Ignition Coils/Spark Plugs/Wires
Old Sep 1, 2009 | 11:01 PM
Jasonvaldez's Avatar
After doing research for a day or two on the forums i have realized my car has 70k miles and the coils, plugs, or wires pry have NEVER been changed i want to go after market no questions asked. but my question is what are some good brands for ignition coils, plugs, and wires i was thinking MSD but I don't know if they make those for rx8s. i also have a few other questions so RX8s have FOUR ignition coils???!!! i am still in a learning proccess of this car. and where is it located?
Thanks. any tips would be very helpful thanks again.
Old Sep 1, 2009 | 11:04 PM
dozer's Avatar
on his 3rd rx8
yes the 8 has 4 ignition coils, 4 wires and 4 spark plugs...if you really wanna go aftermarket, go with the BHR kit (Pm one of the guys over at BHR and theyll give you the treatment) im pretty sure their kit comes with aftermarket wires too, as far as spark plugs, nothing beats OEM and im pretty sure that you can order new plugs with your BHR kit
Old Sep 1, 2009 | 11:09 PM
volcomx31's Avatar
Silver Power
do what dozer said..and change your air filter with a k&n one
Old Sep 1, 2009 | 11:19 PM
RX8pwnage's Avatar
RX8. Yeah, I get it.
BHR ignition hands down. Accept no substitute.
Old Sep 1, 2009 | 11:37 PM
hakuna matata!
If you don't want to do an ignition coversion (BHR) then stock is sufficient if your car is N/A.
Stock Coils, Plugs, and wires are a little less then $300.
Old Sep 2, 2009 | 01:13 AM
I have an aem cold air and who would I pm?
Old Sep 2, 2009 | 01:52 AM
Easy_E1's Avatar
Yeah, PM that guy^
shazy's Avatar
/\ Him.
Old Sep 2, 2009 | 03:14 AM
bse50's Avatar
#50
Just to clarify; the only direct bolt-in performance coils for the RX-8 are the Okada Products coils and they are $700 (or so) per set. Any other coil swap kit will either require a conversion wiring harness or a molestation of your factory wiring.
I would call your upgrade a "direct swap" as well. Your wiring harness is perfect and requires no cutting whatsoever. The only difference maybe is that you don't change your coils one by one but place the whole coil pack in at once!
Now prove me wrong as you always do
Old Sep 2, 2009 | 03:24 AM
bse50's Avatar
#50
Agreed on the times getting shorter lately. You guys really improved at that!
Well, 485$ (BHR) vs 700$ for the okada (with unknown specs) i'd pick your kit up anytime, especially since you provide a real warranty and did some extensive tests on the coils.
I actually found easier to swap the whole coil pack than the coils one by one anyway. Maybe because i am goofy when working on the car
Old Sep 2, 2009 | 03:33 AM
bse50's Avatar
#50
I did some italian tune-up with other parts. I did polish my throttle body with a dremel tool
That's also how i do the simple "smoothening" ports to the engines! Martina thinks that i'm in love with that tool
cliffkemp
Dec 24, 2024 10:48 AM
Eraser
Aug 11, 2023 11:31 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
drlubell
Sep 26, 2015 11:58 PM
Sheldon24
Sep 21, 2015 04:53 PM
