20B renesis pics!!!!!!!
Old Mar 20, 2008 | 04:37 AM
crispeed's Avatar
3-rotor renesis pics!!!!!!!
Here it is!!!!
Engine is running in a drift FD in the UK... thought a 3rotor with side exhaust ports wasn't possible!
The vechicle that's it all in.
Built by----> http://www.mazdarotary.co.uk/
Old Mar 20, 2008 | 06:38 AM
N rider89's Avatar
^NieL
say what?!? looks nice, what are some of the output numbers and more information please
Old Mar 20, 2008 | 08:32 AM
pdxhak's Avatar
Official Post Whore
It was just a matter of time before someone made a 20b Renesis. Is it running?
Old Mar 20, 2008 | 08:41 AM
mike1324a's Avatar
Need'd a Turbo
I like it. Any idea on power or if its ported?
Old Mar 20, 2008 | 08:58 AM
lennon's Avatar
This is what i'm waiting for......
Old Mar 20, 2008 | 09:06 AM
rotarygod's Avatar
Cool looking. It's based on the lower power 4 port engine. I'm not so concerned over whether it actually runs as I am with how much power each rotor makes in relation to each other. I just can't believe that the middle rotor breathes as well as the others due to both of it's exhaust ports being siamesed. You really do need to see those up close to fully appreciate how terrible flow through them is.
Old Mar 20, 2008 | 09:09 AM
Spinning Sushi's Avatar
I <3 Sushi
ITBs on a 3-rotor Renesis... yummy.
Old Mar 20, 2008 | 09:49 AM
Moostafa29's Avatar
Storm Trooper
Numbers!
Old Mar 20, 2008 | 11:25 AM
crispeed's Avatar
That's what I found most interesting.
Old Mar 20, 2008 | 11:30 AM
BigRed's Avatar
w8nkel
numbers por favor
Old Mar 20, 2008 | 11:33 AM
pdxhak's Avatar
Official Post Whore
Originally Posted by crispeed
Here it is!!!!
Too bad there is not any information on 20b build.
Old Mar 20, 2008 | 11:36 AM
I <3 Sushi
Too bad it's not based off of the 6 port renesis like RR said. I would've been nice to have a total of 9 ports...
Old Mar 20, 2008 | 11:40 AM
alnielsen's Avatar
More intake ports don't help solve the problems with the exhaust port.
Old Mar 20, 2008 | 06:03 PM
2k4_8's Avatar
If it's a 20b rene, why does it have 4 exhaust tubes? Isn't it a 2.6 that is two rene's put together??? Even though it just has 3 intake tubes???
edit: NM, I just looked closely again and saw the rotor housings.... <---nub
Old Mar 21, 2008 | 03:22 PM
Hymee's Avatar
Race Steward
It's a 20B, not a 26B.
The Renesis has exhaust ports on each of the side/end plates. 3 rotors = 4 plates, 4 plates = 4 EX tubes, or primaries. You can clearly see the exhaust is not on the periphery, as pre-rennie. A 13B rennie has 3 exhaust "tubes".
Cheers,
Hymee.
Old Mar 21, 2008 | 04:03 PM
Nemesis8's Avatar
Bigus Rotus
I wonder if they figured out the MOP for that setup...
Old Mar 21, 2008 | 04:42 PM
rotorocks's Avatar
RotoRocks Powered
Why isn't it boosted?
Looks nice though, but like RG says, the mid rotor might have difficulties breathing, those shared ports are really tight.
Old Mar 21, 2008 | 05:09 PM
Renesis_8's Avatar
nice to see it done. I predict it could make about 350hp. I don't think the middle rotor of this setup could handle a 6-port version, the exhaust side would be really restricted.
________
Live Sex
Old Mar 21, 2008 | 06:06 PM
Hymee's Avatar
Race Steward
NA all the way!!!
Cheers,
Hymee.
Old Mar 21, 2008 | 06:29 PM
DOMINION's Avatar
I don't buy Kool-Aid
^+1
http://myspacetv.com/index.cfm?fusea...ideoid=3440228
Old Mar 21, 2008 | 06:37 PM
DOMINION's Avatar
Cheers,
Hymee.
Yup 26Bs have 4 rotors
Old Mar 22, 2008 | 12:14 PM
crispeed's Avatar
A quote from the creator!
'Since I have actually built the engine and tuned it i can say that it is very good and I have not driven an N/A engine like it.
This is what the RX8 should have in it.
It has lots of low down torque ,but still wants more and more revs.
Zero overlap of the inlet and exhaust ports helps with exhaust evacuation.
The car has not been on a dyno yet,but I can say that it pulls harder than a modified FD RX7 that is still on stock twin turbo's running around 330hp.
Regards'
Carl
Hayward Rotary
Old Mar 22, 2008 | 12:23 PM
pdxhak's Avatar
Official Post Whore
crispeed,
If you have not already done so, please invite the builder to stop by to discuss his build
Old Mar 22, 2008 | 01:13 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by Renesis_8
nice to see it done. I predict it could make about 350hp. .
if a four port 2 rotor only makes 190hp then 350hp seems a bit optomistic for a 3 rotor 4 port .....
Old Mar 22, 2008 | 05:53 PM
chickenwafer's Avatar
Nope
He said HP not WHP, so I don't think 350-crank is too far off.
I want a video of this, I want to know how it sounds
