how do you install clear corners?!?
Old Aug 12, 2003 | 06:38 PM
tribal azn2's Avatar
i got mine today and i cant figure out how to take the stock ones out. help!!!
Old Aug 12, 2003 | 06:48 PM
cueball's Avatar
Someone says how to do it here.
Old Aug 12, 2003 | 07:18 PM
BRx8's Avatar
Ero-sennin
really easy, just use a Phillip's screwdriver and take off 2 of the plastic screws in the wheel well...just turn then and they pretty much snap off...next pull back the black plastic lining, again, really easy...next look under and you'll see that the clear corner is held up by 1 screw...unscrew it and pull the clear corner out...
i opted to use the original white bulb that came with the car as i don't like the orange that came with the corners so i just twisted the bulb out of the original and the new clear corner and replaced it...
took about 10 minutes total...i had to turn the wheel in the opposite direction of the corner i was changing to allow enough room
Old Aug 12, 2003 | 08:07 PM
thx i just installed them. was pretty ez. but for some reason the right one was friggin hard to pop out. that little plastic hook/tab wouldnt come out. i damn near broke the tab trying to get that bitch outta there.
Old Aug 13, 2003 | 08:46 PM
Wing's Avatar
Is this the same method to get to the fender grills? I was looking and was like WTF? It's BLOCKED!
Nice of mazda to put all that plastic there, at least the rocks flying off the tires won't be too loud.
Old Aug 15, 2003 | 09:54 PM
vix8's Avatar
Could somebody post a pic of these installed? I'd like to see how they look...
Old Aug 15, 2003 | 10:34 PM
highspeed8's Avatar
Old Aug 15, 2003 | 11:59 PM
heres mine
http://www.rx8forum.com/showthread.p...5&pagenumber=1
WranglerFan
May 31, 2022 07:51 AM
DVerdeyen
Sep 13, 2015 11:19 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
blkswan
Sep 2, 2015 10:04 PM
