Any one do any Porting
Old Aug 21, 2007 | 03:06 PM
Unseen's Avatar
One of my friends showed me this . I was wondering if any one has done this to the 8 and if so if done on a turbo 8 do you think it blow the engine?
http://www.mazdarotary.net/porting.htm
http://home.iprimus.com.au/bluey3/portsPage/ports.htm
Old Aug 21, 2007 | 03:17 PM
Any one do any searching?
Old Aug 21, 2007 | 03:29 PM
Unseen's Avatar
i have found rx8s with it but cant find how much it costs and i havent seen anything about turbo ported 8s
Old Aug 21, 2007 | 09:03 PM
lone_wolf025's Avatar
Future Rotary User
Look for the thread titled "Rebuilding My Renesis" that'll tell you all you need to know.
Old Aug 21, 2007 | 10:06 PM
rotorocks's Avatar
RotoRocks Powered
Thumbs up
For those who do not understand the science behind turbo ported 8:
Turbo ported 8 it is when one uses the turbo to power the rotation of a portable 8. A portable 8 is an equivalent to a binary portable 01000, which when powered by the rotation of the turbo can easily be converted to 10010, or even greater.
Once again I would like to remind you that any portable 8 can be converted into the binary portable turbo system system by summing the appropriate multiples of the different powers of two injector cycles and divided by the turbo revolutions plus 100. For example, starting from the right, 10101101 represents (1 x 20) + (0 x 21) + (1 x 22) + (1 x 23) + (0 x 24) + (1 x 25) + (0 x 26) + (1 x 27) + 100= 273 HP (Average relyable stock horse power after the system implementation) .
I hope I am making myself clear.
Old Aug 21, 2007 | 10:09 PM
nelsonrx8's Avatar
so , 10101101 represents (1 x 20) + (0 x 21) + (1 x 22) + (1 x 23) + (0 x 24) + (1 x 25) + (0 x 26) + (1 x 27) + 100= 273 HP O i get it
Old Aug 21, 2007 | 10:19 PM
Brettus's Avatar
Boosted Kiwi
Wow - i think you just switched on a light bulb in my mind ++111111!!!!!
check out this porting job ...
http://en.wikipedia.org/wiki/Image:P...n_at_night.jpg
Old Aug 21, 2007 | 10:24 PM
rotorocks's Avatar
RotoRocks Powered
Dont forget +100
Edit: Above mentioned was spoken with a straight face
Old Aug 23, 2007 | 02:32 AM
Lasse wankel's Avatar
Lasse wankel
I have done a mild stage 0.5 street port on the renesis side plates. But i am very bad at posting pictures for sure! But if you search for lasse wankel flow numbers you will see some numbers. I think i found 10-12 % more airflow in the plates with only reshaping the ports and not adding more timing.
/Lasse
Old Aug 23, 2007 | 10:17 AM
r0tor's Avatar
theres also a vid of a car on this forum that has a ported and turbocharged renesis...
Old Aug 23, 2007 | 10:29 AM
Wow
Old Oct 9, 2008 | 11:40 AM
ira1377's Avatar
what kind of wheels are those
Old Oct 9, 2008 | 11:54 AM
Charles R. Hill has his ported, was done by RG. check the thread mentioned above
Old Oct 9, 2008 | 11:59 AM
alnielsen's Avatar
There are also posts, long ago, by guitarjunkie. He ported his engine before he was killed in an auto accident. There may be some information there.
Old Oct 11, 2008 | 10:01 AM
HeavyMetal699's Avatar
When are you going to release the dyno of your ported engine?
I remember you mentioning it in another thread.
For anyone hoping to get the same port job done as CRH you're SOL. Fred has adamantly said NEVER AGAIN.
Old Oct 11, 2008 | 08:00 PM
The thing that people should understand about porting their Renesis engines; to do so carries with it a strong chance that the resonance frequencies for which the intake system was designed will change and you may end up with droning at certain RPMs and load points. Further, although Lasse has measured increases in airflow that does not necessarily mean more power. You may be able to pick up a little power but the trade-off is that porting the Renesis is FAR more difficult than previous rotaries. Thus, it is a cost vs. power value decision. For anybody who plans on going F/I, I tend to suggest AGAINST porting as the power gained isn't usually worth the money or trouble.
Here's a general concept to keep in mind; although we all think we want the baddest-*** RX-8 on the road, the further we get away from the factory engineering/tuning the narrower the context in which driving the RX-8 can be an enjoyable experience. This is why MazdaManiac, Easy_E1, and I carefully scrutinize the parts we design for the RX-8 and why BHR's product list is very short at this time. It is also why I have a very short list of suggested mods.
great post, and great advice!
Old Oct 12, 2008 | 11:15 AM
No rush, as I said before Fred has clearly stated HE would not port another set of irons in the future. At least unless someone paid him quite a sum of money.
I'm just curious what the results are. It does not seem to be something I'd ever do in the future at this point. So take your time.
Old Oct 13, 2008 | 12:17 PM
rotary.enthusiast's Avatar
The Local Idiot
Nobody else is going to comment on the fact that this year-old thread was resurrected by somebody asking about the wheels in somebody's sig?
Old Oct 20, 2008 | 09:33 AM
Jungleagent's Avatar
Member guitarjunkie28 is the member right? Did he die in his rx8?
Old Oct 20, 2008 | 09:56 AM
dozer's Avatar
on his 3rd rx8
^?????+1????
Old Oct 20, 2008 | 10:17 AM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
He died in a rotary coming down the hill from Big Bear in California. Head on accident.
Old Oct 20, 2008 | 01:39 PM
Rip
Old Oct 20, 2008 | 01:43 PM
ZumnRx8's Avatar
RX8 & RX7 owner
Yeah Yeah Yeah
Old Oct 20, 2008 | 02:19 PM
remixlp's Avatar
^^ your sig is full of win.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Evan Gray
Nov 24, 2015 01:00 AM
bosstin87
Oct 5, 2015 06:52 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
