RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } RX-8 20B 3-Rotor Conversion W/ Spare 20B - Needs Rebuild
Old 03-16-2021, 08:54 PM
RxRot's Avatar
Up for sale is a 2004 3-Rotor Conversion RX-8 in Lightning Yellow. 47.5K miles on the chassis. I have a clean and clear title in hand. The front fenders, hood and front bumper were painted when the Mazdaspeed bumper was installed for a color match. A clear bra was then installed at Xpel - the leading edge of the hood and fenders were also done. Also included is a spare chrome wheel and the Mazda factory shop manual and car cover. All the factory gauges work as well as the factory steering wheel controls for the stereo.
I purchased the car with an (undisclosed) A-series weak engine and when I discovered this, I purchased a C-series core with brand new housings. The engine was rebuilt 2500 miles ago. I still have the original engine and the 20B housings (re-useable) from the core engine. I have run Idemitsu rotary premix 1-1.5oz. per gallon for break-in. Unfortunately, during dyno-tuning the fuel pump failed, causing the engine to lean out and as a consequence, the apex seals sagged. The engine car is tuned for 12psi and still runs, but the engine requires another rebuild (low compression). It's a sharp car and gets compliments everywhere, but after all the time and expense I'd like to move on. I'm willing to sell the car alone or with the extra engine. Asking $25,000 with both engines, $21500 without the spare. The 2nd disassembled motor needs one more rotor and full rebuild kit to use. If you have any questions, feel free. Serious inquiries only please. No test drives unless cash is available. Thank you for your interest. Below is the list of parts:
Engine Bay -
C-Series core with 3 brand new turbo rotor housings. New oil seals, o-rings, side seals, corner seals, competition oil seal springs, 2 mm Rotary Aviation Super Seals, Exedy Twin Disc Clutch. Dual oil coolers with 3,000 psi hoses and steel braided hoses. 115 psi oil pressure regulator, Koyo radiator, Unorthodox chrome power steering pulley, 200 amp dual stairs 12 diode alternator (140amp at idle), high torque custom starter, Greddy catch can, custom cnc torque damper, power steering cooler, custom coolant reservoir. Spal extreme duty dual fan. Comp Turbo 76mm with ceramic ball bearings, Tial 60mm waste gate.
Suspension -
H&R Street Coilovers, custom 3 rotor sway bar, racing beat rear sway bar, racing beat front end links, new 93 RX-7 rack and pinion.
Transmission & Final drive -
Euro-spec RX8 5 speed transmission (similar to the FD RX7), Mazdaspeed 430 final drive with torsen differential.
Interior -
AEM boost controller, AEM UEGO Digital wideband AFR, SPA water temp and fuel pressure gauge, SPA oil pressure and oil temp gauge, Digital EGT gauge, Microtech ECU with data logger and lambda upgrade, Microtech hand controller, Bosch coils, 3-Rotor logo on front seats (center of seat is suede), JDM 5-speed shift ****, Pioneer 3300 BT radio. Push to start button.
Fuel -
New fuel rail with 850 primary injectors, 1600 secondary injectors, dual-in tank 3-Rotor fuel pumps, -8 feed line with inline fuel filter.
Brakes -
Stock cross drilled and slotted rotors, kevlar brake pads, steel braided brake lines.
Exhaust -
Custom built 3-Rotor exhaust manifold and downpipe, Agency Power 3" SS Catback.
Exterior -
Mazdaspeed front bumper and side skirts, chrome stock wheels, factory fog lights with led lights as DRL.
