Turbo/Emanage- ECU reset
Old Aug 17, 2005 | 09:10 PM
zoomzoom_8's Avatar
How often do you guys have to reset your ecu by pulling the negative cable to keep your tune? Just wondering.
Also what are the differences of the LTFT and STFT ? Does STFT reverse itself quickly while LT stays put and takes more fuel out?
Chris
Old Aug 18, 2005 | 12:39 AM
Zoli007's Avatar
On a similar note, would it be desireable to pull the plug on your ecu before putting on the greddy and then tuning it?
So that when you tune you start with a "fresh plate" for the factory ecu so when you reset it by yanking the battery cable it restores your original tune.
Very curious also about the above question.
Old Aug 18, 2005 | 09:44 AM
zoomzoom_8's Avatar
I believe the install instructions, (its been a while) tells you like most install instructions to disconnect the negative battery terminal before installing the kit in the 8. My problem has been now after I am running the turbo, my mixture starts getting lean after a few days under boost and I have to reset the ecu. ECU has to be tampering with it somewhere, somehow!
Old Aug 18, 2005 | 12:37 PM
Zoli007's Avatar
I apologoze if its a dumb question but just trying to understand here.
So once you notice it starting to run lean, you reset the battery and the car runs fine again for a few days. It will starts to adapt again so you just reset again?
Do you have to enter the code for the radio to work each time?
Seems annoying but it also seems like it will work until I can see if the Interceptor-X does what its supposed to and I can collect the $.
Old Aug 18, 2005 | 02:56 PM
r0tor's Avatar
when i'm tuning my NA setup i don't reset the computer. I like to let the computer settle out to where it wants to and then tune on top of that.
Old Aug 18, 2005 | 03:25 PM
zoomzoom_8's Avatar
Yea, thats right and if you do not notice it, the car will tell you, cause them the knock sensor retards timing and the car basically lurches and stalls. That is what happened the first time, now I am always watching the a/f gauge. I don't have a code on my radio so no entering code here. Do have to reset presets, time, etc though.
Old Aug 18, 2005 | 05:17 PM
Zoli007's Avatar
Thumbs up
Thanks for the helpful reply
cliffkemp
Dec 24, 2024 10:48 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
