How long does original clutch last
Old May 9, 2006 | 08:20 PM
Brettus's Avatar
Boosted Kiwi
Im just about to order some parts for my 8 and am debating getting a lightweight flywheel + a new clutch . I figure I may to have to replace the clutch soon anyway so why not get the flywheel at the same time .
I have 46000 kms on the clock - how long does the clutch generally last ? If mine has heaps left I will delay ordering clutch & flywheel.
From reading the forum these are the parts I've chosen
ACT prolite flywheel + ACT Street clutch
REVI intake + CAI
Interceptor x
Other suggestions welcome.
Old May 9, 2006 | 08:59 PM
cjkim's Avatar
^noob
i think the most obvious answer is: depends how you drive
Old May 9, 2006 | 09:10 PM
mysql101's Avatar
it can last you 15,000 miles, or it can last you 10 years. Depends on how you use it. If you feather the clutch from high rpms at a stand still, you can wear it out really quickly.
Old May 9, 2006 | 09:20 PM
dtorre's Avatar
Ultimate ****** Goderator
My stock clutch lasted 9k miles.....
Old May 9, 2006 | 09:21 PM
samsong's Avatar
The folks are right...it depends a lot on how you drive. My DD (2.2l 4-cyl, not RX8) has 180k mi on original clutch, LA, DC & Boston traffic, w/ some spirited driving. I'm easy on it, though, and minimize slippage, heel/toe regularly.
I would guess with a lower torque engine, you'd see more slippage during standing starts and probably faster clutch wear...but that's just speculation.
If you do the change out, check your clutch specs to see how much its worn and share.
Old May 9, 2006 | 09:23 PM
Im_DANomite's Avatar
I love GOOOLD
unless you have a faulty clutch disc/pressure plate from the factory. other than that, depends on how you drive.
Old May 9, 2006 | 09:59 PM
Brettus's Avatar
Boosted Kiwi
hmmmm - maybe I should just buy the new flywheel + clutch & be done with it . I really am keen to give the car a birthday . If I leave it stock much longer I will tire of it & want something quicker.
samsong's Avatar
Originally Posted by Im_DANomite
unless you have a faulty clutch disc/pressure plate from the factory. ....
good caveat
Old May 9, 2006 | 11:51 PM
Winning 8's Avatar
Hot Pit
average driver with 50/50 is about 90k, some better driver could do 120k, but some stupid kid could do it in 3k.
Old May 10, 2006 | 04:25 AM
Brettus's Avatar
Boosted Kiwi
Thanks for that
Old May 10, 2006 | 06:57 AM
Paul_in_DC's Avatar
Rotary Public
My beater 15-year-old Toyota Celica has 180k miles on it with the original clutch.
Old May 10, 2006 | 08:22 PM
protocol's Avatar
Dumb question but how will you know if your clutch is going. Will it be hard to shift gears.
Just curious. Never had a clutch go on me yet and was wondering so that I will know. I have a 96 Eclipse that has 150k miles and had it for 7 years with no clutch change yet.
Old May 10, 2006 | 08:26 PM
Ericok's Avatar
Rotary Wanker
Usually starts slipping and can't be fixed with an adjustment. You press on the gas, the engine speeds up but the car doesn't.
Old May 10, 2006 | 09:13 PM
Winning 8's Avatar
Hot Pit
Originally Posted by abbid
test if your clutch is going bad:
Put the car in the highest gear while cruising and stomp the accel. If the RPMS jump up, and fall back down when you release accel, you have slippage/failure.
And my clutch failed about 3 weeks ago, and i was unable to get into any gear.
32,500 miles.
what happen???
the spring came lose or what
Old May 10, 2006 | 09:36 PM
demob05's Avatar
Since we're on this subject, I am speculating that the transmission & clutch on the 8 is built, or adjusted for, the high revving capabilities of the Rotary engine. However, how much excessive clutch wear develops from regularly taking the engine to the red line, as recommended for the Renesis, especially when shifting at high RPMs??
Correlation with those who have experienced premature clutch or even transmission wear??
Old May 10, 2006 | 11:34 PM
cjkim's Avatar
^noob
unless you're riding the clutch, i really doubt there would be problem unless you're CONSTANTLY doing it. But by then you'll probably have other problems
Old May 10, 2006 | 11:45 PM
Stock clutch should last the life of your car. It will probably last longer than your engine
with proper care of course.
This applies to everything I guess.
Old May 13, 2006 | 12:46 AM
Nubo's Avatar
Lubricious
I disagree, unless "life of your car" is short also. The clutch is a friction surface and wear item, just like brake pads. I would consider 100,000 mile clutch to have lived a full life.
I suspect the average RX-8 clutch will be less, because it takes more finesse to get good driveability from this car -- meaning the clutch will get feathered more. That is simply the result of a low amount of rotating mass to store energy. A nice heavy iron flywheel would help in that department, but that's not what the car is about.
Old May 13, 2006 | 08:52 AM
That might be true, since 8 is a sports car and its going to get more wear than other maunal-shifting car. but no one has a 8 with over 100K miles yet so we just gotta wait and see.
but what Im talking about is that, most other cars's stock clutch can last the life of the car. 200K+, lots of sports car too. So .... again, we just gotta wait and see.
Old May 13, 2006 | 04:52 PM
Bubba Gnoosh's Avatar
I've had a problem with my clutch since I bought my car 2 years ago. When the car is at idle and I have my foot off the clutch it makes a small whining noise. I had this problem after only having the car for a few months. I brought it to Mazda and they ended up replacing it for me. However, 2 months later I had the same thing happen and when I brought it back they told me I'd have to live with it unless the problem came up in a lot of other 8's. I still have the same noise, but the clutch is fine. The car now has 32K miles.
Has anyone else ever had this problem or ever heard of it?
Old May 13, 2006 | 04:59 PM
^^ thats not the clutch...its normal gear noise for this transmission.
Old May 13, 2006 | 05:58 PM
mysql101's Avatar
Funny that you think the noise went away, because all RX-8's have it. Soon as you let off the clutch you'll near a whirrring noise.
Old May 14, 2006 | 01:58 AM
cjkim's Avatar
^noob
i don't recall my sis' 8 having it when it was brand new.
Old May 14, 2006 | 06:53 PM
I thought it was the clutch because when you let go of the clutch you hear the noise. The meachanic at the dealer thought the same thing and that's why they replaced it. The noise went away for a couple months after, but then returned. I also never heard it when I first bought the car.
PotatoCannon
Sep 6, 2015 11:48 AM
RXeckless
Aug 16, 2015 12:51 PM
akagc
Aug 11, 2015 07:07 PM
MrORAN6E
Jul 24, 2015 09:32 AM
