RX-8 Technical Info (CEL codes, PCM pin list, collision guide)
Old Apr 20, 2004 | 08:31 PM
Code:
DTC #   Condition        MIL       DC       Monitor   Self-test   Memory
P0030 - Front HO2S heater control circuit problem                                                              -       ON -      2 - HO2S heater - C, O, R   -    Yes
P0031 - Front HO2S heater control circuit low        -       ON -      2 - HO2S heater - C, O, R   -    Yes
P0032 - Front HO2S heater control circuit high        -       ON -      2 - HO2S heater - C, O, R   -    Yes
P0037 - Rear HO2S heater control circuit low        -       ON -      2 - HO2S heater - C, O, R   -    Yes
P0038 - Rear HO2S heater control circuit high        -       ON -      2 - HO2S heater - C, O, R   -    Yes
P0076 - VDI solenoid valve control circuit low        -      OFF -      2 -       Other - C, O, R   -    Yes
P0077 - VDI solenoid valve control circuit high        -      OFF -      2 -       Other - C, O, R   -    Yes
P0101 - MAF sensor circuit range/performance problem                                                           -       ON -      2 -         CCM - C         -    Yes
P0102 - MAF sensor circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0103 - MAF sensor circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0107 - BARO sensor circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0108 - BARO sensor circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0111 - IAT sensor circuit range/performance problem                                                           -       ON -      2 -         CCM - C         -    Yes
P0112 - IAT sensor circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0113 - IAT sensor circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0117 - ECT sensor circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0118 - ECT sensor circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0122 - TP sensor No.1 circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0123 - TP sensor No.1 circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0125 - Insufficient coolant temperature for closed loop fuel control                                          -       ON -      2 -         CCM - C         -    Yes
P0126 - Insufficient coolant temperature for stable operation                                                  -       ON -      2 -  Thermostat - C         -    Yes
P0130 - Front HO2S circuit problem        -       ON -      2 -        HO2S - C, O, R   -    Yes
P0131 - Front HO2S circuit low voltage        -       ON -      2 -        HO2S - C, O, R   -    Yes
P0132 - Front HO2S circuit high voltage        -       ON -      2 -        HO2S - C, O, R   -    Yes
P0133 - Front HO2S circuit slow response        -       ON -      2 -        HO2S - C         -    Yes
P0138 - Rear HO2S circuit high voltage        -       ON -      2 -        HO2S - C, R      -    Yes
P0139 - Rear HO2S circuit slow response        -       ON -      2 -        HO2S - C, R      -    Yes
P0171 - System too lean        -       ON -      2 - Fuel system - C, R      -    Yes
P0172 - System too rich        -       ON -      2 - Fuel system - C, R      -    Yes
P0222 - TP sensor No.2 circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0223 - TP sensor No.2 circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0300 - Random misfire detected        - Flash/ON - 1 or 2 -     Misfire - C         -    Yes
P0301 - Front rotor misfire detected        - Flash/ON - 1 or 2 -     Misfire - C         -    Yes
P0302 - Rear rotor misfire detected        - Flash/ON - 1 or 2 -     Misfire - C         -    Yes
P0327 - KS circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0328 - KS circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P0335 - Eccentric shaft position sensor circuit problem                                                        -       ON -      1 -         CCM - C         -    Yes
P0336 - Eccentric shaft position sensor circuit range/performance problem                                      -       ON -      1 -         CCM - C, R      -    Yes
P0410 - AIR system problem        -       ON -      2 -  AIR system - C, R      -    Yes
P0420 - Catalyst system efficiency below threshold                                                             -       ON -      2 -    Catalyst - C         -    Yes
P0441 - EVAP system incorrect purge flow        -       ON -      2 - EVAP system - C, R      -    Yes
P0442 - EVAP system leak detected (small leak)        -       ON -      2 - EVAP system - C, R      -    Yes
P0443 - Purge solenoid valve circuit problem        -       ON -      2 -         CCM - C, R      -    Yes
P0446 - EVAP system vent control circuit problem                                                               -       ON -      2 - EVAP system - C, R      -    Yes
P0455 - EVAP system leak detected (large leak)        -       ON -      2 - EVAP system - C, R      -    Yes
P0456 - EVAP system leak detected (very small leak)                                                            -       ON -      2 - EVAP system - C, R      -    Yes
