Clutch problem
Old Nov 18, 2009 | 11:52 AM
DaRotary's Avatar
Clutch problem
so i posted topics about my clutch making a popping noise i went down and checked the clutch with a flashlight and the bracket looks very stable but what i found out the noise was coming from was the big spring it just makes 2 popping noises when u press the clutch and let it out but looks alright?
any one have any opinions to share plz
Old Nov 18, 2009 | 12:16 PM
DaRotary's Avatar
Any one??? plz guys going on a long trip dont want it to break
Old Nov 18, 2009 | 12:19 PM
Huey52's Avatar
Registered Zoom Zoomer
The starter interlock and clutch pedal position switches sometimes make a bit of a popping noise, but is not an issue.
The spring itself can also make a noise at both transition points, again not really an issue.
Do keep monitoring for any signs of degradation and better get the plate welded or braced.
Good view of the switches linked:
http://www.coloradomazdaclub.com/for...clutch+bracket
Old Nov 18, 2009 | 12:59 PM
DaRotary's Avatar
thx alot bro
Old Nov 18, 2009 | 01:18 PM
Huey52's Avatar
When your clutch baseplate is in the process of metal fatigue just prior to factory weld failure it's more of a squeeking sound, whereas the switch and spring are more the 'popping' sound you describe, so you should be fine on your trip.
If you have above 30k miles, and/or have a heavy clutch foot, do look to reinforcement asap.
Unfortunately there's not as easy a fix for the spring-plastic mating part degradation, but that is a much more rare malady then the baseplate spot weld failures.
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
