double clutching
Old Sep 23, 2005 | 03:35 PM
xy4xx's Avatar
double clutching
can some one explain to me how double clutching is done? and the benefit of it?
Old Sep 23, 2005 | 03:44 PM
ZoomZoomH's Avatar
Mulligan User
double clutching is usually done when rev matching to downshift.
normally, when you downshift, you press in clutch, shift gear, rev match, release clutch
in a double clutch, you press in clutch, put gear in neutral, clutch out, rev match, clutch in, shift gear, release clutch
main benefit is when done properly, it reduces wear on your synchronizers, which, ironically, are designed so you don't have to double clutch to downshift :o
Old Sep 23, 2005 | 03:47 PM
scarroll's Avatar
Murphy is my copilot.
I use to have to double clutch in my 356b
driving in gear 1
clutch pedal down
shift to neutral
clutch up
clutch down
now shift to 2
You do this because of worn or (lack of) syncros on older trannys. They had no way to
rev match and your are helping it out.
Sounds convoluted, but with practice you can do it quickly.
of course 0-60 in a 356 is somewhere around, oh 15 seconds
Also if you run Naaahhs, you have to double clutch or you will blow your intercooler
Old Sep 23, 2005 | 03:56 PM
epitrochoid's Avatar
Riot Controller
you have to double clutch so you'll look like vin diesel
pretty much when you normally downshift, you don't accelerate the speed of the input shaft in the tranny, it's still spinning at the RPM you were in before in the higher gear..when you gas it in N with the clutch out you bring the speed of the input shaft up so that the next gear engages easier. not really necessary at all anymore, since synchros are pretty tough these days.
Old Sep 23, 2005 | 07:18 PM
pcimino's Avatar
Great explaination halfway down this page:
https://www.rx8club.com/showthread.p...hlight=lockout
Old Sep 23, 2005 | 07:40 PM
Georgia8er's Avatar
I double clutch my tractor, but it doesn't have syncronizers!
Old Sep 23, 2005 | 10:00 PM
totally unnecessary on a modern synchronizer trans
Old Sep 24, 2005 | 02:08 AM
xy4xx's Avatar
thanks guys. always wonder what it meant when vin disesel said it.
Old Sep 25, 2005 | 08:32 PM
mikeschaefer's Avatar
I wanna rock! Rock!
translated it means: "Look at my big muscles, I'm such a retard that drives fast looking cars."
I liked the movie till I saw that part.
I saw the cars they used at NOPI. The eclipse had a carbon fiber sticker on the hood. It may have just been a replica tho
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
