225/40-18 FR and 255/35-18 R on Stock Rim
Old Feb 6, 2008 | 10:08 PM
echelon's Avatar
Quick question,
fronts: 225/40-18
rear: 255/35-18
will this work with the 18" stock wheel?
THanks
Old Feb 6, 2008 | 10:28 PM
first-rotary04's Avatar
wankel? what's that?
as far as I've read here the widest you can go is 245.
for example a very common set up is 245/40R18
hope that helps
Old Feb 6, 2008 | 10:43 PM
That is almost a 3% difference in rolling circumference...not sure if the ABS will like that. The 255's will fit on the rim OK...but why bother..go with the same front and back so you can rotate the tires.
If you truly want a staggered setup...you need staggered rims as well to pull it off with the right look
Old Feb 6, 2008 | 10:46 PM
Reducing height on raear compared to front is not good.
Old Feb 7, 2008 | 10:49 AM
Silver_Surfer's Avatar
I4NI
hope that helps
That would be a good set up on all four wheels instead of going stagered.
Old Feb 7, 2008 | 11:49 AM
ZoomZoomH's Avatar
Mulligan User
Originally Posted by echelon
Quick question,
fronts: 225/40-18
rear: 255/35-18
THanks
that's a horrible setup on stock wheels
you want staggered tire setup, get staggered wheels with it too
Old Feb 7, 2008 | 12:09 PM
Huey52's Avatar
Registered Zoom Zoomer
Concur.
Go with 245/40's all around or opt for staggered rims (but keep the treadwall height consistent).
Originally Posted by Razz1
Reducing height on rear compared to front is not good.
Old Feb 7, 2008 | 02:04 PM
Scrapin 240's Avatar
those are bmw spec on the 335i, understeer city!! and plus as everyone else has said the ABS will not like it and the DSC if equipped.
Old Feb 7, 2008 | 02:43 PM
c41250n's Avatar
if you wanna go stragger, you can either do 225/45/18 front 245/40/18 rear or 235/40/18 front and 255/35/18 rear
Old Sep 15, 2018 | 05:51 AM
Sydo's Avatar
Howdy. Thread dig how did you work this out ? Should be the same
Old Sep 15, 2018 | 05:54 AM
Sydo's Avatar
Seems a lot of misinformation here. 225/40/18 is near identical to 255/35/18 with diameter and sidewall heights
Vulkan
Canada Forum
May 27, 2014 01:38 PM
quickice4
Aug 13, 2007 06:01 PM
ayap888
Sep 29, 2004 09:04 AM
corvins_63
Mar 25, 2004 07:13 AM
eclps0
Jan 28, 2004 09:07 PM