P0461 - Fuel gauge sender unit circuit range/performance problem                                               -       ON -      2 -         CCM - C         -    Yes
P0462 - Fuel gauge sender unit (main) circuit low input                                                        -       ON -      2 -         CCM - C, O, R   -    Yes
P0463 - Fuel gauge sender unit (main) circuit high input                                                       -       ON -      2 -         CCM - C, O, R   -    Yes
P0480 - Cooling fan No.1 control circuit problem                                                               -      OFF -      2 -       Other - C, O, R   -    Yes
P0481 - Cooling fan No.2 control circuit problem                                                               -      OFF -      2 -       Other - C, O, R   -    Yes
P0500 - VSS circuit problem        -       ON -      2 -         CCM - C         -    Yes
P0505 - Idle air control system problem        -      OFF -        -             - R         -     No
P0506 - Idle air control system RPM lower than expected                                                        -       ON -      2 -         CCM - C         -    Yes
P0507 - Idle air control system RPM higher than expected                                                       -       ON -      2 -         CCM - C         -    Yes
P0562 - System voltage low (KAM)        -       ON -      1 -         CCM - C, O, R   -    Yes
P0564 - Cruise control switch input circuit problem                                                            -      OFF -      1 -       Other - C, O, R   -    Yes
P0571 - Brake switch input circuit problem        -      OFF -      1 -       Other - C, O, R   -    Yes
P0601 - PCM memory check sum error        -       ON -      1 -         CCM - C, O, R   -    Yes
P0602 - PCM programming error        -       ON -      1 -         CCM - C, O, R   -    Yes
P0604 - PCM random access memory error        -       ON -      1 -         CCM - C, O, R   -    Yes
P0610 - PCM vehicle options error        -       ON -      1 -         CCM - C, O, R   -    Yes
P0638 - Throttle actuator control circuit range/performance problem                                            -       ON -      1 -         CCM - C         -    Yes
P0661 - SSV solenoid valve control circuit low        -       ON -      2 -         CCM - C, O, R   -    Yes
P0662 - SSV solenoid valve control circuit high        -       ON -      2 -         CCM - C, O, R   -    Yes
P0703 - Brake switch input circuit problem        -       ON -      2 -         CCM - C         -    Yes
P0704 - CPP switch input circuit problem        -       ON -      2 -         CCM - C         -    Yes
P0850 - Neutral switch input circuit problem        -       ON -      2 -         CCM - C         -    Yes
P1260 - Immobilizer system problem        -      OFF -      1 -       Other - C, O      -     No
P1686 - Metering oil pump control circuit low flow side problem                                                -       ON -      1 -         CCM - C, R      -    Yes
P1687 - Metering oil pump control circuit high flow side problem                                               -       ON -      1 -         CCM - C, R      -    Yes
P1688 - Metering oil pump control circuit initial check problem                                                -       ON -      1 -         CCM - C, R      -    Yes
P2004 - APV stuck open        -       ON -      2 -         CCM - C, O, R   -    Yes
P2006 - APV motor control driver IC problem        -       ON -      2 -         CCM - C         -    Yes
P2009 - APV motor control circuit low input        -       ON -      2 -         CCM - C, O, R   -    Yes
P2010 - APV motor control circuit high input        -       ON -      2 -         CCM - C, O, R   -    Yes
P2016 - APV position sensor circuit low input        -       ON -      2 -         CCM - C, O, R   -    Yes
P2017 - APV position sensor circuit high input        -       ON -      2 -         CCM - C, O, R   -    Yes
P2067 - Fuel gauge sender unit (sub) circuit low input                                                         -       ON -      2 -         CCM - C, O, R   -    Yes
P2068 - Fuel gauge sender unit (sub) circuit high input                                                        -       ON -      2 -         CCM - C, O, R   -    Yes
P2070 - SSV stuck open        -       ON -      2 -         CCM - C, O, R   -    Yes
P2096 - Target A/F feedback system too lean        -       ON -      2 - Fuel system - C, R      -    Yes
P2097 - Target A/F feedback system too rich        -       ON -      2 - Fuel system - C, R      -    Yes
P2102 - Throttle actuator power supply line circuit low input                                                  -       ON -      1 -         CCM - C, O, R   -    Yes
P2103 - Throttle actuator power supply line circuit high input                                                 -       ON -      1 -         CCM - C, O, R   -    Yes
P2106 - Throttle actuator control system-forced limited power                                                  -       ON -      1 -         CCM - C         -    Yes
