Grinding noise... Clutch Plate?
Old Jun 12, 2010 | 09:26 AM
majjic's Avatar
Post Grinding noise... Clutch Plate?
G'day, majjic here, I'm new just recently took delivery of a 2003 6 Speed. I have noticed an odd grinding noise when in idle unless the clutch engaged (less noise in gear with clutch engaged). Car drives and handles well and I do love it, just courious about the noise.
Thanks in advance.
Side Note: also wondering about a stereo kit in Australia to fit a double din head unit with a control box.
Again Thanks
Attached Thumbnails Grinding noise... Clutch Plate?-27799_450632111112_712526112_6280642_1969858_n.jpg
Old Jun 13, 2010 | 02:54 AM
takahashi's Avatar
Congrats on the purchase.
The noise is the throttle body noise and it is normal.
Old Jun 13, 2010 | 04:31 AM
c4nt1k's Avatar
what you mean by "clutch engaged" is when your foot stepping on the pedal? or when the clutch is not touched at all?
if the sound is gone as soon as u step on the pedal, its input shaft bearing. I heard from a few mechanics that its quite a common "problem" in rx8
if the sound is gone when u leave ur foot off the pedal, its clutch release bearing, could be from your aftermarket clutch/fitment by mechanic
Old Jun 13, 2010 | 11:55 AM
There is a lot of rollover gear noise with the transmission in neutral and the clutch out..
Old Jun 14, 2010 | 02:56 AM
majjic's Avatar
It happens when my foot is off the clutch and in neutral.
Thanks everybody!
Old Jun 17, 2010 | 08:51 PM
Wantarotory's Avatar
Registered Rxabuser
takahashi is right...mine does this as well...its totally normal!
Old Jun 17, 2010 | 08:55 PM
Jon316G's Avatar
Grasshopper
Dannobre is correct on this one...
Old Jun 19, 2010 | 03:14 AM
majjic's Avatar
Thanks Guys! you have put me at ease, being a new owner and all!
Cheers
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
