seafoam
Old Feb 15, 2010 | 03:43 PM
pineapplesoymilk's Avatar
pure sex
seafoam
hey guys i dont really know much about seafoam and was wondering what the point of it is if we should use it and how thanks.
Old Feb 16, 2010 | 01:16 PM
tonedef's Avatar
4FragileHearts&WeakLimbs
Seafoam is used to clean the carbon deposits left after burning oil in our engines.
Here this is the process i used.
https://www.rx8club.com/series-i-tech-garage-22/seafoam-newbee-186885/
Old Feb 17, 2010 | 06:32 AM
pure sex
thanks
Old Feb 17, 2010 | 07:19 AM
Bigbacon's Avatar
2006 WB AT
does seafoam come withthe rubber tube or did you just happen to have something?
What 2 stroke would one suggest that you can buy at autozone or AAP?
I dont normmaly premix but I don't like the idea of cranking dry.
Old Feb 17, 2010 | 07:49 AM
Huey52's Avatar
Registered Zoom Zoomer
^ rather get a case of Idemitsu 2-cycle premix. At 4 - 8 oz per tankful it will last you a long time.
Seafoam is very good (a long heritage in marine engine use), but so is Lucas and most of the other decarbing solutions.
Old Feb 17, 2010 | 06:45 PM
pure sex
should you do it before you change oil plugs and wires or after?
Old Feb 18, 2010 | 02:07 AM
tonedef's Avatar
I did this on my car before changing anything else. It helped a lot! It wasn't the only thing wrong with my car but it helped. I say start with the least expensive and work your way up. My car was having big idling problems to the point that it stalled once at a light. Asking around people told me to replace the plugs, coils, wires, etc. also to change the engine mounts. So this process was the least expensive of all and I went ahead and did it. You see even if I bought the plugs, coils and wires my engine will still be filled with crud (probably fouling my new plugs in the process). So I did this first. And it work (to a certain extent) no more rough idles at lights.
I still replaced my coils later on with a BHR Kit (awesome by the way).
Bottom line this is a process you will not regret and your engine will love you for it!
Old Feb 18, 2010 | 03:53 PM
pure sex
thanks man for the info
92trbolzr
May 18, 2025 09:04 AM
WranglerFan
Aug 21, 2022 01:29 PM
WranglerFan
May 31, 2022 07:51 AM
UHATEIT
Mar 31, 2019 05:31 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
