Is there a DIY for Water Pump replacement?
Old Oct 19, 2009 | 02:18 PM
BigMikeATL's Avatar
Yes, I used the search. No, I did not find a thread.
Thanks in advance!
Old Oct 19, 2009 | 04:14 PM
Flashwing's Avatar
3-wheeler
Thanks in advance!
Yes there is, it's in the factory shop manual.
Old Oct 19, 2009 | 05:56 PM
Jon316G's Avatar
Grasshopper
Yup. Its actually pretty easy to install.
Here is a guide from the shop manual:
That is basically it.
Only thing the above guide doesn't mention is to remove the battery, the battery box, and drain the coolant.
Old Oct 20, 2009 | 10:13 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
I just did it this weekend. It was actually not bad. Just make sure you have a big drip pan because it is messy.
Adjusting the tension on the Alternator/Water Pump pulley was obnoxiously easy!
Also, don't forget to turn your wheel from lock to lock, then pump your brakes x20. I forgot this and completely panicked when i say warning lights. But after I did ^, everything was good.
Remember it can take a few engine cycles for your coolant to go from your reservoir into the cooling system.
Antifreeze will pour out when you pull the pump off even if you drained your coolant. So expect your engine bay to smell until it burns away.
Old Oct 23, 2009 | 12:40 AM
Obnoxiously easy?
You get annoyed unless things are exceptionally difficult?
Old Oct 23, 2009 | 01:25 AM
MazdaManiac's Avatar
Drain the coolant from the engine drain (near the starter harness ground) and it will be considerably less messy.
Old Mar 27, 2010 | 06:09 PM
thawk97's Avatar
...pondering...
Is a gear puller required to get the water pump pulley off? Or, does it come off easily? I see from the shop manual pic it is attached to the pump by an off center bolt - is this all that is holding it to the pump?
Old Mar 27, 2010 | 06:13 PM
Jon316G's Avatar
Grasshopper
Only three bolts hold the pulley onto the water pump.
After those are out it simply comes off.
Trick is loosening the bolts without spinning the pulley.
I apply more tension to the drive belt (using the alternator) until the pulley doesn't spin while trying to loosen the bolts.
Old Mar 27, 2010 | 06:17 PM
thawk97's Avatar
...pondering...
excellent, thanks much!
Old May 30, 2010 | 07:00 PM
J03K1LLARX8's Avatar
ジョーイ
Need help removing the entire housing to get to a broken bolt in the block.
Old May 30, 2010 | 08:29 PM
Another Tension bolt broke ?
Old May 30, 2010 | 09:06 PM
ジョーイ
I was removing my engine hoist bracket and when was putting the bolts back in it broke. So now I have to take off the whole front assembly to get to the bolt.
Old Nov 10, 2013 | 06:57 PM
pelensky's Avatar
I am getting ready to replace my pump with a Mazdamart unit. Does this come with a gasket? Is sealant required or is it a rubber gasket or O-ring. Maybe sounds like a dumb question, but I have never had a mazda before much less an RX.
Old Nov 10, 2013 | 07:22 PM
J8635621's Avatar
Pew Pew Pew
This high flow RE-medy water pump is designed to prevent cavitation at engine speeds as high as 10000 rpm. It is a direct fitment, as OEM and comes with a new Mazda OEM gasket. Taken directly from their website. Please read and not bump ancient threads
Old Nov 10, 2013 | 08:01 PM
pelensky's Avatar
Sorry for missing the fact that it had a gasket. I have read a lot on the water pump but could not find if the gasket is rubber or paper or other and if it requires some kind of sealant. If it does require sealant what is the spec?
Old Nov 10, 2013 | 10:41 PM
you don't need sealant, but some people like me always like to have a little extra insurance. RTV is cheap anyway.
and the gasket is made of metal.
Old Nov 11, 2013 | 06:52 AM
pelensky's Avatar
Thanks a million for the explanation and recommendation! Will do it that way. It makes a lot of sense.
Old Nov 12, 2013 | 07:24 PM
pelensky's Avatar
By the way, is there a specific RTV we should use on this gasket? I have used blue RTV in the past for water pumps but I don't have a lot of experience with the rotary.
Old Nov 12, 2013 | 08:43 PM
I use a very little bit of black
Old Nov 12, 2013 | 09:54 PM
black stuff works just fine, but u can always use the stuff designed for coolant/water pump
Old Nov 12, 2013 | 11:36 PM
^^sorry guys, very bad advice
DO NOT USE SEALANT. The gasket is designed to eliminate sealant. Doing so only creates a fubar mess the next time the WP needs to be replaced. Never had one leak. Just use a new one every time. If you do have a leak after then you just did something stupid.
Old Nov 13, 2013 | 12:20 AM
Like Frank's Red Hot..."I put that **** on everything"
Old Nov 13, 2013 | 07:02 AM
it does requires more work, and yes I know the metal gasket is designed to eliminate RTV, just like the front cover gasket, like i said it's just an extra insurance.
i seen metal gasket fail before it's really rare, but it does happen. how? I really have no idea, I didn't do that install. but if he had some RTV in place, he doesn't have to tow his car to me.
Jesus Martinez
44
May 6, 2025 08:09 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
Sakebomb Garage
Vendor Classifieds
Jul 31, 2015 07:36 PM
