air filter
Old Jul 11, 2005 | 12:11 PM
Abracadabra's Avatar
air filter
I can't seem to get to the air filter easily. I loosened the clamp around the flex hose, poped the 2 clips, but found it very difficult to tilt the air cleaner cover enough to get at the filter. It would seem that the cover should come free to expose the filter but it barely tilts away. What's the secret? thanks, Craig
Old Jul 11, 2005 | 01:59 PM
NavyDood's Avatar
Who is this Navy guy?
DIY Air Filter
Old Jul 11, 2005 | 06:20 PM
Go48's Avatar
You don't need to remove any clamps. Push on the front of the airbox until the 2 posts pop out of the rubber grommets then lift up slightly on the box to free it up from the 2 lower rubber grommets. The "accordian-like" pipe will collapse enough to allow the airbox to be pushed backwards.
When reinstalling the airbox, make sure that the lower rubber grommets are in place before pushing the lower posts down into them. If you have accidentally popped the grommets out, locate them and reinstall them before starting the car.
Old Jul 11, 2005 | 06:50 PM
thanks
Thank you both.....that did the trick. amazing!
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Danield97
Sep 30, 2015 05:59 PM
drlubell
Sep 26, 2015 11:58 PM
