{WTB} Megan Racing Rear Lower Camber Arms
Old 10-07-2013, 08:55 PM
  #26
Project Seca
Ricky SE3P's Avatar
Category: Steering & Suspension
maybe not...but i may not have another option.. (since ill be leaving my car at this height)
Old 10-14-2013, 11:11 PM
  #27
Project Seca
Ricky SE3P's Avatar
still in the market
Old 10-31-2013, 08:03 PM
  #28
Project Seca
Ricky SE3P's Avatar
up to the top
Old 10-31-2013, 10:52 PM
  #29
Originally Posted by TeamRX8
that said, if they bend just dropping the jack quickly they likely aren't going to last too long on the street without bending
LOL...just read this again I tipped the car off the jack and caught the arm with the jack underneath it.... was no small wonder the arm bent
Wasn't one of my smarter moves
Old 10-31-2013, 11:13 PM
  #30
Project Seca
Ricky SE3P's Avatar
been doing research on heim joints for a bit now, too. general consensus is that YES the drive will be noticeably rougher and i will have more suspension noise, the joints are in fact durable especially if you keep an eye on maintaining them. additionally, there are products you can buy that act as debris shields for these joints.
Most of the issues with these joints arise when you have them used on roads where corrosive substances are applied (salt on roads for example, there are many other cases). I will never encounter these conditions. Also, these joints see the most wear and tear when they have to rotate in multiple axis. due to our rear suspension design, the heim joint would simply be load bearing and rotate on a single plane/axis just as the stock arm does.
the fact i can later on replace the heim joint in the megan arms with much higher quality when its time to do so makes me pretty confident in the purchase. not to mention i only put about 7,000 miles a year on my car. ill be just fine and report as time goes by on condition just for everyone here
Old 10-31-2013, 11:57 PM
  #31
No respecter of malarkey
Received 2,025 Likes on 1,649 Posts
The only real to maintain that style heim joint is to replace it
Old 11-01-2013, 12:50 AM
  #32
pepsi1337s's Avatar
get a custom shop to do them. mine megan racing chamber arm bent too.
Old 11-01-2013, 01:02 AM
  #33
Project Seca
Ricky SE3P's Avatar
Those covers i mentioned helped protect from debris making them wear even more prematurely, andive read that for non-teflon coated heim's that graphite lube can help extend life and is "safe" due to being a dry lubricant. Once they wear out of course i would purchase some quality replacement joints.
Old 11-01-2013, 01:12 AM
  #34
Project Seca
Ricky SE3P's Avatar
How did you bend your arm? It takes a decent amount of force to bend an arm like hitting a curb
Old 11-01-2013, 02:49 PM
  #35
I had no idea that your experience with them exceeded my own, my apology
Old 11-01-2013, 05:19 PM
  #36
Z0oMzo0m's Avatar
I have the megan rear camber and rear toe. i have easily 20k on them. i have no signs of being bent, or falling apart or loose ends. I drive on normal everyday roads, and dont road race with my car :shrugs:
Old 11-01-2013, 08:58 PM
  #37
Project Seca
Ricky SE3P's Avatar
haha no your experience far exceeds mine. i was simply stating observations of mine, excuse the misunderstanding there please.
also... i made a world of mistakes last night involving buying things online in my sleep (no lie. fell asleep with my laptop next to me.. i must have been straight zombie-mode and got back on there and bought camber arms, and 11 pairs of 194 leds.. seller cant issue refund as item already shipped...so looks like ill be selling some 194 smd leds for corner markers pretty soon to make up for money spent from putting 11 instead of 1)
Old 11-01-2013, 09:08 PM
  #38
pepsi1337s's Avatar
daily driven, never tracked. had about -6 Degrees of chamber. only had 2k miles on them. bent because it couldn't handle my aftermarket whitelines sways. where it is connects to the sways endlink is where it bent. quiet disappointed.
Old 11-01-2013, 09:18 PM
  #39
Project Seca
Ricky SE3P's Avatar
im trying to get less camber with these, not more. i also have stock sways and links.
Old 11-01-2013, 10:28 PM
  #40
Z0oMzo0m's Avatar
I'll have to go under and really focus and see if its bent. But from what I have seen they are notI have coilovers, agency power end links and sway bars. So suspension is fairly stiff.
Old 11-02-2013, 12:44 AM
  #41
pepsi1337s's Avatar
just dont worry about megan racing. i thought itd keep me by. but they totally wasn't worth the money. either way, even if you aren't supporting anything fancy. because of the performance and lack of durability. they aren't worth the money. better to get a same price with custom arms. best way to go with rx8s with lack of arms in the market.
WingleBeast
22
05-23-2016 09:22 PM
ColeParkerrr
09-15-2015 07:30 PM
dylan424
08-21-2015 06:10 PM
philip53
07-30-2015 04:18 AM
MolecularConcept
07-26-2015 09:09 PM
Quick Reply: {WTB} Megan Racing Rear Lower Camber Arms
