pcv valve
Old May 13, 2006 | 06:51 PM
mongoose2494's Avatar
pcv valve
I was looking at the vacuum wiring diagram under the hood of the 8 and it shows a pcv valve. I didnt think the 8 had a pcv valve! Does anyone know where this is located? thanks.
Old May 14, 2006 | 11:15 AM
i am pretty sure the 06 has one. as to where i have no idea.
Old May 14, 2006 | 11:27 AM
There is a vastly different crankcase ventilation system in the 2006's. There is a one way valve where the system vents into the manifold. The breather goes from the vent by the oil fill tube to the vacuum ports on the passenger side of the engine. The vent from the TB end goes to the manifold by the oil filter...
Old May 14, 2006 | 11:44 AM
Nemesis8's Avatar
Bigus Rotus
I think Mazda learned something, didn't they
Old May 14, 2006 | 01:14 PM
Well the one that I have is a 2005. If anyone has a 05 you can see it on the diagram under the hood. So the 06's are different from my 05?
Old May 14, 2006 | 01:33 PM
Raptor2k's Avatar
Club Marbles Member
Where did you get the diagram from? Could you show me?
My understanding is that valve has only come in the 2006 model?
Old May 14, 2006 | 02:20 PM
my brother has my digi camera, but it is on the underside of the hood on the left top right beside the emissions info.
Old May 16, 2006 | 08:39 AM
09Factor's Avatar
Original Turbo 'd Auto !!
What would be the benefits from this change in the way the vaccum line are routed.
Old Jun 27, 2006 | 04:53 PM
dgrx8's Avatar
FN GR8
Old Jun 27, 2006 | 07:32 PM
less "milky stuff on the dipstick" threads on the forum is the major benefit to me and my sanity. the othe rbnefit to the 8 owners is less or no oil getting into the intake accordian tube and screwing around with the MAF among other things
Old Sep 6, 2015 | 05:26 PM
WranglerFan's Avatar
Can you post a pic please??? I can't seem to find much info on the lcv valve anywhere. my intake is full of oil and it gets sucked in at high rpms which initially made me think I had a blown oil seal. If I much out and fix it by repair/replace on the pcv it would be amazing but Im new, had the car two days and don't know what I'm looking for.
WranglerFan
Nov 5, 2017 09:35 AM
Evan Gray
Nov 24, 2015 01:00 AM
Willopap
Oct 29, 2015 11:04 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