P2107 - Throttle actuator control module processor error                                                       -       ON -      1 -         CCM - C, O, R   -    Yes
P2108 - Throttle actuator control module performance error                                                     -       ON -      1 -         CCM - C         -    Yes
P2109 - TP sensor minimum stop range/performance problem                                                       -       ON -      1 -         CCM - C         -    Yes
P2112 - Throttle actuator control system range/performance problem                                             -       ON -      1 -         CCM - C         -    Yes
P2119 - Throttle actuator control throttle body range/performance problem                                      -       ON -      2 -         CCM - C, O, R   -    Yes
P2122 - APP sensor No.1 circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P2123 - APP sensor No.1 circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P2127 - APP sensor No.2 circuit low input        -       ON -      1 -         CCM - C, O, R   -    Yes
P2128 - APP sensor No.2 circuit high input        -       ON -      1 -         CCM - C, O, R   -    Yes
P2135 - TP sensor No.1/No.2 voltage correlation problem                                                        -       ON -      1 -         CCM - C, O, R   -    Yes
P2136 - TP sensor No.1/No.3 (calculation value in PCM) voltage correlation problem                             -       ON -      1 -         CCM - C, O, R   -    Yes
P2138 - APP sensor No.3 (calculation value in PCM)/No.4 (calculation value in PCM) voltage correlation problem -       ON -      1 -         CCM - C, O, R   -    Yes
P2195 - Front HO2S signal stuck lean        -       ON -      2 -        HO2S - C, R      -    Yes
P2196 - Front HO2S signal stuck rich        -       ON -      2 -        HO2S - C, R      -    Yes
P2257 - AIR pump relay control circuit low        -       ON -      2 -  Air system - C, O, R   -    Yes
P2258 - AIR pump relay control circuit high        -       ON -      2 -  Air system - C, O, R   -    Yes
P2259 - AIR solenoid valve control circuit low        -       ON -      2 -  Air system - C, O, R   -    Yes
P2260 - AIR solenoid valve control circuit high        -       ON -      2 -  Air system - C, O, R   -    Yes
P2270 - Rear HO2S signal stuck lean        -       ON -      2 -        HO2S - C, R      -    Yes
P2271 - Rear HO2S signal stuck rich        -       ON -      2 -        HO2S - C, R      -    Yes
P2401 - EVAP system leak detection pump control circuit low                                                    -       ON -      2 - EVAP system - C, O, R   -    Yes
P2402 - EVAP system leak detection pump control circuit high                                                   -       ON -      2 - EVAP system - C, O, R   -    Yes
P2404 - EVAP system leak detection pump sense circuit range/performance problem                                -       ON -      2 - EVAP system - C         -    Yes
P2405 - EVAP system leak detection pump sense circuit low                                                      -       ON -      2 - EVAP system - C, O, R   -    Yes
P2407 - EVAP system leak detection pump sense circuit intermittent/erratic problem                             -       ON -      2 - EVAP system - C, O, R   -    Yes
P2502 - Charging system voltage problem        -      OFF -      1 -       Other - C, R      -    Yes
P2503 - Charging system voltage low        -      OFF -      1 -       Other - C, R      -    Yes
P2504 - Charging system voltage high        -      OFF -      1 -       Other - C, R      -    Yes
U0073 CAN system communication error (See DTC TABLE [MULTIPLEX
COMMUNICATION SYSTEM] )
U0101 Communication error to TCM
U0121 Communication error to ABS HU/CM
U0155 Communication error to instrument cluster
U0167 Communication error to keyless control module
Old Apr 30, 2004 | 06:47 PM
Omicron's Avatar
PCM (ECU) pin diagrams
For you enjoyment and reference :D
Each page split into 3 parts. Here's the first part of page 1
Attached Thumbnails RX-8 Technical Info (CEL codes, PCM pin list, collision guide)-scan000035a.jpg
Old Apr 30, 2004 | 06:48 PM
Omicron's Avatar
second part, first page
Attached Thumbnails RX-8 Technical Info (CEL codes, PCM pin list, collision guide)-scan000035b.jpg
Old Apr 30, 2004 | 06:49 PM
Omicron's Avatar
third part, page 1
Attached Thumbnails RX-8 Technical Info (CEL codes, PCM pin list, collision guide)-scan000035c.jpg
Old Apr 30, 2004 | 06:50 PM
Omicron's Avatar
Page 2, first part of 3
Attached Thumbnails RX-8 Technical Info (CEL codes, PCM pin list, collision guide)-scan000036a.jpg
Omicron's Avatar
page 2, second part of 3
Attached Thumbnails RX-8 Technical Info (CEL codes, PCM pin list, collision guide)-scan000036b.jpg
Old Apr 30, 2004 | 06:51 PM
Omicron's Avatar
page 2, last part of 3. Enjoy! :D
Attached Thumbnails RX-8 Technical Info (CEL codes, PCM pin list, collision guide)-scan000036c.jpg
Old Jan 19, 2007 | 10:15 PM
Smile RX-8 Collision Guide with part numbers
Attached in PDF format is the RX-8 collision guide, it shows a lot of major parts and their part numbers
due to the size please right click, save target as ...
