Dyno Results Compilation
Old Jul 26, 2010 | 09:44 PM
  #701
Originally Posted by GeorgeH
- do sensors change over time, requiring an annual tune-up?
Thanks,
George
Not sure if they change . Mine gave out and I when I replaced it I noticed the reported afrs differed from the previous sensor by a bit less than 1/2 a point (I also have an AFR guage so could see the diference) . My fuel comsumption improved immeadiately after fitting the new sensor.
Old Jul 26, 2010 | 10:11 PM
  #702
GeorgeH's Avatar
Air filter is a K&N drop-in, recently clean (same filter as last year). MAF is a possibility, I'll check it (I normally don't over-oil the K&N, but you never know).
Brettus, which sensor died on you, and what were the symptoms?
Old Jul 26, 2010 | 10:24 PM
  #703
the front one .
AFRs were all over the place in closed loop and when doing a log it would run ok till it warmed up then just flatline at 14.7 .
Old Aug 2, 2010 | 06:30 AM
  #704
The O2 sensor only affects closed loop operation. I seriously hope you weren't in closed loop on the Dyno.
Old Aug 17, 2010 | 05:09 AM
  #705
schumi1996's Avatar
2006 RX-8 japanese specs, Injen short Ram intake, Tanabe exhaust, ACT clutch+light flywheel-211HP on the Dyno.Images to fallow
Old Oct 13, 2010 | 02:45 PM
  #706
SEANMAC777's Avatar
Originally Posted by Nemesis8
1. Dynojet 1-21-06. 63 Degrees, 47% Humidity, Altitude 250 feet, Seattle
2. 200.8 RWHP / 148.6 FT-LBS (SAE Corrected to 196.77 / 142.75)
3. Below
4. REVi, Ultra Plug Wires, Lineage Grounded, UR Pulleys, MS Flywheel, RP Supercat Midpipe, RB REV8 Dual Catback, CZ with Slight Fuel Mods Only
More Info Here
now these numbers, along with several others, are disappointing.
All of my mods are.....borla exhaust, rp supercat, sr pulleys, act prolite flywheel, act 6 puck race disk, and cobb accessport w/ mazdamaniac tunes.
I cant find my charts right now, but I know my best pull with was only 166rwhp and the the torque was really low. I cant quite remember what it was, but i feel that for all of the money i have spent trying to improve the car...166 is pretty low. Does anybody else agree with me? Or are my expectations just too high?
Old Oct 13, 2010 | 04:10 PM
  #707
shaunv74's Avatar
Power!!
What did it dyno before the mods on that same dyno? Do you know how much you gained?
Old Oct 13, 2010 | 10:56 PM
  #708
SEANMAC777's Avatar
no, i dont know. I dont even know of any dyno's within a few hours of my house here in iowa. I got a chance to do a dyno when I was in Alabama, and I cant find my charts anywhere that would tell me the info on the dyno.
I unfortunately dont have too much info on the dyno, but I would still think it should be higher than that.
Old Oct 13, 2010 | 11:48 PM
  #709
HockeyRX-8's Avatar
TNC
Here's my printout from the East Coast MM dyno day back in August
Mods:
-Borla catback
-Racing Beat Dual Res midpipe
-Cobb AP w/ MM tunes
-K&N panel filter
-Racing Beat ram air duct
I was very pleased with the results. A BHR ignition kit should put my car at the 200whp mark!
Old Oct 14, 2010 | 12:07 AM
  #710
Tamas's Avatar
Registered Lunatic
Here is mine from the last NorCal dyno day in August.
Mods are just a RB intake / duct, BHR ignition and Cobb AP with MM tune.
Old Oct 16, 2010 | 09:49 PM
  #711
shaunv74's Avatar
Power!!
Maybe but without a baseline you don't know if it's the dyno or your car. Different dynos read differently and depending on the load setting you can get different results. You need to perform a vacuum check or compression check to determine if your engine is strong or not. Dynos are just comparative tools for measuring changes and tuning, not for absolute numbers.
Also without a chart we have no idea if the engine looks healthy or not. If you can post up a chart we can tell you if thinks look okay or if something looks wrong.
