V1 hardwire problem. system?
Old Apr 4, 2006 | 11:13 PM
LiL BenNy's Avatar
Bubblicious? DEF.
So today i was giving my friends a little demo of my JL's but while i was doing that i noticed my V1 started turning off then on then off again.... now im not sure what the cause of this is... would it be from the vibration of the subs?
info: i hardwired the V1 using the blue splice into the map light wire, also i took out the map light lights and replaced them 4 days ago, so maybe the wire had moved around when i poped the map light piece back in... or could this be an electrical problem due to the subs?
any suggestions?
Old Apr 5, 2006 | 01:41 AM
wow,
maybe current draw???
Old Apr 5, 2006 | 06:34 AM
applejax's Avatar
Radar detectors hardly draw any current. While not impossible, I would be very surprised if it was due to a power drain.
With the radar detector on, wiggle the plug. See if the power cycles. If it does, you have a loose plug.
Is there an inline fuse? if so, wiggle the wires and the fuse holder. If the power cycles, you have a bad connection in or on the fuse holder.
Expose the wiring. With the detector on, prod around a bit. Wiggle the wires. If the power cycles, you have a loose connection.
Try that and check all around your map light replacement - make sure everything is solid and neat. Then report back.
Old Apr 5, 2006 | 07:07 AM
momo stereo's Avatar
I would defenitely take the wire under the dash to the ingnition harness for the radar detector...current draw plays a factor in just about everything....besides the fact that mazda puts that small of a wire to the map light expecting that no one would ever tie into it....sounds like an easy fix....make sure your ground is good and go for the ignition harness..
Old Apr 5, 2006 | 08:36 AM
applejax's Avatar
Ack - missed that. Good call, momo.
Check your ground. Check it again.
Oh, and check your ground.
Old Apr 5, 2006 | 08:46 AM
modena's Avatar
Modena
Check the "Phone" wire plug, mine has done it to, reseat the plug, or replace...
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