File Type: pdf
Old Oct 8, 2007 | 05:48 PM
Muthafodder's Avatar
WOW....great find here!!!
Here is the complete engine diagnostics and troubleshooting steps to take for each. Looks like what the Techs use. Credit to revolutionrotorclub.com for the link and Google for letting me find it!!!
http://www.revolutionrotorclub.com/f...ne_Control.pdf
Old Mar 4, 2008 | 10:18 PM
Heres a link to idiot lights.
https://www.rx8club.com/series-i-tech-garage-22/what-service-light-139547/
Old Jul 13, 2008 | 01:34 AM
Sgt Fox's Avatar
Foxed.ca
Since I didn't see it listed anywhere here, I have the RX-8 FSM and some other Rx-8 documents at the bottom of this page:
http://rx7.foxed.ca
Old Nov 28, 2009 | 04:53 AM
2004-2008 RX-8 Maintenance Part Number List
File Type: pdf
Old Sep 13, 2010 | 03:31 AM
Exclamation Renesis engine rebuilt/overhaul manual
I found this copy of the S1 Renesis engine service/overhaul manual on the web. Haven't checked it against my actual manual to see if it's complete or not. It seems to end abruptly.
File Type: pdf
Old Sep 16, 2010 | 09:07 PM
Nemesis8's Avatar
Bigus Rotus
Yeah, that is incomplete
Old Oct 11, 2012 | 02:43 PM
RIWWP's Avatar
S2 focused, but appears to provide the accurate S1 info as well. Have not found similar S1 document to compare for accuracy.
Old Jan 15, 2013 | 03:07 AM
ASH8's Avatar
Super Moderator
I just wanted to add this here as some Dealers are telling owners that their PCM/ECU needs replacement when CEL and code (DTC) P0610 which is PCM malfunction and or configuration error...this is not always correct as in most cases the ECU/PCM will survive after this re-config..see PDF.
Many Mazda Dealers are not giving out correct advise and or performing the correct IDS update/config procedure.
To reconfigure ANY Mazda PCM and or re-flash (update) make sure your dealer performs the attached PDF instructions with Mazda IDS (MMDS), it is not, repeat NOT, the procedure that Mazda IDS will instruct the Dealer to do, as the 'normal' IDS Instruction will in many cases not resolve the issue
or advise for the PCM to be renewed when this is not actually needed.
The reconfiguration MUST be performed EXACTLY to the letter in the PDF..""MZ PCM Recovery""
It is also imperative that your RX-8's Battery is in good/top condition and in most cases a 20 AMP Battery Charger should also be attached when the VCM/IDS is in use as it can drain car battery without a suitable tender or battery jumper.
