Red line transmission fluid= greatest thing since sliced bread
Old Dec 17, 2005 | 11:31 PM
P Daddy's Avatar
Seriously well worth the time and $$$$$.
FInally the transmission feels like a $30K car.
WHy doesn't mazda dump this stuff in all along???
Old Dec 17, 2005 | 11:46 PM
BlueRenesis82's Avatar
Registered Tracker
because most people wont notice the difference and the ones that would will change it anyway?
Old Dec 18, 2005 | 12:01 AM
rotarygod's Avatar
Everone knows I personally use Royal Purple but Redline is very nice stuff. Both have very nice lubricants.
Old Dec 18, 2005 | 12:47 AM
StealthTL's Avatar
Exclamation Redline....
Redline was great in mine....make sure you use the MT90, not the MTL - it is too thin. (I use about two thirds MT90, one third MTL )
S
Old Dec 18, 2005 | 01:32 AM
brillo's Avatar
Go Texas Longhorns!
I use RP but I used the redline in my Mazda6....great stuff.
I can't recommend either RP or redline tranny fluid enough to folks
Old Dec 18, 2005 | 01:41 AM
i think it is the mod that you can feel the most.
Old Dec 18, 2005 | 08:14 PM
Gomez's Avatar
Shifty Bastard.
It isn't a cure all. I'm sure it has improved the shift feel of many of you in snowy climates, but it made absolutely no difference to my car. We see an occasional snowflake once every five years.
I used MT90.....I still have a notchy 1st-2nd shift, a common complaint of many RX-8 owners. This miracle lubricant didn't fix it, athough many said it would.
Old Dec 18, 2005 | 08:21 PM
gomez,
in us req is gl 4 or 5 75w-90 i did the royal purple i think it was gear max that fit the bill. made all the difference in the world.
Old Dec 21, 2005 | 10:24 AM
arghx7's Avatar
I use MT-90 in my FC with 151k miles on the tranny. Still runs strong with no grinding as of late.
Old Dec 21, 2005 | 12:31 PM
AndysAutoSport's Avatar
GT2871R
I tried Redline in my 240SX and it turned to water pretty much, broke down way to quickly. I'm now using Royal Purple and it's been working well thus far.
I used Reline is my '92 Integra as well and I had no problems then, I guess the OS Giken Tranny on my 240SX is not liking Redline or something.
Old Dec 21, 2005 | 12:41 PM
Red Devil's Avatar
I posted this somewhere else recently, but I have Royal Purple in my tranny and differential. I didn't really notice too much of a difference. The shifts didn't feel any smoother. I just think it was good to flush all the break-in shavings out of there.
Old Dec 21, 2005 | 11:04 PM
Purple Helmet's Avatar
I used Royal Purple in my Tranny and Differential, the Tranny was very happy shim was well greased and ready to go!
Old Dec 22, 2005 | 12:05 PM
BRealistic's Avatar
Mine is notchy on ther 1-2 shift when cold. But usually it takes just seconds for it to smooth out again (usually just the 1st shift is overly notchy). Is your notchy all the time, or just when cold? I ask because if it is overly notchy all the time, maybe you are rushing the shift (not letting the rpm drop enough) between shifts? Sometimes taking a fraction of a second off of the shft makes it shift a lot smoother.
Old Dec 22, 2005 | 12:22 PM
Dark8's Avatar
Ride Naked!
With the OEM tranny oil I had trouble getting the 1-2 shift when below 50 degrees. It was really stiff until everything warmed up. With Redline (MT-90 and MTL 50/50 mix) my cold shifting is much easier and warm shifting is a little faster also.
Old Dec 22, 2005 | 01:16 PM
Raevik's Avatar
Ok, so stupid non-techie person question: how hard is it to drain your own tranny fluid and replace it with redline?
I usually do oil and filter changes and tire rotations myself...and that's about it
Old Dec 22, 2005 | 02:56 PM
Dark8's Avatar
Ride Naked!
Easier (for me) then changing the engine oil:
http://www.5cats.org/rx8/trans_diff_refill/
Old Dec 23, 2005 | 02:48 AM
Sendo's Avatar
hey gomez i feel that notchy 1st-2nd shift also, no way to fix that?
Old Dec 23, 2005 | 03:23 AM
Gomez's Avatar
Shifty Bastard.
No mate. Comes standard on every 2nd RX-8.
Old Dec 23, 2005 | 07:16 AM
crossbow's Avatar
If your looking for an alternative to either redline or royalpurple, check out Speciality Formulations MTL-R.
http://specialtyformulations.com/
Most owners who switch from the standard replacements (redline,rp, amsoil) usually end up staying with the SF products.
http://www.bobistheoilguy.com
If you need a few hundred reviews, see the above link.
Old Feb 6, 2007 | 03:27 PM
TheBri's Avatar
Spastic Monkey
I had Redline MT-90 and 75W90 put in my car today.
Damn.
Shifting is vastly improved. Overall the drivetrain just feels smoother. I should have done this a long time ago. Anyone still on the fence about this should just do it.
Old Feb 6, 2007 | 04:42 PM
olddragger's Avatar
RP and redline shockproof
olddragger
Old Apr 5, 2007 | 06:31 PM
otherside's Avatar
I dont care...
Did a search and dug up this old thread.
I put Redline in my transmission and diff yesterday. Man, I should have done this sooner!
Transmission shifts very nicely now! Great stuff...
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
DJclever
Sep 6, 2015 10:51 PM
Bomba
Jul 22, 2015 06:46 AM
