DIY: Remove Alternator
Old Jun 26, 2011 | 05:31 PM
Jon316G's Avatar
Grasshopper
Appears that we needed a DIY for removing the alternator because some feel that you need to remove the alternator bracket.
It would make it easier, but isn't necessary.
1) Disconnect and remove battery along with the upper battery tray to gain some room (and to prevent electrocution).
The pic below I have the whole battery box removed, but its not required (I was working on something else too).
DIY: Remove Alternator-alternator-remove-1-.jpg
2) Disconnect the harness to the alternator.
DIY: Remove Alternator-alternator-remove-2-.jpg
3) Open covers to expose the wire and nut, then remove nut and wire from housing.
DIY: Remove Alternator-alternator-remove-3-.jpg
4) Completely remove tension bolt and the piece that runs through the alternator bracket (piece the tension bolt threads through).
DIY: Remove Alternator-alternator-remove-4-.jpg
5) Remove bolt that secures alternator to the engine.
DIY: Remove Alternator-alternator-remove-5-.jpg
Old Jun 26, 2011 | 05:32 PM
Jon316G's Avatar
Grasshopper
6) Removing the intake's accordion tube will make things easier.
Remove all hoses going to the accordion tube, loosen the clamps, and remove it.
Also, remove the electrical connector to the throttle body.
DIY: Remove Alternator-alternator-remove-6-.jpg
7) This is where having the accordion tube out makes it easier...
Use a large flat-head screwdriver to lift the alternator out.
You'll need to "rock" the alternator while lifting it.
It'll take some time (few minutes), just be patient and you'll see it begin to lift out.
DIY: Remove Alternator-alternator-remove-7-.jpg
Some good FYI provided by TeamRX8:
Originally Posted by TeamRX8
The reason you have to rock it back and forth to get it out is because there is a sliding bushing in the lower mount that cinches up against the lower alternator mounting tab.
Once you get it to slide back a bit the alternator lifts right out.
When you tighten down the bottom mount bolt on the re-install it cinches back in place again.
8) Now rotate the alternator counter-clockwise (if facing from the front) and then rotate sideways.
The alternator will come out forward and under the bracket.
DIY: Remove Alternator-alternator-remove-8-.jpg
9) Enjoy a beer since you managed to get the alternator out without removing the bracket.
DIY: Remove Alternator-alternator-remove-9-.jpg
Just re-install in reverse order!
Old Jun 26, 2011 | 05:44 PM
it's probably worth noting that the reason you have to rock it back and forth to get it out is because there is a sliding bushing in the lower mount that cinches up against the lower alternator mounting tab. Once you get it to slide back a bit the alternator lifts right out. When you tighten down the bottom mount bolt on the re-install it cinches back in place again.
Old Jun 26, 2011 | 05:50 PM
Jon316G's Avatar
Grasshopper
Thanks Team.... I added your quote to the DIY.
Even though I'm sure people would have seen your post right after the DIY, I wanted to give you a little credit for the suggestion
Old Nov 21, 2011 | 02:43 PM
05shinka's Avatar
Bad Company, Till I Die
Nice, I thought I was going to have to buy a set of metric open end wrenches until I found this.
Old May 2, 2014 | 10:52 PM
Cesarcigala's Avatar
Rotary Vegas
I know it is an old thread but I couldn't find any information on how to remove the nut from the alternator's pulley. I want to change to pulley while I am also changing the alternator. the pulley spins along with the nut. I tried a strap wrench to hold the pulley but I am not sure if the nut comes off clockwise or counter-clockwise. I tried both with no luck. I don't wanna try too hard and damage the bearing.
Old May 3, 2014 | 06:25 AM
Carbon8's Avatar
Yank My Wankel
Have to use an impact gun.
Old May 3, 2014 | 10:45 AM
https://www.rx8club.com/series-i-aft...rnator-133801/
Old Aug 22, 2015 | 04:15 PM
Street rx8 Racing's Avatar
I have done all of this but when I go to remove my wire harness it will not come out and the plastic around the wires just keep breaking when I try to remove it so any suggestions or is there something I'm doing wrong?
