HKS Speed Limit Defencer
Old Dec 16, 2004 | 12:50 PM
shelleys_man_06's Avatar
Not anymore
Question HKS Speed Limit Defencer
http://translate.google.com/translat...peed/sld3.html
Anyone else ever hear of these things? Is this a fuel cut defencer? Is defencer a word?
Old Dec 16, 2004 | 02:25 PM
Genom's Avatar
Not so Super right now
Jap RX-8's are speed limited rather low (200KMH I think it was) and this basically lets you get past that limit. You can fidn them for tons of import cars to remove the top speed limiters.
Old Dec 16, 2004 | 04:21 PM
epitrochoid's Avatar
Riot Controller
from the looks of that broken translation, it sounds like it just modifies the speed sensor signals on the CAN bus. if not done properly, this may affect DSC, and due to PCM and equipment differences between JDM and US models, it may not work at all.
Old Dec 16, 2004 | 04:28 PM
Magic8's Avatar
Mazda Mole
Originally Posted by shelleys_man_06
Is defencer a word?
Welcome to the world of Japanese English...
Old Dec 16, 2004 | 05:14 PM
RXE16T's Avatar
'RX-EIGHT'
You mean the mystical dialect known as 'Japlish'
Old Dec 16, 2004 | 06:37 PM
Not anymore
I doubt it'll work for U.S. PCMs.
I was randomly wandering HKS' webpage for RX-8 stuff, and this is all I could find.
OT: Whatever happened to HKS' supposed turbo kit that was in development? Vaporware?
Old Dec 16, 2004 | 06:40 PM
Riot Controller
the guys at their SEMA booth didn't know anything about it. we all know what that means, especially when their major competitors there have installed kits at the show.
Old Dec 16, 2004 | 06:43 PM
rotarygod's Avatar
US RX-8's are top speed limited by power, not the ecu.
Old Dec 16, 2004 | 07:13 PM
RXE16T's Avatar
'RX-EIGHT'
Found this on the website of HKS USA:
"FCD (Fuel Cut Defencer)
The HKS FCD is an electronic device developed to properly raise the factory fuel cut level on factory turbocharged vehicles. As modifications are made to optimize engine performance, the factory fuel cut is often triggered by higher boost levels which activate a fuel delivery cut-off as a failsafe procedure. Symptoms of fuel cut are hesitation, bogging, and/or illumination of diagnostic indicators.
The electronic signal from the FCD will raise the fuel cut level to accommodate for the additional boost without triggering fuel cut and/or an engine diagnostic light. The FCD installation is designed to be easily integrated with the VPC/F-CON or factory ECU harness."
http://www.hksusa.com/products/more.asp?id=683
"SLD (Speed Limit Defencer)
The HKS SLD is an electronic device designed to eliminate a vehicle’s factory speed limiter. When competing on the drag strip or a circuit track, the factory speed limiter can hinder a vehicle’s performance. The HKS SLD is available in two versions: Type-1 is generally for vehicles equipped with a manual transmission and Type-2 is generally for vehicles with automatic transmissions."
http://www.hksusa.com/products/?id=781&rsku=
Hope that answers the questions in your original post, shelleys_man_06.
Old Dec 19, 2004 | 10:15 AM
Neon's Avatar
Black Ace
All the JDM bros want them - SLDs
We are all limited to 187Km/h. And the dumbest thing is the damn gadget is not cheap. $500SD about 300+USD. Dat's y we r all waiting for the next available ECU dat will most probably have this function + power gains instead of just this DEFENCER. Real stoopid!
Old Dec 19, 2004 | 11:07 AM
mysql101's Avatar
Actually, it's called Engrish
Try this site: http://www.engrish.com/
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
Rupanrx
Sep 4, 2015 06:44 AM
