greddy turbo + unlimited
Old Dec 25, 2006 | 12:33 AM
LiL BenNy's Avatar
Bubblicious? DEF.
greddy turbo + Ultimate
so i know most people run the greddy with the intx and reach about 300whp... for those who are using greddys new emanage what whp have your reached and at what psi?
dont flame and say searhc blah blah im trying to create a thread that shows the whp users have accomplished with the Ultimate
-benny
(merry christmas, happy holidays!)
Old Dec 25, 2006 | 01:36 AM
Ultimate??
Old Dec 25, 2006 | 01:38 AM
RazzyBRX-8's Avatar
Representin'!
^^^...I think that's what he means.
Old Dec 25, 2006 | 07:22 AM
mikeschaefer's Avatar
I wanna rock! Rock!
I haven't seen any EMU users post numbers. Oh, and Merry XMAS
Old Dec 25, 2006 | 07:51 AM
mysql101's Avatar
I don't think 300 is the norm, even for int-x users. Several have posted whp numbers around 270 (Epi and some other guy). You can push the car to the edge to get 300... but the turbo doesn't flow enough to make it hold boost past 5-6k rpm.
Old Dec 25, 2006 | 10:45 AM
LiL BenNy's Avatar
Bubblicious? DEF.
what about with the mazsport upgrade? that should help right?
Old Dec 25, 2006 | 12:10 PM
mysql101's Avatar
The turbo upgrade? I haven't seen any numbers for it, so I don't know how much it helps.
If your turbo blows, then the upgrade might not be bad to get... but until there's published numbers, we have no idea.
Old Dec 25, 2006 | 04:56 PM
gh0st's Avatar
guitarjunkie will be running one with clipped turbines. that *should* raise max hp a bit. he will be running the int-x though.
just to be clear, the int-x deosnt increase max hp. its more consistent and makes it easier to approach the max but the greddy kit is limited by its turbo in terms of HP.
Old Jan 3, 2007 | 10:46 PM
BigOLundh's Avatar
#1 Legend
the turbo in the greddy kit is only rated for up to 310 whp. just like any turbo, it has a set max possible power. its not easy to reach the turbos max, but once you do... nothing you do will increase that until you change the turbo.
-hS
Old Jan 4, 2007 | 03:31 AM
Fanman's Avatar
Manuel in PR basically welded the wastegate shut, and put on an external, turned up the boost to high heaven (12+ psi) and got to about 310 whp. Beyond that it rapidly lost efficiency & turned into a heat unit. At that level it has nothing to do with the EMU, and everything to do with the maxing out of the turbo. Also the wastegate spring on the internal wastgate may be a weak point on this turbo. I agree with the posters above expect around 250-270 whp and be happy. That is the high end of this kit.
Old Jan 12, 2007 | 07:21 AM
VarneyMazda's Avatar
Northeast Pimpin'
ditto i talked to scott a while back and he said the best i could conservatively get out of my greddy kit is around 260-280 range.
we are talking whp here.
Old Jan 12, 2007 | 02:08 PM
brillo's Avatar
Go Texas Longhorns!
I would tune the greddy kit for about 260whp and be done with it. You can get a good, safe tune with a broad torque curve that will make your 8 a whole different car.
Speed is more than peak HP.
Old Jan 17, 2007 | 03:43 PM
Northeast Pimpin'
i totally agree!!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
jDt!
Oct 2, 2015 04:04 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
