Smelly Clutch
Old Feb 12, 2006 | 01:49 PM
NGTMRE's Avatar
Smelly Clutch
Hello All!
new to the site but i have a question. i have a 2005 rx8 in the loosing blue and it has about 2k on it. when my wife drives it she likes to rev the clutch too much before letting it out and you can smell the clutch burn pretty bad. i am trying to get her to not rev it much, but i was wondering if other people have experienced it as well.
the clutch is not slipping or anything but she has done it a few times.
any help if this is common or not. it even happened to me when i was on a steep hill and was backing up it you could smell the clutch burn pretty bad!
thanks!
Old Feb 12, 2006 | 07:53 PM
yiksing's Avatar
the giant tastetickles
If this carries on, say bye bye to your clutch
Old Feb 13, 2006 | 12:15 AM
she is slipping it, that's where the smell is coming from
however my clutch smelled from high rpm drops when it was new and went away with further use
Old Feb 13, 2006 | 01:25 PM
NGTMRE's Avatar
thanks, that is what i was looking for. i'm sure alot of guys around here use high rpm drops etc. and was wondering if it did go away or not.
thanks, alot...
anyone else notice that clutches go out quickly with abuse or do they last long?
Old Feb 13, 2006 | 01:37 PM
NgoRX8's Avatar
you have a loosing blue.? ouch...
I'm at about 2600 now and my clutch smelled before when i was starting at 2000 rpm from a stop. It's gone now.
Old Feb 13, 2006 | 07:14 PM
VOODOO8's Avatar
Hermitage Holdout
Check out other threads on this site regarding clutch longevity. These things were not built to be bulletproof at the factory. Many who like to load up on the clutch are seeing premature failures and are upgrading to after-market parts.
Old Feb 13, 2006 | 07:37 PM
Nubo's Avatar
Lubricious
Not a lot of moving mass in the rotors and flywheel, so it takes more finesse to get the car moving compared to a heavier piston engine. The clutch has a little more work to do. But ya' shouldn't be *burning* it. If it's an intimidating hill, use the parking brake maneuver to get started.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