File Type: pdf
Old Feb 12, 2013 | 08:27 AM
RIWWP's Avatar
A list of all Mazda recalls as of recently. The ones for the RX-8 are bolded:
RECALLS
0100L - 1993-1995 RX-7 with Mazdaspeed Carbon Fiber Hood - Recall
0301B - 2000-2001 Protege Left Side Rear Flexible Brake Hose Recall
0401H - 2001 B-Series Seatbelt Buckle Recall
0502A - 2000-2001 MPV DX Brakeline Proportioning Valve Replacement Recall
0602D - 2002 MPV Certification Label - Recall
0702F - 1999 - 2000 Protege Ignition Coil - Emission Recall
0802H - 2001 MPV Passenger-Side Air Bag Module Recall
0903C - 2002-2003 MPV Front Fog Lights Recall
1003E - 2003 Miata PCM Replacement Recall
11012 - 1981 RX-7 Recall
1103F - 2002-2003 MPV, 2001-2003 Miata, and 2003 Mazda6 Fog Lights Recall
1203F - 2003 Mazda6 Brake Reservoir Recall
1303F - 2003 Mazda6 Check Engine Light Emission Recall
13305 - 1978-83 GLC and 1979-82 626 Recall
1403L - 2003 Mazda6 Fuel Odor Recall
14410 - 1981-82 626 Recall
1503L - 2001 Tribute Seat Belt Cover Replacement Recall
15410 - 1981-82 GLC Recall
1604B - 2004 MPV and 2004 RX-8 Front Passenger Side Airbag Recall
1704B - 2004 RX-8 Manual Transmission Dynamic Damper - Recall
17510 - 1977-83 GLC, 1979-82 626 and 1979-83 RX-7 Recall
18601 - 1982 GLC Cruise Control Recall
1904D - 2001-2003 Tribute Powertrain Control Module Re-Calibration - Recall
19604 - 1986 626 Throttle Sensor Campaign - Recall
2004F - 2000-2001 MPV Actuator Cable Recall
20604 - 1986 626 Evaporative Emission Control System - Recall
2104F - 2004 MPV FMVSS Certification Label Recall
21605 - 1982 RX-7 Evaporative Emission Control System - Recall
2204H - 2002-2003 MPV PCV Hose Emission Recall
22702 - 1982 GLC Exhaust Emission Recall
2304J - 2004 Mazda3 Crash Zone Sensor Recall
25711 - 1986 RX-7 Exhaust Emission Recall
2604L - 2004 Mazda6 Rear Seat Belt Recall
26801 - 1986 - 87 RX-7 Front Brake Recall
2704L - 2002-2004 Tribute Accelerator Cable Recall
27801 and 28801 - 1988 626/MX-6 Fuel Fixing Band and Rear Drum Brakes Recall
2804L - 2004-2005 Tribute Lift Gate Recall
29802 - 1988 929 Evaporative Emission Recall
3005C - 2003 Protege Intake Manifold and Variable Tumble Control Valves Emission Recall
30803 - 1988 626/MX-6 Throttle Valve Frosting Recall
3105G - 2004 Mazda6 "O2" Sensor Failure No Illumination Recall
31805 - 1988 626 Automatic Shoulder Belt Recall
3205G - 2004 Mazda6 3.0L Evaporative Circuit Failure Emission Recall
32903 - 1985 RX-7 Exhaust Emission Control System Recall
3305G - 2004-2005 RX-8 Thermal Damage Recall
34006 - 1986-87 626 Ignition Switch Recall
3405G - 2004 RX-8 Front Lower Arm Ball Joint Recall
3505H - 2001-2002 Miata Emission Failure Recall
3605J - 2006 Mazda5 Heat Damage Around Main Silencer Recall
3705K - 2006 B-Series and 2006 Tribute Windshield Wiper Motor - Recall
38101 - 1989 MPV Brake Vacuum Hose Recall
3906C - 2006 Miata Air Bag Recall
39103 / 40103 - 1991 Navajo Fuel Tank Heat Shield and Rear Bumper Reinforcement Recall
4006D - 2005 Tribute Headliner Compliance Recall
4106E - 2006 Mazdaspeed6 Lack of Power - Voluntary Emission Recall
41106 - 1991 MX-5 Miata ABS (Anti-Lock Brake System) Recall
4206F - 2004-2006 RX-8 Reprogram PCM - Voluntary Emission Recall
42110 - 1989 MPV Brake Lock-Up Recall
4306K / SSP68 - 2006 Mazda5 Sliding Door Latch - Recall
43202 - 1991 Navajo Rolling In Park Position Recall
4407B - 2007 Mazdaspeed3 Genuine Mazda Accessory All-Weather Floor Mat Recall
44205 - 1990-91 MPV Rear Brake Shoe Recall
4507C - 2001-2004 Tribute Anti-Lock Brake System - Voluntary Safety Recall
