Stinksause Attempts tunning
Old Jul 23, 2010 | 11:29 PM
stinksause's Avatar
The Stink w.o The Sause
So I finally got my cobb and made the following changes to the stock map:
Fan temp A at 200
Fan temp B at 210
P0420 CEL hidden
I drove around for a bit to set my fuel trims and today I made the following logs to calibrate my MAF
first 2 are cruises
last one is idle followed by a 1st gear pull
My LTFT is a bit over 6% across the board
so I multiplied my MAF by 1.03 across the board.
I am stock up front, with a midpipe and catback out back
Discuss, gimme suggestions etc?
I fucked up the #1 and #3 datalogs when saving them ....
File Type: zip
stinksause's Avatar
reserved
Old Jul 23, 2010 | 11:30 PM
stinksause's Avatar
reserved.
Old Jul 23, 2010 | 11:31 PM
stinksause's Avatar
reserved..
Old Jul 24, 2010 | 07:58 AM
Congrats, it's not that difficult to do.
Old Jul 24, 2010 | 01:13 PM
arghx7's Avatar
Wait, you rescaled your MAF on a stock intake?
Old Jul 24, 2010 | 10:16 PM
stinksause's Avatar
yeah .... something weird happened tho .... I got a crank position CEL when I flashed to the new map .... I spent half the day trying to figure it out until I flashed back to the last one ... anyone else experience this?
Old Jul 24, 2010 | 11:02 PM
Mawnee's Avatar
I divide by zero
yes, if you skew your maf too far you'll get a crank sensor code.
Old Jul 24, 2010 | 11:05 PM
stinksause's Avatar
3% is too far??? Does it go away after a drive cycle?
Old Jul 25, 2010 | 09:16 AM
arghx7's Avatar
What the heck is the point of rescaling the MAF on a completely stock intake? If the trims aren't near zero, so what. It's well within the design parameters that Mazda established. Fuel trims change with the weather, that's ok if the underlying calibration is ok and there are no mechanical problems.
Old Jul 25, 2010 | 09:26 AM
Kane's Avatar
The idea is to minimize it some so you can run more aggressive in open loop. But the injectors also need to be scaled, so the whole thing can become a chase your tail experience really fast.
Old Jul 26, 2010 | 12:40 PM
stinksause's Avatar
so is there ANY way to scale it without throwing that CEL?
Old Jul 26, 2010 | 12:49 PM
Kane's Avatar
Leave the first two cells alone (the far left), they stay stock, scale the rest and you'll be fine.
Old Jul 26, 2010 | 01:28 PM
stinksause's Avatar
oh okay ... thanks ... that's idle anyhow I guess
Old Jul 27, 2010 | 07:45 PM
MazdaManiac's Avatar
Leave the bottom-most MAF scale cell alone (as we discussed in the seminar).
Moving it can cause an ESS cell on some models.
The OE intake can be off by as much as 12%.
Like you have any clue.
Old Aug 9, 2010 | 08:19 PM
More than you think, apparently.
So anyway, I popped in to see how the tunaing project was going. Catch anything yet?
Old Aug 9, 2010 | 10:40 PM
stinksause's Avatar
thanks for checking in .... my cobb has an overheating issue and I sent it out for maintenance ... It also will refuse to connect live to ATR ... so I will be back when I receive it
Old Aug 10, 2010 | 10:54 AM
Think? You demonstrated this fundamental ignorance. I don't have to think anything about it for it to be apparent.
Old Aug 10, 2010 | 01:08 PM
It's apparent that you're doing a pretty good job of this yourself.
Old Aug 10, 2010 | 01:44 PM
Well, yeah. Gutting other people's ill-founded remarks is my specialty.
Old Aug 10, 2010 | 01:50 PM
I could have sworn that gutting yourself was your specialty above all else
Old Aug 10, 2010 | 03:17 PM
stinksause's Avatar
guys ... both of you have demonstrated and contributed lots of knowledge on this forum ... and I have nothing but respect for both of you ... but seriously, why do you feel the need to **** on each other on my thread
Old Aug 10, 2010 | 03:49 PM
Because it's fun.
Old Aug 10, 2010 | 04:33 PM
Brettus's Avatar
Boosted Kiwi
Interesting - never seen that . But mine is an 03 so i gues it doesn't have that issue .
Old Aug 10, 2010 | 05:09 PM
The AUDM/JDM 2003 model is the 2004 export model.
There were no significant changes from the start of production until the switchover to the 2005 MY.
Since you have some significant tuning issues with your PCM, it isn't likely that your example would be relevant.
