6 disc problems with ejecting and loading
Old Nov 16, 2004 | 02:47 AM
SantozRx8's Avatar
Raccoons SUCK!
did a search found nothing on what im experiencing.
got the 6 disc changer and sometimes the cd will get stuck when i try and eject it then i just stick a cd in there and wiggle and it'll come out and when i go to load another cd in there it wont accept it.... iono what the deal is but i have to shut the car off and back on to try and load a cd again once it rejected the previous attempt
anyone know what might be goin on?
Old Nov 16, 2004 | 06:48 AM
flatso's Avatar
I'm Tantalizing
sounds like it's broke. Take to the dealer for a replacement.
Old Nov 16, 2004 | 01:04 PM
kwescott's Avatar
One ball, corner pocket
When you press the load button, does the indicator "wait" come up? This should flash for about 2-3 seconds and then it will indicate "load". I have had no problems with my unit, either loading or ejecting. I have the 6-disc changer, but it was in the car when I purchased it. I had to read the manual on how to use it first.
Old Nov 16, 2004 | 02:45 PM
SantozRx8's Avatar
Raccoons SUCK!
yeah it flashes wait and then tells me to put in the cd and it wont pull it in... then it just shuts off and only the radio works until i restart the car i think ill just take it to the dealer fo r a new one.... ive read that you could just ask for instructions so you could install the new unit yourself..is that true??
Old Nov 17, 2004 | 11:33 AM
kwescott's Avatar
sounds like you have a faulty unit. If it is still under warranty you shouldn't have to worry about installing it yourself. They'll do it for you at no charge. But if this isn't, you could get instructions on how to replace it, it looks pretty simple. The hardest is removing the dash peices, but otherwise it should be a simple plug out the old and plug in the new. You may want to check the audio portions of this site for additional info. I have received other parts from Mazda that come with pretty extensive instructions. I didn't have any problems doing it myself.
Old Nov 17, 2004 | 01:25 PM
mikeb's Avatar
100% Italian
contact the dealer
something is totally wrong
I have had no problems with mine for over a year
sorry man
Old Nov 17, 2004 | 08:14 PM
SantozRx8's Avatar
Raccoons SUCK!
thanks guys im gonna call the dealer tomorrow
RevMeHarder
Jun 1, 2026 02:30 PM
Brettus
46
Apr 19, 2024 06:28 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Vedivan1
Sep 20, 2015 04:39 PM
Vedivan1
Sep 18, 2015 12:39 PM