45206 - 1990 Miata Catalytic Converter Recall
4607F - 2007 Mazdaspeed3 Engine Mount Bolt - Safety Recall
46204 - 1993 MX-6 Lower Ball Joint Retaining Bolts Recall
4707H - 1998-2002 B-Series Cruise Control Deactivation Switch Recall
47206 - 1990-91 626/MX-6 Turbo EGR Valve Recall
4807H - 2007 CX-7, 2007 Mazdaspeed3, and 2006-2007 Mazdaspeed6 MIL Illumination (DTC P2006) - Voluntary Emission Recall
4907H - 2007 CX-7, 2007 Mazdaspeed3, 2006-2007 Mazdaspeed6, and 2006 Mazda6 OBD-II Compliance - Voluntary Emission Recall
49301 - 1991-92 B-Series White Steel Spoke Wheels Recall
5008H - 2007-2008 MAZDA6 (Cal. Spec. Only) - Metal Fuel Tank Coating Recall
5109A - 2009 B-Series 4X2 Front Spindle Voluntary Safety Recall
5209A - 2009 Mazda6 Outer Door Handle Voluntary Safety Recall
5309B - 2007-2009 CX-9 Power Adjustable Driver's Seat Voluntary Safety Recall
53404 - 1988-91 626 and 1988-89 929 Outer Door Handle Recall
5409D - 2010 Mazda3 Emission Harness Voluntary Safety Recall
5509E - 2009 Mazda3 Dynamic Stability Control (DSC) Safety Recall
55406 - 1991 B3000 and B4000 Front Fuel Line Assembly Recall
5709J - 1995-1997, 2001-2003 B-Series Cruise Control Deactivation Switch Recall
57409 - 1994 B-Series and 1993-94 Navajo Parking Brake "Skip" Thru Recall
5810B - 2010 CX-9 Seat Warmer Voluntary Safety Recall
58502 - 1995 626 Passenger Side Air Bag Recall
59503 - 1995 Protege Engine Valve Spring Recall
6010H - 2007-2009 Mazda3 and Mazda5 Power Steering Voluntary Safety Recall
60504 - 1993-94 RX-7 Fuel Leakage Recall
6110K - 2009-2010 Mazda5 Fuel Pump Connector Voluntary Safety and Emission Recall
61510 - 1992-93 Navajo Liftgate Bracket Reinforcement Recall
6211B - 2009-2010 Mazda6 2.5L Engine Fuel Tank Safety and Emission Recall
63602 - 1994 B2300 Throttle Icing at Highway Speeds Recall
6411F - 2008-2009 MAZDA3 and MAZDASPEED3 Windshield Wiper Motor Voluntary Safety Recall
64603 - 1994 BSeries and 1991-94 Navajo Brake Booster Replacement Recall
6511K - 2012 Mazda3 Variable Valve Timing System Voluntary Emission Recall Campaign
65609 - 1993-95 RX-7 Brake Vacuum Hose Recall
6611K - 2010 CX-7 and 2010 Mazda6 Readiness Code For Evaporative Monitoring System Emissions Recall
6712A - 2001-2002 Tribute ABS Relay Installation and Master Cylinder Reservoir Cap Replacement Voluntary Safety Recall
6812G - 2001-2008 Tribute 3.0L Engine Cover Modification Voluntary Safety Recall
68702 - 1989-91 RX-7 Automatic Shoulder Belt Recall
70709 - 1992-1995 MX-3 Front Coil Spring Recall
72803 - 1990-1994 323, 1992-2993 MX-3, 1990-1993 Protege - Automatic Shoulder Belt Recall Campaign and Door Latch Switch SSP
73801 - 1998 626 PCM Recall
75804 - 1999 Miata Fuel Injector Recall
77810 - 1998 626 Radio Recall
80906 - 1998-1999 B-Series Cruise Control Cable Recall
82907 - 2000 MPV Door Lock Recall
83910 - 1995 626 Emissions Recall
85001 - 1993-1994 Navajo Liftgate Bracket Reinforcement Recall
86003 - 2000 MPV Reprogramming of the Powertrain Control Module (PCM) - Recall
87004 - 1994 626/MX-6 Headlight Switch - Recall
88004 - 1999 Miata Hard to Refuel Recall
89004 - 1999-2000 626 Brake Master Cylinder Cap Recall
90006 - 2000 MPV Tire Labels Recall
91007 - 1995-1996 Protégé Headlight Switch Recall
92007 - 1998 626 2.0L Engine Timing Belt Tensioner Recall
93008 - 2001 Tribute Cruise Control Cable Cap Damage Recall
94009 - 2001 Tribute Steering Wheel Mounting Nut Damage Recall
95010 - 2000 B-Series Front Passenger Side Seat Belt Buckle Recall
96009 - 2001 Tribute Incorrect Rear Wheel Hub Installation Recall
