FEED Intake and HKS Twin Power Ignition ?'s
Old Mar 22, 2008 | 10:43 PM
Nopstnz8's Avatar
Question FEED Intake and HKS Twin Power Ignition ?'s
Does anyone have one of these? If so, I need a sound clip, because I would love to buy one if it sounds good.
Also, I was wondering about the HKS Twin Power Ignition. What is the point of it? Does it replace the entire ignition system which is similar to the Mazsport ignition upgrade? Thanks.
Old Mar 22, 2008 | 11:10 PM
1. Yes, someone has it. Search
2. The point of Twin power is an additional item that sits between your ECU and ignition coils to increase igniting power by Storing power in the unit. It does help.but depends on what you want to do with it. It does not replace stock system. Unlike Mazsport.
Old Mar 22, 2008 | 11:37 PM
Nopstnz8's Avatar
I did search and couldn't find it. Could you please post the link. Thanks.
Old Mar 22, 2008 | 11:45 PM
u need to work on ur search skill.
u can google it too.
Old Mar 23, 2008 | 12:04 AM
Nopstnz8's Avatar
Why are you being such an ***? I have been on this forum for a while and always search before I ask a question, especially one that hasn't been repeated a 1000 times. I have been looking for a videoclip for this intake for months, and so far no one has given me info. If you have any please tell me, otherwise leave and go **** off some of the newbs.
Old Mar 23, 2008 | 07:24 AM
u called ^^^^ that being an ***? I think Im very nice to you already.
it took me no more than 30 seconds to find what you've been asking for.
Try harder, if u really cant find it, I will give ya the link.
Like I said, u should try to google it. Learn how to put the correct keyword.
Old Mar 23, 2008 | 10:54 AM
Nopstnz8's Avatar
Yeah I did search pretty much everywhere. I spent about an hour searching google and the forum. Please post the link. Thanks.
Old Mar 23, 2008 | 11:23 AM
The HKS unit is a good upgrade if you stick with the stock ignition...problem is it is about the same price as the upgraded ignitions......
Old Mar 23, 2008 | 01:37 PM
Nopstnz8's Avatar
Yeah that's what I was thinking. It is probably just worth it to get Mazsport's Ignition Upgrade.
Old Mar 23, 2008 | 01:50 PM
invasion08's Avatar
The Mazsport Ignition Solution is well worth it.
Old Mar 23, 2008 | 01:52 PM
MADDSLOW's Avatar
17 second FD
I just bought an HKS Twin Power for my FD because I was having ignition breakup at higher RPMs. So far, I've heard nothing but positive things about it; but it's a little pricey...
Old Mar 23, 2008 | 02:44 PM
invasion08's Avatar
The HKS is a good product it just doesnt fix the RX8's ignition problem which happens to be the coils.
Old Mar 23, 2008 | 03:17 PM
MADDSLOW's Avatar
17 second FD
Are the FE's coils as shitty as the FD's? I'm personally contemplating going with the FC's in mine...
Old Mar 23, 2008 | 03:19 PM
^^ worse
Old Mar 23, 2008 | 03:20 PM
staticlag's Avatar
The Professor
use LS2 coils
Old Mar 23, 2008 | 03:36 PM
shaunv74's Avatar
Power!!
You get about 30K miles out of the coils if you're not tracking and even when they work well you will still get misfires at high RPM in high heat conditions. If you track your car at all it's a good investment.
Old Mar 23, 2008 | 06:55 PM
invasion08's Avatar
I am sure the ls2 coils will work well but with mazsport you get everything you need to install in one nice package.
Old Mar 23, 2008 | 10:28 PM
I think the first step to make stock ignition to work better is to move them ALL AWAY from the engine !
Im thinking to custom cut some pieces to make that happen ...
Old Mar 23, 2008 | 11:09 PM
Nopstnz8's Avatar
So how about the FEED Intake? Any info would be appreciated. Thanks.
Old Jun 3, 2008 | 09:48 PM
MazdaJeff's Avatar
Sorry for the old thread bump, but does anyone have a sound clip for one of these? I also tried searching and could not find one.....
jay_tibo
22
Sep 13, 2016 08:10 PM
Jazzmeson
Aug 6, 2015 04:34 PM
Jazzmeson
Aug 6, 2015 04:32 PM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