Old Jan 10, 2016 | 05:34 PM
Art Hazebrook's Avatar
Well that was the fight of my life, but I did prevail!! Removed the air box plenum and resorted to lifting the alternator straight up then spinning it clockwise (towards the drivers side). I will be getting hold of a 10-12 inch long 12mm open end to remove the bracket during the installation Thanks for having this DIY!!!
Old Jan 16, 2016 | 11:42 AM
Follow on to alternator removal: the new one went in twice as fast as compared to the removal process, and with much less effort!! The best part was not having to remove the belt adjustment bracket !!
Old Feb 23, 2017 | 05:53 PM
Tracey Fuller's Avatar
What tools do I need to replace the
Alternator?
Old Jun 7, 2017 | 12:44 AM
Reoze's Avatar
So I tried this I've been kicking myself in the ***** for it ever since. In my opinion it was *much* easier to just remove the bracket last time I did it. Probably takes a total of 5-10 minutes, and removes a LOT of the headache from this process.
I do appreciate the work that went into writing this up though.
Old Dec 11, 2018 | 11:08 AM
Lori Miller Howell's Avatar
im having the same issue as well
Old Aug 26, 2020 | 02:07 PM
ThomasThicc's Avatar
Attachment 173691
Attachment 173692
Attachment 173693
Attachment 173694
Attachment 173695
can't quite seem to disconnect the harness in "2)" is there a disconnect clip?
Old Aug 26, 2020 | 07:40 PM
it’s sort of self capturing and does have a tab that needs to be depressed to release it, otherwise don’t be shy trying to pull it out.
Old Aug 27, 2020 | 05:41 PM
What tab? That's the problem is I see no tab system or anything! Can you please send a picture or a diagram or something? Been stuck on it for 2 days cannot figure out how to get it out.
Old Aug 28, 2020 | 06:25 AM
it must be broken off, in that case take a small flat-head screwdriver and force it out then
Old Aug 28, 2020 | 05:24 PM
I was looking for a spare plug I have in my electrical bin but I must have used it on my son's FD.
It pretty much looks like the coil connector just bigger...
Old Aug 28, 2020 | 05:33 PM
is there a close up picture available of the harness connection on picture 2? I cannot figure out how to take it off! I see no tab or anything and i've tried forcing it out. I really don't wanna break it.
Old Aug 28, 2020 | 05:56 PM
If you look at picture #4 you can see the tab peeking out a bit from underneath. My car isn't at the house so I can't take a pic for you
Push the tab toward the center and lever up on the connector. Be careful because it is easy to pull the wires out they are small
Old Aug 29, 2020 | 04:54 AM
sorry, found and marked this up the other day and meant to post it, but got sidetracked. So there’s one on the main cover that exposes the nut and the smaller one on the side that releases the cable. I usually just take the main one loose and pull the cover off with the wire, but it can be a bit tricky to get the cover off the alternator post but because it’s has some captive barbs on the underside
I think you mean the other one off to the side though. I was looking for that when I got off onto something else. Let me look around.
Old Aug 29, 2020 | 05:14 AM
here it is, tab is in the rear, which if you look at the socket opening in the pic above you can see where the tab locks into, hth
Old Aug 29, 2020 | 09:38 AM
I just woke up, went to it, and kinda pulled it off with the tab. No clue how the hell I did it, but it worked. Just slipped off, like it was supposed. Still don't know how it works. I'm just an ape I guess.
Old Aug 29, 2020 | 06:54 PM
it’s ok, we’ve all been there. My apology for not having helped you get there sooner.
the tab may be broken; which it’s a bit of a snug, tight fit even without the tab, or sometimes those tabs are just difficult. It’s always best to push the connector in first with pushing on the tab to help release it, then pull the connector out.