97010 - 2001 Tribute Fuel Leak Recall
98011 - 1999 Protegé with FMS Audio Rear Speaker Recall
99011 - 2001 Tribute Owner’s Manual Correction Child Restraint Anchorage System Instructions Recall
Old Feb 7, 2015 | 03:22 PM
Jim Daugherty's Avatar
Does anyone know what the CAN bus protocol is for a series 1 RX8? I know it is 11 bit (500kb) but is it j1939? I know its too old for j1969. I'm trying to power aftermarket gauges in an RX8 renesis into an MGB, using the RX8's ECU, but it seems I need to know which protocol is being used to know which adaptor might work.
Old Feb 7, 2015 | 05:55 PM
ASH8's Avatar
Super Moderator
J2534
Old Dec 10, 2015 | 10:49 PM
Stephanee Drost's Avatar
I have a 2004 mazda rx8 and I am wondering why I am pulling 15 volts from the OBD2? I had lost my keys and was having a set made The locksmith made the key and when he went to program it he said that my OBD2 was pulling 15 volts and he didn't know why. Would you happen to be able to help with this?
Old May 16, 2020 | 01:15 PM
5. Differential
The Limited Slip Differential (LSD), which prevents wheels from slipping when cornering or suddenly starting, is essential for sports driving. Torque sensing LSD was adopted for the RX-7 ahead of other companies, and its response to accelerator operation, vehicle controllability, and traction at the start of a corner have been well received in the market. With the RX-8, we have further improved the vehicle controllability while maintaining the well-received responsiveness and traction, aiming to develop an LSD that is fun and safe for all drivers to drive in both limit and normal driving.
To achieve this, we have developed a new torque sensing type LSD “Super LSD” with a structure that the RX-8 has a low torque bias ratio (TBR) and the friction surface does not change regardless of the driving direction. Furthermore, by adding initial torque, the controllability of the vehicle during cornering is improved by suppressing changes in the differential limiting force when the driving direction between the acceleration and engine brakes changes, and the vehicle stability during start and straight running is improved. Increased. As a result, we were able to achieve both vehicle controllability and stability. Fig.8 shows the cross section of Super LSD, and Fig.9 shows the differential control.
Old Jun 18, 2020 | 12:07 PM
A boatload of service manual and other RX8 information, but in chinese language.
You can still glean a lot of information if you’re resourceful. Not sure how long this will last, but get it while you can:
https://share.qclt.com/汽车论坛免费资料第三期/Mazda%20RX-8%20车间手册/
Old Jun 18, 2020 | 12:28 PM
UnknownJinX's Avatar
Smoking turbo yay
Originally Posted by TeamRX8
A boatload of service manual and other RX8 information, but in japanese language.
Actually, it's all in Chinese, where RX-8 was sold in limited quantities.
Had a quick look and it looks like it covers a lot of the stuff a Service Manual would cover, but if you go under 动力总成(powertrain), there are some animations for the different mechanisms of the engine.
Old Jun 18, 2020 | 01:10 PM
oops 😬 although they share a lot of kanji, I should have noticed there wasn’t any katakana was just ripping through the downloads
Old Jun 4, 2022 | 09:48 PM
Body Shop Repair manual, critical RX8 body repair info as attached
File Type: pdf
xfz
23
Oct 24, 2023 07:43 AM
Speed_8
15
Jun 25, 2021 12:09 PM
blue ninja
Sep 30, 2013 09:06 AM
MazdaManiac
Europe For Sale/Wanted
41
Sep 14, 2011 04:54 PM
JohnO
Jun 21, 2005 02:52 PM
