Clutch going bad or what?
Old Oct 26, 2007 | 05:51 PM
galleychief's Avatar
Unbalanced & Unmedicated
Parked in my driveway at about a 25 degree incline, motor off, car in 1st gear. I normally set the parking break but forgot to today. I opened my door to get out, took my foot off the brake, and the car rolled back about a foot. I reached over and pulled up the parking brake and it stopped.
Thinking it rolled because it wasn't in gear, I stepped on the clutch, shifted into 2nd, then back to 1st and released the clutch. I let off the parking break and the car rolled back slowly another foot or two before I set the brake again.
I've had the car almost exactly 4 years to the day. It's got 28,500 miles, most of which are normal driving. It's never been abused but I'll admit to being a "spirited driver" at times. Does this indicate a clutch gone bad?
Old Oct 26, 2007 | 05:53 PM
Spinning Sushi's Avatar
I <3 Sushi
That's normal, don't worry It's the same thing with AT's. You put it in park and it still rolls a little bit before the weight of the internal parts locked it out.
Old Oct 26, 2007 | 07:22 PM
Oh, umm, I forgot to mention that my DSC was off (push and hold) prior to shutting the motor down (don't know if that is relevant) and that If I hadn't applied the hand brake it would have continued to roll in a "jerky" fashion 50 feet backwards down the driveway. . .!
I am well aware of the slight rollback you suggested Renesis SE3P and this ain't it, but thanks anyway.
Old Oct 26, 2007 | 10:57 PM
has nothing to do with dsc..
what happened is normal.. if you put into 3rd it would have made the problem worse...
Old Oct 26, 2007 | 11:26 PM
Swoope,
Just so I am clear. . . If my car is parked on an incline, motor off, in first gear, handbrake disengaged, I should expect it to roll backward??
Old Oct 26, 2007 | 11:38 PM
Originally Posted by galleychief
Swoope,
depends on the incline.. and yes it will happen.. try the same incline in different gears. you will learn a lot..
nothing is wrong.. it is a weight vs incline vs gear ratio thing..
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
