Anyone with BHR ignition in NZ?
Old Feb 2, 2011 | 04:01 AM
scotttnz's Avatar
ST8 OF PLAY
I'm new to rx8s and rotaries in general, but from what I have been reading on here and elsewhere new coils, leads, and plugs are probably a good idea some time soon. I am thinking of going with BHR and am wondering if any kiwis have imported them? What are your experiences with them? Is there a local alternative? Or other recommendations?
Old Feb 7, 2011 | 03:00 PM
Rotaman's Avatar
NZ
Hi There
I have imported a few things from BHR and have found Charles great to deal with, but I think you will find that by the time you look at getting their ignition system to NZ, it will end up being very expensive.
I made my own version using the same type of coils which are GMC Yukon coils.
Commonly know as D-585's.
I had to import the coils, as they are not a common coil over here and fairly common in the US.
Then I made up my own bracket to hold them which mounts to the original coil mounting bracket, this is so it is easy to put everything back to standard if I want to.
The spark plug wires are Magnacor which I also made up myself. The only differcult bit was finding plugs to connect to the factory coil plug wiring.
It would have been easier to hard wire new plugs into the factory wiring, but that would have meant I could not easily put it all back to standard.
Anyway if you are going to the RX8 Mystery tour day out, I can show you what it looks like if you are interested.
Rotaman
Old Feb 7, 2011 | 11:47 PM
scotttnz's Avatar
ST8 OF PLAY
Well I need to save up untill next month, but current thinking is to go with stock coils, and plugs, and upgraded leads.
I came acros these in my search to. They are using bosch coils of some kind. Expensive but!
http://www.promaz.com.au/rx8_na.php
Old Feb 8, 2011 | 11:52 AM
scotttnz's Avatar
ST8 OF PLAY
That kit contains an external igniter module of some kind, which has posed problems in the past for RX-8 owners. Be careful.
I'm not planning on buying that kit, just thought it was interesting that someone is doing something different.
Old Feb 8, 2011 | 12:51 PM
bse50's Avatar
#50
they are actually copying an older system
Old Feb 9, 2011 | 12:59 PM
bse50's Avatar
#50
There are so many hacks in the automotive industries that they don't even know who to copy!
Old Feb 9, 2011 | 01:21 PM
Brettus's Avatar
Boosted Kiwi
I have a similar system sitting in my gge gathering dust ......
Old May 4, 2011 | 02:00 PM
pottsy's Avatar
Scott did you end up getting the coils?
Old May 4, 2011 | 10:00 PM
scotttnz's Avatar
ST8 OF PLAY
NO, I decided to send my car to the panel beaters instead
cliffkemp
Dec 24, 2024 10:48 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
olyrx7
Oct 26, 2015 09:23 AM
Quiggs321
Sep 30, 2015 05:34 PM
