putting brake back together, help!
Old Apr 9, 2007 | 11:31 PM
BlueRenesis82's Avatar
Registered Tracker
I am reassembling my brakes after painting my calipers, I wasnt smart and did not write which caliper came from which side. Now the calipers have R and L stamped in them, are they referring to the view from in front of the car looking at the nose, or from inside the car?
Also if anyone has pics of their brakes without the wheels on I would really appreciate you posting them.
thanks
Old Apr 10, 2007 | 12:03 AM
R is the side of the car from the drivers seat looking forward.....R is passenger front and L is drivers front in NA
Cheers
Old Apr 10, 2007 | 12:50 AM
Registered Tracker
would it make a different if i installed the front calipers reversed?
Old Apr 10, 2007 | 01:02 AM
d j's Avatar
d j
hukbong himpapawid
I think you would know if you installed them incorrectly, it would not sit right and you'd have problems putting eveything back together. look up a few pics of peoples calipers (installed) and use it as a refference. There should be a few floating around (search)
Old Apr 10, 2007 | 06:52 PM
Registered Tracker
back together.
thanks
Old Apr 10, 2007 | 07:40 PM
easiest way = bleed nipple has to be at the top, if you reversed them it would be on the bottom
Old Apr 12, 2007 | 07:44 AM
Registered Tracker
thanks for the help team, i will remember that in the future
Audio Concepts ATL
Sep 26, 2021 01:59 PM
UHATEIT
Mar 31, 2019 05:31 PM
BigMikeATL
May 26, 2016 12:31 AM
