DIY: RP (AFE) Short Shifter install.
Old Jul 14, 2006 | 01:01 AM
  #176
Hymee's Avatar
Race Steward
Originally Posted by falcon
Very nice shifter, Paul.
Richard makes a nice shifter as well
Nice to hear you don't have any noise issues.
Cheers,
Hymee
Old Jul 14, 2006 | 07:08 AM
  #177
falcon's Avatar
Slave to my RX-8 SE
Cheers,
Hymee
Old Jul 15, 2006 | 08:57 PM
  #178
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
hey thanks for the diy. I juss installed mines and loving it.. Like everone else i thought the clip/tab part was the hardest..but after awhile i got mad and couldnt wait any longer and pulled the tab towards me and up..whoa the whole panel came off without breaking the clip hahaha,lucky me i guess...
Old Jul 15, 2006 | 09:01 PM
  #179
NgoRX8's Avatar
haha... i spent 20 minutes trying to get out that tap only to come back and continue reading to find that i was pushing it the wrong way. and so i went about pushing it the other way and it came off quick.
the tap pisses everyone off. except those that just grabbed it by the shift boot and pulled. easy for them...
Old Jan 5, 2007 | 06:09 PM
  #180
Urchin's Avatar
Cheers,
Hymee
I installed mine, and heard the whine in 5th and 6th when first trying it before putting the console cover back on. With the cover back on, I do not hear the noice. I did take the green fuzzy thing out.
I was wondering, on the stock shifter the plastic on the bottom bushing goes a bit below the metal ball on the end of the shifter. On the short shifter, the bottom of the plastic is even with the metal ball, and does not cover it. Could the metal on the bottom of the shifter be touching the metal on the shifting rod in certain gears or at certain times? That could transmit a whining type of noise.
Old Mar 26, 2007 | 02:09 AM
  #181
BlueFrenzy's Avatar
Rotary Powered Decepticon
Thanks for the this DIY. Had a bitch of a time trying to get that right hand clip off. I ended up doing the brute force method of pulling up on the boot. But still the right hand clip would come undone ... in the end I broke it. The rest of the install was easy from there. I did find a surprise guest in the upper boot ... there was a spider! (dead of course). I can now see what you guys were talking about with regards to the "bolt action" vs the soft cushy OEM. I'm getting a little more noise than before but I have my stereo on most of the time anyways, so it doesn't matter.
Thanks again to Gomez for the DIY and thanks to Richard Paul for this great product.
Old Apr 20, 2007 | 02:56 PM
  #182
limepro's Avatar
45 minute install thanks to gomez and i didnt even have the correct tools had to do with what i could find
Old Aug 10, 2007 | 02:32 AM
  #183
sleeperx8's Avatar
anti-bandwagon
great write-up! no problems with install... not even the tab, i just yanked up. hardest part was fixed when i re-read the stuff about that metal thingie sticking out has to face the right side (it was for the reverse gear)
Old Aug 20, 2007 | 03:59 PM
  #184
RX8Z88M's Avatar
Smile Fix the broken tab (clip) near the parking brake boot
I also broke the infamous tab during the RP shifter installation. I found the best way to repair the tab is to install a new A-Clip. There is an unused A-Clip post (YELLOW circle) near parking brake boot. I simply purchased a new A-clip (GREEN Arrows) and installed over the post. Everything is back as new.
Here are the steps:
1. buy the A-Clip ($0.71) from Mazda
2. use a flat head x-acto knife to carve out the groove on one side (make the post "I" shape)
3. heat up a flat-head screw driver and burn a slot for the clip to latch in
4. clip the A-clip over the post
Make sure you measure the slot position carefully for a tight fit.
-RX8Z88M
Attached Thumbnails DIY: RP (AFE) Short Shifter install.-rp-clip.jpg
Old Sep 4, 2007 | 07:56 AM
  #185
fanaticz's Avatar
I just wanted to say good job Gomez and the rest of the crew for putting up such a great DIY. I installed the short shifter yesterday, and wow. I had no idea a shifter could make that much of a difference in the overall satisfaction of the car, but I stand corrected.
Excellent job all and thanks. I didn't quite break the tab, but I did bend it a bit. I don't seem to have any problems shifting between 5th, 6th, reverse, nor do I hear any whining.
Old Sep 13, 2007 | 05:14 PM
  #186
type59's Avatar
mrjackwong
Does the noise happen because the nuts that hold the plate down isn't torqued?
Old Sep 13, 2007 | 05:17 PM
  #187
Gomez's Avatar
Shifty Bastard.
No.
