my sub idea
Old Mar 21, 2006 | 11:31 PM
fenderlover's Avatar
my sub idea
ok so i've decided i want to get a subwoffer for my 8. and this is what i've come up with
JL Audio
12w7
(contacting JL Audio about amp situation)
box design
thoughts? is it able to become a reality? feasible?
Old Mar 22, 2006 | 06:37 AM
Butch Brown's Avatar
8w7 will do the job with a jl 250/1 amp. The Box will fit better. http://mobile.jlaudio.com/products_e...=1&prod_id=293
Old Mar 22, 2006 | 08:15 AM
gonnahanvan8's Avatar
I don't think either of those boxes will fit. Isn't the throat opening of the Rx only like 11.5 inches?
Old Mar 22, 2006 | 08:53 AM
robbz23's Avatar
I think if you take the plastic off the rear part of the trunk you get about 12 to 13 inches. You will never get that box in the trunk unless you take out the rear seats and the X bracing. Even then i think it will be too tall. I have a 10w6v2 in a 4080 box with a 500/1 that totally kicks. If that isn't good enough for you go with 2 4080boxes on either side. This way with the amp mounted in the recess you will still have most of your trunk space.
Old Mar 22, 2006 | 10:36 AM
Tigerfootball's Avatar
Clemson, NOT Auburn
if you take off the plastic cover and the trunk mechanism then you have a good amount of room, just have to play with the box to get it in. i have a 10W7 in a 1.5cu. ft. ported enclosure in there now and i managed to get it in. But that box you are trying to fit in there is a little too big. i would highly recommend a custom box if you want it to fit in the small trunk.
Old Mar 22, 2006 | 09:22 PM
ok can someone take a pic fo the plastic covering your talking about and tigerfootball got any links to pics?
Old Mar 22, 2006 | 09:26 PM
and what are 4080boxes?
Old Mar 22, 2006 | 09:33 PM
and would it be worth the decrees in sub size for jl audios ported box design. or get a bigger sub but a custom box?
Old Mar 22, 2006 | 09:46 PM
strayer2189's Avatar
thats what i wanted too but i went to 3 different shops all said that with proper box size the best i could hope for is a 10w7 with a custom box...I ordered it last weekend and it should hopefully be in tomorrow and installed friday ill post pictures when finished
Old Mar 23, 2006 | 06:43 AM
dang strayer, I would've sold ya my JL 10W7 cheap. I'm getting an 8W7 instead , I think.
Old Mar 23, 2006 | 12:02 PM
zrmotoring's Avatar
custom make the box
i have a 13w 7
what a pain to but the box inside the trunk, had to put box in first then the subwoofer
Old Mar 23, 2006 | 12:25 PM
staticlag's Avatar
The Professor
that box is 17 inches high, it would be physically impossible to fit it in the rx8.
It is possible to have the 12w7 if you want it, a few guys on here have done it, but your not going to have any trunk space left. And I mean, none.
Old Mar 23, 2006 | 12:58 PM
zrmotoring's Avatar
it is not impossible to fit a 13 w7 its not sitting all the way back and yes there is no space.
also they did a aftermarket radio
also did some simple kicks with morel speaker a 9 inch on the door a 5 and tweet
Old Mar 23, 2006 | 10:23 PM
HOLY CRAP that's alota sub
Old Mar 24, 2006 | 08:09 PM
jobe2433's Avatar
I have a base model rx8 i am wanting to upgrade the system. Can someone tell me if it is possible to add two door speakers and a 10" sub with amp.. without charging the head unit? Any ideas would help...
Old Mar 24, 2006 | 09:11 PM
i don't believe changing the head unit is the problem. the alternator is
Old Mar 25, 2006 | 07:51 PM
i just really liked what jl audio did for the porting on the box i posted. i'm wondering though if all that would fit would be like the 8w7 if i'd be better to get like a 10w7 or 12w7 with a normal box and port it custom
Old Mar 26, 2006 | 04:23 AM
gregg's Avatar
Although I didn't have a base model (I had the BOSE) I wanted the same; some tight bass and more clarity withough wholesale changes to my dash. Here's what I had installed:
Front speakers: JL ZR 6.5 Components --> http://mobile.jlaudio.com/products_c...php?page_id=31
Rear Deck Speakers: JL VR 6x9 coaxials -->http://mobile.jlaudio.com/products_c...hp?comp_id=129
Sub: JL 10 W3v2 -->http://mobile.jlaudio.com/products_s...p?series_id=11
Amp: JL 500/5 --> http://mobile.jlaudio.com/products_amps.php?amp_id=256
OEM Interface: JL Cleansweep --> http://mobile.jlaudio.com/products_c...=1&prod_id=369
Rationale behind choices: I was interested in 'clean', accurate, full range audio. I wanted to keep my OEM headunit & wasn't willing to sacrifice all my trunk space. Lastly, I set a budget of $2,000. I was able to accomplish all of that with these selections, installation with lifetime warranty included.
Knowing The fron components were critical to my desire, I went with JL's flagship ZR series. These provide tremoundous range & clarity and I am extremely pleased with the results. The rear 'filler' speakers were less important and, given the 6x9 size, it was a no-brainer to leverage the JL coax's. Given my previous comment about not giving up all my trunk for a sub-box, the JL 10W3v2 was an optimal choice; it rocks with a small enclosure. I elected to have a box with a downward facing position; this allows the bass to travel a bit prior to entering the cabin but also eliminates the rear facing challenges; visibility and potential damage. The Cleansweep was mandatory due to the factory headunit and it's unbelievable how easy this device makes integration. Lastly, the 500/5 was perfect for this install - plenty of power for the up-front speakers and runs the sub at it's 'optimal' 250w. It also fits perfectly into the aclove in the trunk with a false floor installed above it.
As the saying goes "different strokes for different folks". You need to figure out what's important to you and prioritize. This setup worked for me but I'm sure would be unacceptable for others.
Good luck with your final decision, any way you go will be a significant improvement over where you are today -
92trbolzr
May 18, 2025 09:04 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
