Intake manifold runner stuck open P2004 Code
Old Oct 16, 2009 | 09:00 PM
mag48's Avatar
I am getting an error code P2004 Intake maniford runner control stuck open. . . it is pointing to the APV. Have you run into this problem before?
I pulled the ACV off. There is a gear there . . . to open or close the intake runner. The gear will not turn by hand with the vehicle off . . .is this normal?
Your help is appreciated.
Regards
Mark
Old Apr 3, 2012 | 05:46 PM
R-mazda-X-man-8's Avatar
now i dont know too much about the apv and the valve it controls but i have the same problem and i took the apv motor off and tried to turn the big gear that it turns and it would only turn about a half inch either way and its suppose to turn one full turn both ways. so the only thing i cn think of is that it has alot of carbon or a peace of carbon droped into the valve and got it stuck. but im having mazda do a decarbonize the engine and hopefully it will free up the exhaust valves. if not then i will have to tear apart the engine and clean out the exhaust valves. i hope this helps you and if you get your engine fixed plz tell me what they had to do to fix it.
Old Jun 12, 2012 | 02:28 PM
Mo287@hotmail.com's Avatar
I changed the APV and Didnt do anything. Next im going to try to clean exhaust valves and body else go any ideas?
Old Jun 12, 2012 | 02:40 PM
DarkBrew's Avatar
Extraordinary Engineering
jon316G has videos on APV troubleshooting
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-troubleshoot-intake-valves-174009/
Old Jun 12, 2012 | 02:46 PM
It should turn freely by hand with the motor off...if it is plugged up you could try and soak it in carb cleaner by spraying it in the intake runners with the UIM off.....to see if it loosens up
Old Jun 12, 2012 | 04:43 PM
one injector is not working? anyone has wiring diagram for mazda rx 8 engine? PCM?
TeslaMSI
Dec 10, 2015 01:10 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