Old Sep 29, 2007 | 04:02 PM
  #188
Mazurfer's Avatar
Surf Hard, Drive Hard
Gomez.......good DIY. I have one suggestion that worked really well for me, it's a small portion of the install, but will save some aggravation.
Here's what you said:
Now you need to undo the four nuts indicated by the orange arrows. Two of the four nuts have wiring harness clips over the threads. These are a pain to get off. I used a small flat bladed screwdriver to separate the clip from the thread....others have had success using a straightened paperclip bent into a "U" shape.
In this step, if you look down straight into those wiring clips(right down beside the bolts), you will notice two little tabs on each side that are inside the overall plastic wiring clips(these grab the threads on the bolts). Using just a small set of needle nose pliers, you can insert right down beside the bolt and the spread the two tabs that grab the threads(and with fingers on the other hand lifting up), they come of really easy.
Dave
Interestingly enough, I was in there doing the AFE shifter and replacing my parking brake with a totally new one. Jeez, that was fun...........remove passenger seat(actually you can just loosen it, but I took it out for more room), then you take out the ENTIRE center console from the ash tray to the trunk pass through! The instructions I had were in Japanese and were of no real use except for some drawings. I winged it with those and the brake took about 2 hours as I went really slow and was methodical about that. Shifter was only about 35 minutes!
Old Sep 29, 2007 | 04:23 PM
  #189
BigRed's Avatar
w8nkel
^post pics of the park brake!
Old Sep 29, 2007 | 06:42 PM
  #190
Mazurfer's Avatar
Okay, you asked........and I don't want to hijack the thread so here are a few shots with the short shifter installed along with the leather parking brake. I'm not the best at photos so I took a bunch and you'll have to sort them out.
Some were taken with a flash and some were not.
Attached Thumbnails DIY: RP (AFE) Short Shifter install.-shift_brake1.jpg   DIY: RP (AFE) Short Shifter install.-shift_brake2.jpg   DIY: RP (AFE) Short Shifter install.-shift_brake3.jpg   DIY: RP (AFE) Short Shifter install.-shift_brake4.jpg   DIY: RP (AFE) Short Shifter install.-shift_brake5.jpg
Old Sep 29, 2007 | 06:52 PM
  #191
Mazurfer's Avatar
Couple more.
Cleaning day is tomorrow as I kinda made a mess having a good portion of the interior dis-assembled for that brake.
Last one is my current engine bay for the hell of it!
Attached Thumbnails DIY: RP (AFE) Short Shifter install.-shift_brake6.jpg   DIY: RP (AFE) Short Shifter install.-shift_brake7.jpg   DIY: RP (AFE) Short Shifter install.-shift_brake8.jpg   DIY: RP (AFE) Short Shifter install.-shift_brake9.jpg   DIY: RP (AFE) Short Shifter install.-engine_bay1.jpg
Old Sep 29, 2007 | 07:31 PM
  #192
BigRed's Avatar
w8nkel
^oh, I thought you were the one who bought the momo park brake. In any case, nice work. It looks really good! and nice ss too! haha
Edit: why the hell do you have a steering wheel cover?!?!?!?!?!
Old Sep 29, 2007 | 07:51 PM
  #193
Mazurfer's Avatar
Ha Ha.........daughther gave it to me for fathers day........what are you gonna do????? I'm trying to wear it out as fast as I can.
Old Oct 1, 2007 | 10:32 AM
  #194
dozer's Avatar
on his 3rd rx8
i got mine at ssx and had it installed at ssx
Old Oct 1, 2007 | 10:58 AM
  #195
kinchu007's Avatar
Anyone have a pic of the fuzzy green thing?
Old Oct 1, 2007 | 05:08 PM
  #196
kinchu007's Avatar
bump!
Old Oct 2, 2007 | 01:19 PM
  #197
kinchu007's Avatar
bump!
Old Oct 2, 2007 | 03:31 PM
  #198
Mazurfer's Avatar
???????????? Don't get it?
What fuzzy green thing?
Old Oct 2, 2007 | 04:42 PM
  #199
BigRed's Avatar
w8nkel
I think its part of the updated shifter^
Old Oct 2, 2007 | 06:45 PM
  #200
Mazurfer's Avatar
You mean the sort of green fuzzy in this picture on this thread?
https://www.rx8club.com/showthread.p...46790#poststop
This is the supposed sound deadening wadding that comes with the car normally.
People were finding in some cases that taking this out actually reduced the noise when the SS was installed, but I believe that has been corrected in other ways. Mine is still in there and to tell you the truth.......I don't have any cabin noise from the transmission or gearbox. Maybe RP will chime in if he sees this or LittleJohn or Gomez.
