obd2 scanner tells me...
Old Oct 18, 2009 | 07:40 PM
abc20abc's Avatar
Ok so I just got my engine put in. (junkyard engine) and it has the cel illuminated. The scanner reads two codes: "misfire cylinder one detected", and "misfire cylinder one detected" (yes they say the same thing, i dont remember if the actual codes were the same, but the description was) I don't understand what that means. I mean we don't have cylinders. Does this mean the leading and trailing spark plugs are both bad for one rotor? I dont know much about leading and trailing plugs so im clueless. I can't really notice a misfire, maybe a little at idle, but that's it. Any ideas?
Old Oct 18, 2009 | 07:52 PM
expo1's Avatar
He's as bad as Can
How are the coils & wires? Did you install new spark plugs?
Another thing to try is the 20x brake pedal thing.
Old Oct 18, 2009 | 08:20 PM
abc20abc's Avatar
its from a wrecked 8. so I'm assuming it ran fine before the wreck, but it has been sitting for a while.
Can I check the coils and wires by taking one of the wires off the plug while it's running and check for spark? (if i get spark that means the coil and the wire is good, right?)
And no I didn't change the plugs.
I'm just confused how it says it has two "cylinder one misfires"
And what's the 20x brake pedal thing?
Old Oct 19, 2009 | 09:02 AM
olddragger's Avatar
resets short term trim stuff in the cars computer. i had the same thing when i last installed an engine. the pedal dance cleared mine up. may work on yours.
one code will read misfire--another code will detect which rotor will misfire.
od
Old Oct 19, 2009 | 10:23 AM
bose's Avatar
Reginald P. Billingsly
Your right we don't have cylinders, but we can't expect the scanner companies to make a scanner special for ours cars, unless we wanted to pay ridiculous prices for it. It's just a general term really. Cylinder one is the front housing, cylinder two is the rear. Sounds like you had two misfires in the front rotor. Check your plugs and I would just for posterity change the coils and wires. Do the brakes pedal reset and see how that goes.
Old Oct 19, 2009 | 10:11 PM
abc20abc's Avatar
Ok so I did the brake pedal thing. When the ecu reset (after the oil pressure gauge shot up and dropped down), the CEL blinked a couple times then stayed lit. I started it up and it stayed on.
The car runs fine. Doesn't seem to have a missfire, so I'm afraid to mess with it.
Old Oct 20, 2009 | 02:01 AM
Juice's Avatar
I made some poos
Well, now that the CEL is solid, you should get the code read.
My guess is the eccentric shaft position sensor is giving you the trouble. If the car can't detect where the eccentric shaft is, it could throw random misfire codes. It happened to me when the sensor face was dirty with dust containing metal particles and rust. The 20x brake pedal pump will reset the sensor but if it is dirty, broken or not in the correct position it could give you problems.
It never hurts to replace the plugs, coils and wires though.
I'd love to sit here and throw out ideas all night, but it seems pointless considering I don't know what the code is at this time. Anyways, when you get the CEL code, post it up and we can try and further diagnose.
cliffkemp
Dec 24, 2024 10:48 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
duworm
Oct 1, 2015 04:57 PM
Stubbs
Sep 27, 2015 04:06 PM
