"R" Flash( How can you check?)
Old Feb 28, 2006 | 01:07 PM
X-SIN-X's Avatar
Car(04MTRX8) was in shop overnight( repair oil leak from oil pan.) Invoice states "Reprogramed ECM Per bulliten". I called the service department and they tell me the only way they can tell what version I have is by hooking my car back-up (BS I Know). So my question(s) is/are.. How can you check what version of flash you have on your car? And if is infact the "R" what does "R" do for you? I have serched this forum for the answer and also google. Any and all help would be greatly appreciated. Thanks
Old Feb 28, 2006 | 01:32 PM
Brice-RX8's Avatar
One way to check the "R" flash is to completely warm your car to operating temperature and then hold the rpm's above 8500 for 10 seconds and the car should return to idle on it's own while you are still holding the throttle down. The "R" flash was mainly for the car generating too much heat while stationary. Not sure if it will help you, but my car idles alittle rougher since having going from "P" to "R" with the recall. Have fun.
Old Feb 28, 2006 | 02:54 PM
find teh sticky that says "tsb's and recalls" follow the link and then find the 3305g thermal damge recall bulletin. read it. find out if you have had this recall done(call 1800 222 5500 with your vin and ask)
Old Feb 28, 2006 | 03:21 PM
Brice-RX8's Avatar
Or you can do what Zoom said
The TSB is here: http://www.finishlineperformance.com.../pdf/3305G.pdf
Old Mar 1, 2006 | 09:02 AM
X-SIN-X's Avatar
Thanks ver much guys. I will try that.
RevMeHarder
Jun 1, 2026 02:30 PM
LB2739
Jul 9, 2019 02:25 AM
DVerdeyen
Sep 13, 2015 11:19 AM
Irvinb16
Sep 11, 2015 10:27 PM
