs run so good with only 3 attached???
Huey52
09-20-2010, 12:22 PM
^ doubtful it actually ran as well with three 'plugs, but then if you rarely rev the engine it's typically running more-so on the leading 'plugs (and also more-so the primary injectors).
Remember that the trailing 'plugs are there due to the rotationally long combustion chamber of the rotors and therefore the 'speed of heat' inadequacy of just the leading 'plugs.
Boborino
09-21-2010, 11:26 AM
Huey,
After two days of driving now, I guess the difference is a bit of peppyness at higher RPM's. It didn't seem to help the slightly rough idle I'm beginning to experience though. I'm kind of surprised it didn't throw any codes
painoracing
09-22-2010, 02:20 PM
Thanks to all for the info. Changed my wires. Really easy, especially with the ignition diagram to my side as a safety blanket. If you do it one by one, it's almost impossible to installed them incorrectly. The housings also have the T & L identification.
Less than 30 minutes...
MsWhiteRX8
09-22-2010, 02:30 PM
I found these off ebay.
http://cgi.ebay.com/ebaymotors/IGNITION-COIL-NGK-WIRE-SET-MAZDA-RX-8-2004-2009-_W0QQcmdZViewItemQQhashZitem563f7a8107QQitemZ37043 2180487QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Question is, are these good? How i know which color coil is for the leading or trailing.?:dunno:
Khaf
09-22-2010, 03:19 PM
MsWhite, I bought my OEM coils from Mazmart for 150 i believe and wires from THMotorsport for 37+80 for plugs. So if that is only coils and wires it is expensive and you can find better pricing from vendors here.
On your question I should say there is only one way of connecting the wires because of their length (I learn it the hard way). I think they have number 1 and 2 on wires for front rotor and back rotor and blue is for leading and black is for trailing. I am not sure but that is what I remember. Again once you try it there is only one way of connecting those NGK wires.
painoracing
09-23-2010, 11:04 AM
Although the price doesn't seem so far, I think it's better to shop a little bit more with people like Goodwin Racing, Kamispeed or other vendors...
For installation, I used the diagram that you can find in this same thread, but, it is not that difficult. The lenght of the wires plus the L & T ID's in the housings make it fairly simple, at least for the wires.
Good luck
FastFreddy61
09-23-2010, 01:38 PM
They are OEM,so there as good as stock coils, their all black.
Bigbacon
10-14-2010, 09:34 AM
what is with the gap portion of it...can someone explain that?
Grace_Excel
10-16-2010, 04:41 AM
Huey,
Well, I'm the second owner and drove it for 37k miles before yesterday afternoon when I made the first spark plug change since I took ownership of the car last year. The engine idled rough and showed a few CEL the last 500 or so miles prior to changing the plugs but I didn't bother to check the code, which lead me to focus on the ignition.
I've already encountered a problem: The rear trailing and leading spark plugs wouldn't budge, so I was not able to remove and replace those. The fronts were easy. Wires are in it's corresponding spark plugs. Started the car and CEL disappeared.
Although, with only the front leading and trailing plugs replaced, the CEL disappeared with a rough idle. Drove it around for half an hour and I could feel the power difference prior to the DIY; however, I still have to maintain my foot slightly on the accelarator to keep the idle above 500 RPM, otherwise, the car will stall (but doesn't flood) at a full stop.
It starts up right away and the RPM dips below then rises up to 900 RPM as though the ECU would revive it without the aid of my foot. I don't know if it's due to the new plugs in the front and old ones in the rear for the engine to react this way. I only hope, once I could remove and replace the two remaining plugs in the rear that I wouldn't have a chronic idling problem.
York
10-16-2010, 09:20 AM
Have you tried replacing the coils?
Grace_Excel
10-16-2010, 11:40 AM
It's the next step once I have funds. How bad is it for the engine with inconsistent idling?
