HIGH OIL CONSUMPTION DUE TO WRONG AIR INTAKE HOSE Series 1 ONLY
Old Nov 18, 2009 | 11:22 PM
ASH8's Avatar
Super Moderator
Exclamation HIGH OIL CONSUMPTION DUE TO WRONG AIR INTAKE HOSE Series 1 ONLY
It appears that Mazda factory Spare Parts have incorrectly packaged the Air Intake Hose as a REPLACEMENT SPARE PART.
In other words the correct Part Number labeled but with the wrong Air Hose inside box, in fact the 09 or Series II Air Hose has been supplied in error.
So if your Air Hose (concertina intake one) has been replaced because of a Vehicle Accident or other reasons there is a possibility that the incorrect hose has been installed and you may experience HIGH OIL CONSUMPTION as a result.
Please see attached TSB showing how you can inspect you Air Intake.
NOTE: This is NOT a Recall, or Wrong Part Installed During Production in your RX-8.
It is the WRONG replacement part supplied and possibly installed IF your car has had this part renewed.
Attached Thumbnails HIGH OIL CONSUMPTION DUE TO WRONG AIR INTAKE HOSE Series 1 ONLY-1.jpg
Old Jun 1, 2012 | 07:18 AM
t.swain's Avatar
I have a high oil consumption problem. And the attachment doesn't explicitly state how to inspect it to see if you have the wrong one. Do I just Check the small hose for 3 holes?
Have a 2004 rx8 with a new engine early 2010
Old Jun 1, 2012 | 07:34 AM
RIWWP's Avatar
If you have any more information on this Ash, it would be helpful.
This is t.swain's thread that I have been trying to help him through, but it's getting puzzling: https://www.rx8club.com/series-i-trouble-shooting-95/oil-level-problem-help-232792/
Old Jun 1, 2012 | 01:33 PM
It's so obvious. You don't notice?
The only different is 3 hose hole and 2 hose hole. if you have 3 on a 2009+ RX-8. you got the wrong one.
Old Jun 1, 2012 | 04:04 PM
ASH8's Avatar
Super Moderator
You could only have the 'wrong one' if you had it replaced because of say a bad frontal car accident, or perhaps it melted because of engine fire.???
It ONLY applies to those those have had it renewed...they don't replace them with engine replacements.
As originally said, it was a replacement 'parts' issue, a Series II part was inside a Series I numbered box/bag/wrapper.
And Jackson is correct...
Series II's have 2 not 3 '13-758' Vacuum Elbows like Series I's.
Old Jun 1, 2012 | 04:26 PM
godesshunter's Avatar
Voids warranties
Not that this applies to me but just curious...why does it make higher oil consumption?
Old Jun 2, 2012 | 06:00 AM
cuz the vacuum hose will be wrong and the engine will suck oil in much more than it should
Old Jun 4, 2012 | 01:28 AM
what they're saying is that when people didn't have the third hole to connect the line to they just plugged the hose end, which causes the OMP nozzles to experience engine vacuum, which in turn causes high oil consumption
these numnuts are doing it intentionally
https://www.rx8club.com/series-i-tech-garage-22/possible-mop-oil-line-cleaning-method-225321/
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
ripigs
Aug 2, 2015 10:44 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
AussieGray
Jul 16, 2015 03:58 AM
