somethings not right...
Old Aug 26, 2004 | 11:26 AM
Dongwhi's Avatar
Question somethings not right...
I had Tein Stech springs installed to my car... but the car doesn´t seem to have
been lowered much compared to the pics I see of other cars lowered by the same
springs or other springs.... I had my bodyshop install them when they were working
on my car after an accident... the bodyshop is mostly into fixing cars and not modding cars..
could they have installed the springs incorrectly?
the ride of the car became a little harder after the install but that's because of the spring rate i suppose...
if they had installed it incorrectly won't I have problems when driving?
I haven't measured the distance from the ground to the wheel wells...
and I'm out of the country now so I won't be able to measure it until the weekend..
it's just that I spent money on the springs and to get them installed, but I don't see
much of a difference before and after....
anyone else had this kind of problems before?
any input will be appreciated.... thank you in advance...
Old Aug 26, 2004 | 11:33 AM
8is>enuff's Avatar
Bland
You should notice that your car is lower, but depending on how long ago they were installed, I believe you need to give it time to settle.
Old Aug 26, 2004 | 02:06 PM
brothervoodoo's Avatar
RainMan is Back
Did they put a "load" on the car before tightening the control arms and links, etc..?
Old Aug 26, 2004 | 03:07 PM
sup3rbad's Avatar
Numbah 1 in da hood... G
That might be the cause, I noticed an almost half inch drop when I loosened my control arms and retightened them with the car off the jack stands. You should also give the springs some time to settle.
Old Aug 26, 2004 | 04:59 PM
Dongwhi's Avatar
thank you for your thoughts.
I think it should have settled by now since I put about 1000 miles on the springs.
I think what brothervoodoo said might be the problem...
I´ll have to check it out...
thanks again for your inputs.
Old Aug 26, 2004 | 07:58 PM
rotaryred's Avatar
I'm having the same problem with my s-techs whats the deal with these springs the car isn't much lower at all????
Old Aug 27, 2004 | 12:11 AM
IZoomZoomI's Avatar
Boost needed
hmm had mine for 2500+ miles im having the same issue with the back springs but not the front. I did load the springs while they were untightened. My back is now sitting higher than ever stock height.
Old Aug 27, 2004 | 09:30 AM
Dongwhi's Avatar
maybe the bodyshop didn't cut the bumpstops?
it seems like according to the thread below, you need to cut them....
cutting them will lower the car a little more?
Old Aug 27, 2004 | 03:02 PM
Kel Rx8's Avatar
if your not 1st your last
post a pix
then i will dig up a pix of mine here i posted months ago.
Old Aug 30, 2004 | 01:00 PM
Dongwhi's Avatar
I'll try to post a pic after i get a chance to take one...
kinda busy registering for classes and getting the waitlists taken care of...
thanks
Old Aug 30, 2004 | 01:18 PM
IZoomZoomI's Avatar
Boost needed
bumpstops won't affect the drop, just the ride quality. I think you should listen to brothervoodoo, untighten the control arms drop the car for a lil while retighten. A few others had this problem b/c they neglect this. So try it out when you have time this is likely the solution to your problem.
cliffkemp
Dec 24, 2024 10:48 AM
Digitz0070
55
Jul 25, 2017 08:40 PM
crimson809
Aug 14, 2016 10:03 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
