Which direction should the sub point?
Old Nov 26, 2004 | 02:07 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
This weekend I am going to build a custom box for two 10's. I have notice in my last car the if the sub was faced forward it made cleaner bass, however, less of it. When faced up... it made little bass and when faced back it just rattled the trunk. So my question is which direction should the sub point? If I could know before I build the box... well, it would make my life a lot easier. Thanks in advance.
Old Nov 26, 2004 | 12:21 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
In my experiencemaking it face the trunk (back) makes ithit the hardest and you can always dynomat the trunk if the rattle annoys you
Old Nov 26, 2004 | 02:29 PM
I am building a seal box (0.6 cubic feet each chamber) and using two Infinity Perfect 10.1 with a Polk Momo 500.1 amp. I've built a few boxes in my life time, so I should be okay in that area.
Old Nov 26, 2004 | 02:48 PM
truemagellen's Avatar
Attracts tree branches
Djseto congrats again on your new 8!
During black friday deals I picked up a low end sub setup that will probably be fired backward since it is ported...also I got around a 500w amp as well
really this box will be more for show and I will set it up so it can be removed easily when I need trunk space
I'm glad you guys are discussing this even though it has been brought up before, I'll test mine in different positions and give you guys an update on how it goes
I've heard dynamat costs and arm and a leg at retail places but my friend who works at a pawn shop (shady don't ask) can get it for like $12-$15 a square foot brand new (not pawned :D stuff) if I need to resort to it I will
later
Old Nov 27, 2004 | 12:50 AM
MrWigggles's Avatar
Typically you don't want the subs to face right into the seats unless they are paper thin. This is less of a concern with the RX-8 because even with the passthrough in place I would estimate that there is still a way for bass energy to get through.
Facing backwards works well; however, you do get some horn-loading (i.e. "1/8th space corner loaded") type effects by putting it in the very back corner of the trunk and shooting it sideways. https://www.rx8club.com/showpost.php...3&postcount=81
Overall, in my opinion the top ways to fire subs into a car are:
1. Straight into the cabin (i.e. through the pass through section): A+
2. Corner loaded (if possible): A
3. Against the rear seats firing back: A-
4. Any random placement: B
5. Firing straight into the rear seats (generally): D
-Mr. Wigggles
Old Nov 27, 2004 | 11:46 AM
irfan's Avatar
ElusiveSasquatch
ive got 1 perfect 10.1s with a 600watt jbl amp, in a box facing directly into the seats. the reason i chose this is because it saves me the most space, i built the box to the same angle as the back seats (find the plans in a thread on here, i cant remember who made them but they are great). i mounted the amp on the side of the box so its a clean looking install and no one can see the subs or amp. also i dont have to worry about the subs getting damaged from objects in the trunk, and honestly, they hit very hard. enough to make ur nostrils vibrate, which is enough for me. sometime when i have time i'll flip it around and face them back to see if they sounds better or worse.
Old Nov 29, 2004 | 01:44 AM
box is built, check it out. https://www.rx8club.com/series-i-interior-audio-electronics-24/new-sub-install-46086/
Old Dec 1, 2004 | 06:13 PM
LMCCAL05's Avatar
irfan got any pics.....
Old Dec 2, 2004 | 03:17 PM
irfan's Avatar
ElusiveSasquatch
ya i'll take some maybe tomorrow or this weekend
Hunterkelley24
Jun 14, 2022 08:32 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
bosstin87
Oct 5, 2015 06:52 AM
