which fuel pump to get?
Old Dec 28, 2009 | 03:58 PM
Mr.&Mrs.Magic's Avatar
I would like to upgrade my current fuel pump for safety reasons(FI and it's time anyway). Question is which one to get. I hear things about the 09 pump and the walbro 255 lph. Question is why would anyone spend +$200 bones for an 09 pump when you can get a walbro 255 for +70 bones? I also read on the BHR site that you need to melt on the siphon assembly so does that mean litterly melt it on(within reason) or get it real tacky for a better seal.
There are a ton of 255 lph walbro pumps on ebay but some have a different title so which one is it.
http://cgi.ebay.com/ebaymotors/Walbr...5fAccessories- GSS-341
http://cgi.ebay.com/ebaymotors/Walbr...Q5fAccessories - GSS-342
or is it one of the other 1000+ walbro pumps on ebay
Last edited by Mr.&Mrs.Magic; Dec 28, 2009 at 05:04 PM. Reason: fixed a bit for jeffy
Old Dec 28, 2009 | 04:11 PM
MazdaManiac's Avatar
Have you read ANY of the threads about this?
Yeah - go ahead and buy an ebay pump and let us know how it turns out.
Old Dec 28, 2009 | 04:13 PM
ebay walbro pumps.
have fun with those Chinese / Ebay knockoffs.
Old Dec 28, 2009 | 04:28 PM
thanks for the help guys
Old Dec 28, 2009 | 04:32 PM
Seriously? You're genuinely lost on this?
I give up. Unbelievable.
Old Dec 28, 2009 | 04:35 PM
shaunv74's Avatar
Power!!
Definitely buy the Walbro from BHR. You don't melt the o-ring. You buy an o-ring that is 1/2 the thickness of the original and install it. You melt the popoff valve on to the stack on the fuel pump outer assembly. Two different things.
I posted the exact specs on the correct o-ring in that thread when I installed mine.
I just did this and it was no big deal once I got the pump assembly retaining ring off. That was a PITA. You really need 2 people or a 4 leg tool to remove the pump retaining ring.
The reason you'll pay more for the '09 pump is you're buying the whole assembly and you're buying it from Mazda.
Hope that helps.
Old Dec 28, 2009 | 04:36 PM
Hey MM, get back to work on that Fuel pump offering/program/solution deal! I'm patiently waiting.
Old Dec 28, 2009 | 04:47 PM
shaunv74 can you exact link me to your post i can't seem to locate it. Suppose i'm just lost
Old Dec 28, 2009 | 04:52 PM
shaunv74's Avatar
Power!!
Sure. Here it is: https://www.rx8club.com/showpost.php...&postcount=211
Old Dec 28, 2009 | 06:37 PM
AJ's Shinka's Avatar
Enthusiast
I would get the BHR pump, it's like $90.00 which is very handsomely priced.
Old Dec 28, 2009 | 07:12 PM
Flashwing's Avatar
3-wheeler
The solution is simple.
Buy the pump we offer on our site...follow the instructions listed in the fuel pump thread Mazdamaniac composed and you're done.
Old Dec 28, 2009 | 07:15 PM
shaunv74's Avatar
Power!!
+ purchase or borrow the fuel pump retaining ring removal tool. The one I bought wasn't stout enough (only 2 prong) so I had to stand on it to keep it from popping off the ring while my wife turned. I hear the Mazda tool has 4 prongs and does pretty well but is much pricier. The best bet is to borrow one from someone.
Old Dec 28, 2009 | 11:02 PM
05rx8mazda's Avatar
B.I.G
Why do you need to get a 1/2 thickness o-ring for the fuel pump? A stock one cannot be used?
Old Dec 28, 2009 | 11:14 PM
Is the retainer ring on the RX8 pump unique or is it the same as most other cars? I remember the fuel pump ring being a bitch on the RSX but nothing a hammer and big flat head couldn't handle.
Old Dec 28, 2009 | 11:41 PM
shaunv74's Avatar
Power!!
I don't think it's unique. Just a PITA.
Old Dec 29, 2009 | 09:25 AM
maxxdamigz's Avatar
Baro Rex
$90 shipped is about as good a price as you'll get on the walbro. I did a lot of shopping around for mine (not for price but for information) as there are 3 variants of the 255 high pressure. The variants (GSS340, GSS341, and GSS342) have to do with either the outlet or inlet location (right, left, center) and not so much the pump mechanics. I'm all for buying crap off ebay (clear corners, trim pieces, brittney spears collector dolls, whatever), just probably not fuel system components when the cost savings is only a couple bucks and you don't know the vendor.
Old Dec 29, 2009 | 11:28 AM
olddragger's Avatar
the 09 pump has worked well for me and as more get into the market the prices will come down. I saw one with a claimed 10 hrs of use for $125 recently. Mazmart stocks the 09 used pump.
I just like the redesigned cup/system and venturi ---matched with a bosch pump and replaceable filter.
Both seem to work and it is good to have options. Is one better than the other? I have no idea!
SInce you were asking about the 09 pump though i would just throw my thoughts in.
I remember when the only solution was to get a new oem assembly anytime a "symptom" would show.
OD
Old Dec 29, 2009 | 01:46 PM
so which pump to get 340, 341, or 342?
Old Dec 29, 2009 | 06:00 PM
heyarnold69's Avatar
Rotary wanabee
anyone near me -- long island can help me instaul a walbro fuel pump...
Old Dec 29, 2009 | 06:16 PM
maxxdamigz's Avatar
Baro Rex
I'll be doing it at some point this winter though the car isn't moving so I can pretty much do it at any time between now and march.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
mdl0209
May 23, 2019 05:46 PM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