Cost Breakdown Given By Previous Owner -
$7,500.00 To buy a 3-Rotor on E-bay
$2,700.00 3 New Rotor Housings
$5,000.00 To rebuild, port & polish
$2,400.00 JDM 5-Speed Trans
$1700.00 Exedy Twin Disc Clutch
$1,100.00 High Torque starter, 200 amp Alternator (140 amps at idle)
$1,800.00 Microtech ECU
$600.00 Microtech Handheld & Turbo Timer
$1,600.00 Gauges (Boost gauge/controller, Water Temp, Fuel pressure/oil press/oil temp, EGT/AFR)
$2,300 Custom 3in. Exhaust, Agency Power 3" Stainless Steel Exhaust
$1,600.00 Mazdaspeed Front Bumper/Side Skirts
$900.00 Clear Bra
$1,100 H&R Street Coilovers
$530.00 430 Gears
$2,400 Turbo and Custom built manifold $400.00 60mm Waste gate
$400.00 BOV
$500.00 CNC custom built torque damper
$625.00 Mazda Car cover, Shop manual, Spare wheel
$400.00 3 Rotor Seats
$800.00 Chrome AN polished parts
$1,200.00 Intercooler and piping
$550.00 SPAL Extreme Duty Dual Fans, Heavy duty relays
$175.00 Fuel Pressure Regulator
$380.00 Yellow Top Optima,mount,priority start
$600.00 Pioneer Radio,Metra Kit
$280.00 Koyo Radiator
$600.00 Vintage Air Steel Braided A/C Lines and Fittings for 134 freon.
$200.00 Greddy Catch can
Total: $40,340.00 + the value of the car + labor, so somewhere in the neighborhood of $70-80K
Old 03-16-2021, 09:02 PM
///// Upscale Zoom-Zoom
wannawankel's Avatar
Engine Bay -
Suspension -
Interior -
Fuel -
Brakes -
Exhaust -
Exterior -
$900.00 Clear Bra
$530.00 430 Gears
$400.00 BOV
Best of luck - she's a beaut.
Old 03-17-2021, 06:16 AM
FULLY SEMI AUTOMATIC
200.mph's Avatar
Received 2,363 Likes on 1,992 Posts
glws. is/was this a texas car? looks like one of 9krpms buddies car
renesisjim (11-16-2023)
Old 03-17-2021, 06:40 PM
No respecter of malarkey
Received 2,025 Likes on 1,649 Posts
It was formerly Tito Ramos’ 3-rotor RX8 from Texas and I think it’s in Indiana now, but the OP needs to confirm where it will need to be seen and picked up from.
Wannawankel; you reply copied the whole thing just to post “best of luck”, really?
The following 4 users liked this post by TeamRX8:
200.mph (03-18-2021), J_Ro (03-22-2021), Lvlvl (03-23-2021), renesisjim (11-16-2023)
Old 03-17-2021, 07:15 PM
24歳、学生です
Shaozhou Zhang's Avatar
saw this car on Craigslist either at Indianapolis or Bloomington 2 years ago when I was looking for mine, not sure if it is still around.
Old 03-20-2021, 07:57 AM
RxRot's Avatar
Yes, the car is in northern Indiana - Middlebury to be exact. It's about 30 miles east of South Bend.
Old 03-22-2021, 09:57 AM
REW 8 with JDM stuff..
J_Ro's Avatar
Free bump. I bought my REW swapped 8 at the beginning of last year if I remember correctly. Wishing I saw this post coming some how lol. Love me some yellow and love the swap even more. GLWS.
Old 04-03-2021, 06:34 PM
Godzilla831's Avatar
Hey if it’s still for sale lmk. I sent you a PM here and on RX7. Thx
Old 06-13-2021, 07:32 AM
RxRot's Avatar
With the weather finally warming up, I was able to get video of a cold start, warm up and idle two days ago. Feel free to contact me if you would like to see it.
Old 07-23-2021, 06:29 PM
RxRot's Avatar
SOLD! I'm excited to see how she turns out with the new owner.
Old 07-29-2021, 12:40 AM
peterpangea's Avatar
Me too! A 20B RX-8 is a dream build, especially in NA trim for me. Curious to see what they do with it.
Old 07-22-2022, 09:19 AM
Trinituner's Avatar
20b
I own this Rx8 now,needs fuel pump rewire ,rebuild and some electrical corrections.Great seller,awesome car.Wayyy too much torque for the drivetrain.
Mazdaspeed body kit.
Very tight fit.
The following 3 users liked this post by Trinituner:
Fickert (12-28-2022), peterpangea (04-04-2024), pfknrx8 (09-22-2022)
JETS3T8
618
05-26-2024 06:56 PM
slvrstreak
348
04-26-2020 11:12 AM
rgonza
1296
02-08-2019 05:47 AM
logalinipoo
274
12-17-2015 10:39 PM
Rambling Man
15
01-16-2004 12:51 PM
Quick Reply: { FS } RX-8 20B 3-Rotor Conversion W/ Spare 20B - Needs Rebuild
