motormounts
Old 12-26-2010, 05:08 PM
pledpled12's Avatar
motormounts
hey i was just wondering if it was necessary to change all the motor mounts if i was to get new ones. Is it only one motor mount (right side under exhaust) that wears out mostly that causes vibration?
i cant find any on ebay and mazmart has the single right mm for 130, its kinda expensive for me because im a student and barely work, only a few hours a weekend
if i replaced just the right one would that help mostly?
Old 12-26-2010, 06:05 PM
invasion08's Avatar
Yes, if money is tight and only your right side motor mount is bad just replacing just the right motor mount will be fine.
Old 12-26-2010, 06:26 PM
pledpled12's Avatar
see the thing is that i dont know if its just my right motor mount
as of now theres a blizzard and my car is kinda buried haha so i cant check right now
but is that usually the case? that only the right side was the one that wore out and caused the idle vibration?
Old 12-26-2010, 06:27 PM
pledpled12's Avatar
and anyone have any tips on how to use the jack and block of wood method to lift the engine to access each motor mount (no cherry picker)
Old 12-28-2010, 06:31 PM
4FragileHearts&WeakLimbs
tonedef's Avatar
If you have not purchased the mounts I'd like to suggest buying from Finish Line.
http://www.finishlineperformance.com...ction=0&page=2
You'd be hard pressed to find anything cheaper. I got my fuel pump there much lower compared to other web sites. They are quick to ship as well.
Old 12-28-2010, 06:45 PM
Power!!
shaunv74's Avatar
If money is tight you should verify what's bad and what's not before you go buying parts.
Old 01-02-2011, 05:48 AM
Blacknightz's Avatar
second this...
FizzvisVR
05-02-2011 10:51 AM
Faria
04-12-2011 10:57 AM
Kane
583
02-08-2010 01:53 PM
Eatsomerice
12-23-2007 12:21 PM
Quick Reply: motormounts
