EVAP Pump gone bad
Old Sep 13, 2004 | 09:52 AM
mootz's Avatar
EVAP Pump gone bad
Has anyone else had their EVAP pump go bad. The dreaded yellow light came on this weekend. Just waiting for the parts to come in now. Just wandering how common the problem is?
-Mootz
Old Sep 13, 2004 | 11:52 PM
B-Nez's Avatar
First I've heard of it since Aug 2002...
Old Sep 14, 2004 | 02:02 PM
first one ive heard of also.
Old Sep 22, 2004 | 04:37 PM
army_rx8's Avatar
X-Sapper
my evap pump went bad about 2 weeks ago....the dealership replaced the pump and all hoses going to it. My check engine light has been coming on for about 5 months (about 7-8 times in that time span). the dealership always reset the ecu and checked again and the evap leak code went away..so they said i had to screw the gas cap on...um..yea i'm not a moron...so after it came on for 5 months the pump finaly went bad...and with it all the hoses...4 day install on all parts (they had to wait for some of the hoses)..but no biggie..it was all covered and i haven't had anymore problems.
As a side note the check engine light came on after about 2 1/2 duty cycles (a lill more than 2 fill ups). But other than me i haven't heard of anyone else with this problem. Just anouther perk of owning a first production car
Old Mar 18, 2005 | 05:21 PM
sdcrx8's Avatar
Evap system problem....
Jan 14.....I had a CEL in which they reflashed the computer.
Jan 25.....CEL, same code(small evap leak). replaced evap pump. replacement pump was bad. another one put on.
Feb 4......CEL (large evap leak). was not the gas cap. I checked the cap after filling tank and again when light came on. It was tight.
3/14......CEL (large evap leak). Still same code. in process of replacing pump again along with the filter. This under the advise of Mazda tech. But would not guarentee that it would fix.
getting very frustrating
Also told condensation in crankcase is "normal", no fix. I'm sorry but no matter what anybody says water in oil is not normal.
two days ago discovered two silver dollar sized oil spots on floor of garage about 8-10 inches apart
Old Mar 18, 2005 | 05:34 PM
msrecant's Avatar
Hubble has been saved!
mootz, armt_rx8 and sdcrx8,
What vintage are your 8s (when did you get them) and how many miles do you have on them now? I'm thinking this might be an age/mileage issue.
Old Mar 18, 2005 | 05:41 PM
sdcrx8's Avatar
purchased in Nov. 04. It is a 05 with 4k miles
Old Mar 18, 2005 | 08:56 PM
army_rx8's Avatar
X-Sapper
purchased in aug 03 build date is july 03. since my evap system's been replaced i'm had no more problems with cel's :D knock on wood
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
DVerdeyen
Sep 29, 2015 10:31 PM
Shumster
Sep 10, 2015 11:05 PM