Old Nov 12, 2010 | 07:03 PM
  #712
ganseg's Avatar
Nature vs. Nurture
MN
Had some fun today - got a dyno run. It is cold up here, but before winter I wanted to try my RB V2 software and straight midpipe. So, I put in new coils and RB Plug wires, synthetic oil, K&N drop in and got two runs for $50. These were run in 4th gear.
I am new to dynos - is this adjusted for the low temp and not "smoothed" too much? The first run he only went to 7k. I had reset my long term fuel trim before this. The LTFT did build up before the second run, but it doesn't appear to have hurt anything.
The car is a 2005 mt with 34,000 miles.
Old Nov 14, 2010 | 02:15 PM
  #713
951Rx8's Avatar
anybody know of a good dyno shop in southern california??
Old Nov 14, 2010 | 10:32 PM
  #714
FazdaRX_8's Avatar
subscribed
Old Nov 15, 2010 | 11:52 AM
  #715
renesisking's Avatar
Is the BHR Ignition kit tunable?? I have a microtech that I am waiting to get back from KD Rotary and I have yet to tune my car but I am curious if you can adjust the ignition kit with the Microtech LT-10 (Interceptor X).
Old Nov 15, 2010 | 12:22 PM
  #716
That isn't how ignition systems work.
You adjust the EMS to operate the ignition system, not the other way around.
Old Dec 3, 2010 | 08:00 PM
  #717
ganseg's Avatar
Nature vs. Nurture
Got my car dyno'd stock to see how it compares with the RB and straight midpipe. I saw how to turn the image horizontal this time too!
Old Dec 3, 2010 | 08:03 PM
  #718
ganseg's Avatar
Nature vs. Nurture
Mods:
-Borla catback
-K&N panel filter
What happened with the AFR on a couple of the runs?
Old Dec 12, 2010 | 02:29 AM
  #719
GeneRamsey's Avatar
Rx8 Arbelist
SC
I ran this test without using the bump shifter. I just got this car so Ive only removed the stock muffer and installed two flow masters in its place
04 RX8 AT (new motor)
Old Dec 12, 2010 | 07:18 PM
  #720
shaunv74's Avatar
Power!!
I suspect your weight is too heavy. (Unless you weigh 800lbs.)
Also you're going to have a hard time estimating horsepower based on 1/8 mile runs. The launch and shifting speeds will introduce variables that will lower your calculated values.
You should try setting it up to just record a full throttle run from a low RPM to redline in 2nd or 3rd gear.
Old Jan 3, 2011 | 10:19 PM
  #721
1Point3's Avatar
2007 rx8 6-speed just hks legamax cat-back, other than that totally stock. original spark plugs and coils. 1000 ft elevation, 57 degrees, 91 octane, dynapack chassis dyno. best of 3 pulls. AFR steady around 12.5. Did this for a baseline before the Esmeril Racing Turbo kit gets here.
Old Feb 28, 2011 | 01:52 AM
  #722
shadycrew31's Avatar
WENTGERMAN
Base I was at 205 whp 143 tq.
Sorry for the **** quality, don't mind the torque. The first 4 runs were picking up around 147tq at 207 whp.
Best we figured it it was 150 tq at 218 whp airflow at 240.
Mods...
D585 ignition system assembled by me wires purchased form rotaryfan 1991 fixed by BHR (Thanks Ray)
RP super cat with a blown cat
HKS Hi Power
ACT prolite flywheel
ACT HD street clutch
SR motor sports pulleys
Stock intake with a panel filter
Wrapped boost bros headers
RB template street port done by my friend and me when we were doing the rebuild
I think that's it for relevant mods, next year I want to break 220.
Old Mar 1, 2011 | 10:19 AM
  #723
240 g/sec of air.
Not 440. lol
Old Mar 1, 2011 | 10:26 AM
  #724
WENTGERMAN
Thumbs up
240 g/sec of air.
Not 440. lol
Yea I was half asleep when i saw your screen... I forgot to change this post lol, thanks for the reminder.
Old Mar 1, 2011 | 12:11 PM
  #725
laythor's Avatar
I zoom therefore I am.
420?
