Installing Midpipe
Old Feb 28, 2006 | 06:55 PM
Waz's Avatar
Waz
Installing Midpipe
Hi guys,
I have a used RP midpipe coming with no gaskets or bolts. I also have a Mazdaspeed Cat back exhaust on its way. What extra bits do I need to make it all fit? I am aware I need a dounut gasket which I will source from my local Mazda dealer but what about bolts? Does the MS exhaust come with bolts to bolt onto the midpipe and a gasket for that end? Can I re-use the old bolts connecting the midpipe to the downpipe/manifold?
Thanks,
Waz
Old Feb 28, 2006 | 07:10 PM
chrism's Avatar
Misfit Moderator TnC
i used the stock bolts from the catback and the midpipe on mine....i aslo reused the oem gaskets
Old Feb 28, 2006 | 07:22 PM
Get a new manifold to midpipe gasket...they are less than $10 and the old one will leak if re-used.......the midpipe to exaust gasket can be re-used lots of times...it will be OK
bolts...get some that fit anywhere....Home depot, autoparts store......
Old Feb 28, 2006 | 09:16 PM
StealthTL's Avatar
Red face Tip....
A little tip to make the job much easier - the header/midpipe nuts only undo from the front, the bolt is splined into the cat midpipe piece, you will be there all day!!
You also have to take BOTH the cross-brace pieces off to get the cat out, no way around it.
S
Old Mar 1, 2006 | 06:41 PM
WTF are you talking about Stealth
The RP pipe doesn't have splined studs, it uses regular bolts. I already told you the size; 10mm diameter x 30mm long with nuts and lockwashers, they should be stainless steel, you will need to buy them at someplace that sells fasteners like a hardware store or something, I don't know what the equivalent is over there
I don't think they have Home Depot in Scotland guys ...
Old Mar 1, 2006 | 07:01 PM
StealthTL's Avatar
Arrow Thanks....
Thanks for the nice WTF post, but he has a midpipe "coming", which would imply he has a stock setup, at present.
With splined bolts in the stock cat.
He also wanted to know "can I reuse the bolts to the manifold?", so the answer would be; "not if the originals are stuck in the catpipe", right?
....and the tip about not trying to undo the splined bolts? .....also still applies.
So Mr. TeamRX, bite me.
S
yurcivicsux
192
Sep 12, 2017 10:54 PM
br0wm
Oct 24, 2015 11:06 PM
yapakanichi
Sep 25, 2015 07:55 PM
