Where is the EPS Motor Relay? Help Pls.
Old May 15, 2006 | 05:36 PM
snkpkp's Avatar
Is the EPS motor relay under the EPS Controller? Or near the motor? I couldnt find it in the workshop manual. It is in the EPS electrical diagram but could not find out where. Any idea guys? Pls advice.
Old May 15, 2006 | 05:44 PM
StealthTL's Avatar
Arrow Not having much luck....
There is no steering "relay".
Power goes direct from the 60 amp fuse on the battery, to the module, then to the motor itself, no relays.
S
Old May 15, 2006 | 05:57 PM
snkpkp's Avatar
what is that relay in the diagram?
whats that relay in the diagram? is it same as the fuse?
Attached Thumbnails Where is the EPS Motor Relay? Help Pls.-snapshot-2006-05-16-04-53-46.jpg
Old May 15, 2006 | 06:26 PM
Ericok's Avatar
Rotary Wanker
According to the circuit diagram, it's inside the EPS. You need a relay because the 60 amp circuit is too big to go thru the ignition switch. The ignition switch trips the relay and energizes the 60 amp circuit to the power steering rack.
bosstin87
Oct 5, 2015 06:52 AM
Luke.s
Sep 30, 2015 05:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