York
10-16-2010, 11:53 AM
Not so much the idling you have to worry about, but if your ignition system is weak it won't burn all the fuel, so the unburned fuel will get clogged in your catalytic converter.
Grace_Excel
10-16-2010, 01:28 PM
Objectively, the car runs better than before. Besides the ignition coils, what could be an underlaying cause for the idle to drop. I can aid it to 1000 RPM and it'll stay there, however, if I drive normally and completely remove my foot off the pedal and come to a complete stop. It'll dip straight and stall. Anyway, I might not drive the car until I remove and replace the rear trailing and leading spark plugs, and attempt to clean the Shutter Valve this weekend.
Boborino
10-17-2010, 08:35 AM
Well, a dirty mass airflow sensor can also cause rough idle. I bought a can of MAS cleaner and pulled mine off and cleaned it. Made a pretty big difference in idle. But.. be VERY careful because it's very sensitive.
maffatato15
10-17-2010, 01:46 PM
just changed my plugs in my driveway. Took me about half
hour, first time doing it. Just replaced 1 plug n wire at a time so there is no confusion. My front leading plug was rusty/corroded where the spark plug meets the wire. Im glad it got it done because the car drives and idles much better now.
Just got the rx8 with 51k on it a few weeks back and im trying to do all the maintence right away. Next is changing diff and tranny fluid.
Grace_Excel
10-17-2010, 04:46 PM
I finally removed the rear leading and trailing spark plugs, I was affraid that I'd break the plug. It was so tight that I'm quite positive that the last person who changed it didn't apply the anti-seize prior to putting the old plugs. However, the rough idle slightly improved after I did the "20-tap-brake" reset. Drove it and damn, the wonders of what new plugs could do. I was able to streatch 6 gallons of 91 oct. gas to 130 highway miles. WOW, that's from 16 - 17 mpg last week, now I get close to 21 mpg conservatively! I wonder what a cleaned SSV would contribute.
York
10-17-2010, 05:42 PM
Make sure you use the right oil! Mobil1 or Royal Purple have been known to cause transmission grinding! I just managed to fix mine after using mobil1 :| Red Line other GL-4 oil only! </offtopic>
Grace_Excel
10-17-2010, 07:12 PM
Well, a dirty mass airflow sensor can also cause rough idle... be VERY careful because it's very sensitive.
True, I'm doing that next and the eccentric shaft sensor.
Bigbacon
10-20-2010, 02:59 PM
going to attempt this soon...have the new plugs and wires waiting...
do you necessarily need all those extensions to do the front rotor or can you muscle other tools in there? I lack 3 long extensions.
Grace_Excel
10-20-2010, 03:47 PM
There isn't much room in there, specially if the plugs are difficult to unscrew! I bought a 13/16 magnetic spark plug remover with 10 inch swivel-headed-extension from Autozone; and, 3 and 6 inch extensions.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs288.snc4/40719_1209578496241_1732089955_391652_6980467_n.jp g
Bigbacon
10-21-2010, 02:18 PM
guess I won't be attempting this soon....
themodcity
01-09-2011, 01:06 PM
Well i just replaced the plugs, wires and coils on my 2006 RX8 and the car still wont start, it seemed like it wanted to but just wouldn't...
Any suggestions?
themodcity
01-10-2011, 09:49 PM
anyone?
gregs
01-10-2011, 09:52 PM
sounds like your engine is possibly flooded...search "deflood procedure"
themodcity
01-11-2011, 01:53 PM
tried that....
ArXate
01-11-2011, 08:03 PM
thermodcity, what is your location? I'll bet someone from this forum who lives near you would be willing to drive to your place to help you deflood.
Once you deflood a couple of times, you get the "feel" for it.
laythor
01-11-2011, 08:10 PM
i'll be the first to ask.. there is gas in your tank, right?
themodcity
01-11-2011, 10:48 PM
i am in south Florida, and yes, there is gas in it. But right now i had it towed to the dealer and i'll keep you updated...
