Jon316G's Dyno Run Analysis
Old Sep 14, 2009 | 07:42 PM
Jon316G's Avatar
Grasshopper
I performed 3 dyno runs today and want some opinions since I'm not very knowledgeable on reading these graphs.
List of mods are in my signature.
The outcome was surprising... I expected a little more, but its difficult to judge since I don't have a stock dyno to base the improvements off of.
I also don't like the A/F ratio since it starts off lean and gradually richens.
Shouldn't this be more linear?
And could this be effecting my numbers (HP and/or TQ)?
My first thought was, "Oh no, is it time for a compression test!"
But the graph curves appear very good.
Wouldn't I see some crazy "spiking" along the curve if I had any electrical or mechanical issues?
Each PDF has 3 pages of information, the first page is the graph and the other two are the text-based data.
Thanks for taking the time to review this and any input would be greatly appreciated.
Dyno Run 1.pdf Dyno Run 2.pdf Dyno Run 3.pdf
Old Sep 14, 2009 | 07:46 PM
05rex8's Avatar
sold the 8... :(
what kind of dyno is this?
Old Sep 14, 2009 | 07:47 PM
Jon316G's Avatar
Grasshopper
Dynojet
Old Sep 14, 2009 | 07:48 PM
Those are decent graphs...even the AFR's aren't that bad...
Your AP tune looks OK...the AFR graph is a bit hard to read..but you are missing the usual pig rich top end from the stock tune
Old Sep 14, 2009 | 07:51 PM
05rex8's Avatar
sold the 8... :(
does seem a little low for a dynojet
the power and tq curve look fine tho
Old Sep 14, 2009 | 07:57 PM
Jon316G's Avatar
Grasshopper
That's what I thought too...
My friend was also there tuning his TransAm and his first run was 20HP less than before on the same dyno.
What's the chance the dyno is reading incorrectly.
Old Sep 14, 2009 | 08:00 PM
@!!narotordo's Avatar
FLAME ON!
I had low numbers when i dynoed my car for the first time. But having never done this before I had no clue what I was doing lol
After I found I needed new coils wire spark plugs oil change and a seafoam really bad.
This is a good thread to check out
https://www.rx8club.com/showthread.p...highlight=dyno
Old Sep 14, 2009 | 08:04 PM
Jon316G's Avatar
Grasshopper
I doubt I need new coils
Old Sep 14, 2009 | 08:14 PM
chickenwafer's Avatar
Nope
Your AFR actually looks pretty good for an NA car. Not nearly as rich as stock.
Your power curve is pretty good too. My money is on the dyno reading low. Don't get hung up on it tho, it the car still feels quick then that's all that matters. But now you have a basline with your current mods so if you change anything you have this baseline
Old Sep 14, 2009 | 08:20 PM
Jon316G's Avatar
Grasshopper
But shouldn't the line be more linear?
Old Sep 14, 2009 | 08:25 PM
FLAME ON!
You never know. Look what happen with Jedi on his first dyno run with them. I'm just saying. Hey let me see if I can find my dyno slip brb...
Old Sep 14, 2009 | 08:27 PM
FLAME ON!
Oh yeah did you pull the room fuse?
Jon316G's Avatar
Grasshopper
You never know.
I only say I don't need coils because they are BHR's
Old Sep 14, 2009 | 08:28 PM
Jon316G's Avatar
Grasshopper
I remember reading that whole thing and I don't want to get into that here.
But no... I didn't.
Old Sep 14, 2009 | 08:38 PM
05rex8's Avatar
sold the 8... :(
all you need to do is turn off traction control
Old Sep 14, 2009 | 08:39 PM
Jon316G's Avatar
Grasshopper
I did tell the guy to push/hold the DSC for 8 sec.
Old Sep 14, 2009 | 08:54 PM
FLAME ON!
How about staticleg diy? did you his steps?
Old Sep 14, 2009 | 08:57 PM
Atilla's Avatar
I am THAT guy
scribed
Old Sep 14, 2009 | 09:19 PM
Cam's Avatar
Cam
this space for rent
How come you didnt take it to redline? Graphs show 8200.
Dyno in 4th gear, should be 5th (although I dont think thats going to cost you the 10-15 HP you were hoping for.
Im no tuning guru, but 12:1 up top seems a little rich to me.
Since you dont have a stock baseline, you cant tell how much you gained with the mods. Maybe yours stock is one of the 170 HP cars?
Old Sep 14, 2009 | 09:21 PM
Jon316G's Avatar
Grasshopper
I told the guy to take it to 8500.
Didn't see a reason to go higher than that.
Old Sep 14, 2009 | 10:06 PM
My Scangauge II reads 8300 at red line according to a little past the 9k mark on the stock tach.
Old Sep 14, 2009 | 10:08 PM
05rex8's Avatar
sold the 8... :(
Which gear were the pulls done in?
Old Sep 14, 2009 | 10:09 PM
Jon316G's Avatar
Grasshopper
Which gear was the pulls done in?
The sheets have the gear listed
But the first one was in 4th, they wanted to do 3rd for the other two.
Old Sep 14, 2009 | 10:11 PM
05rex8's Avatar
sold the 8... :(
oh, I missed that
I didn't feel like opening the files again, lol
4th is usually what is used
Old Sep 14, 2009 | 10:13 PM
Jon316G's Avatar
Grasshopper
I forgot to mention... each PDF has 3 pages of information.
So the first page is the graph and the other two are the text-based data.
You should be able to read the AFR easier with that.
