MY OMP never worked
Old Aug 19, 2009 | 09:09 AM
turborx8's Avatar
Boost 4 Life
MY OMP never worked
I am really happy I installed a Sohn OMP adapter when I first bought my car because the OMP never worked. I have the adapter connected to a small 2stroke reservoir and it only burned a few ounces of oil in the past 30,000miles. I knew right away that I needed to premix.
Couldn’t I just cap off the nipple on the OMP adapter and just premix?
I would rather use the 2stoke reservoir for my windshield washer fluid.
Old Aug 19, 2009 | 09:54 AM
09Factor's Avatar
Original Turbo 'd Auto !!
I don't see why not. I had to remove the OMP for my turbo project and plan to pre-mix.
I also know several rx7 owners that pre-mix exclusively.
Old Aug 19, 2009 | 10:12 AM
OnRails's Avatar
I know that's what some of the race teams do. Seems kind of inconvient for daily use but if you're doing it every time anyway why not.
One of the benefits I'm told is a much cleaner engine internally.
Old Aug 19, 2009 | 10:50 AM
MazdaManiac's Avatar
Why not crank it up with the AP?
Best of both worlds.
Old Aug 19, 2009 | 11:09 AM
rotary.enthusiast's Avatar
The Local Idiot
I was planning on getting the OMP adapter myself, but ended up deciding to try pre-mix only. I zero'd out all the OMP tables with the AP and have been premixing ~1 oz. per gallon for the last 4 months with no (noticeable) ill effects so far. I keep two small bottles of two stroke in the trunk, and just dump the entire contents of one in at a fill up.
I'm not 100% certain that the OMP isn't still putting out a little bit of engine oil, but my oil level hasn't changed noticeably between oil changes. I also started the heavier pre-mix one full gas tank before turning off the OMP.
Still not sure if it's a great idea or not. I guess I won't know until my engine dies and I have to tear it apart.
Old Aug 19, 2009 | 11:46 AM
turborx8's Avatar
Boost 4 Life
The map you gave me does have the omp cranked. It simply does not work.
Old Aug 19, 2009 | 12:50 PM
chickenwafer's Avatar
Nope
How do you have your OMP air bleed hooked up?
Old Aug 19, 2009 | 07:18 PM
csl's Avatar
csl
shaft stuck or line clogged? I took mine out for cleaning and after that drink like a fish
Old Aug 19, 2009 | 07:40 PM
Brettus's Avatar
Boosted Kiwi
yes
Old Aug 19, 2009 | 08:38 PM
turborx8's Avatar
Boost 4 Life
Good question.
I dont even know what that looks like.
Old Aug 19, 2009 | 09:07 PM
I8U's Avatar
I8U
turbo, you said your OMP never worked? How much 2 stroke have you been running to counteract the faulty OMP? With a non-functioning OMP you should be running atleast an ounce per gallon of fuel, just to be on the safe side. If you haven't been I bet your engine is f'd after running like that for 30k.
Old Aug 19, 2009 | 11:26 PM
turborx8's Avatar
Boost 4 Life
I premix 8oz per fill up.
Old Aug 20, 2009 | 04:20 PM
04RX8man's Avatar
Rotary Powered Countryboy
^I'd up it more....I'm using 8oz with my OMP still pumping away..since yours is not working like you said....I'd listen to I8U and use At LEAST 1 oz per gal
Old Aug 20, 2009 | 04:27 PM
ChrisRX8PR's Avatar
13B-RE
You can premix in the fuel, its been done for years in RX-7's....
You do have to be careful not to overdo it because depending on what you are using it has the capacity to clock your fuel filter.
It works wonders for people with no OMP.
Chris
Old Aug 20, 2009 | 04:42 PM
Just remember that the oil effectively lowers the octane of your fuel.
Old Aug 20, 2009 | 04:47 PM
Nope
Good question.
It's one of the two larger hoses hooked into the accordion on the factory airbox. The other is the Jet Air hose and should be plumbed to boost (or have a check valve if hooked up to vacuum) and the OMP air bleed should be hooked up pre-compressor.
Old Aug 20, 2009 | 05:50 PM
turborx8's Avatar
Boost 4 Life
Hmmm... I have two Mazsport check vlaves on those two hoses. Could that be the issue? lol
Old Aug 20, 2009 | 05:52 PM
turborx8's Avatar
Boost 4 Life
Good to know.
I use 94 octane anyways just to be safe.
Old Aug 20, 2009 | 05:55 PM
Nope
Yes, remove the check valve off the OMP air bleed
Old Aug 20, 2009 | 06:38 PM
turborx8's Avatar
Boost 4 Life
I will give that a try. Thanks man!
Old Aug 23, 2009 | 06:23 PM
Red Devil's Avatar
I've actually been considering the direct opposite and dialing down via the AP and increasing the amount of premix. With the two injector locations on the majority of our engines I'm not sold that cranking it up is superior to premixing. At this point I suppose like many other things this argument is academic and what floats your boat. But my rationale is that I have little interest in doing a sohn adapter and would rather have 2 stroke enter the combustion chamber rather and oil from the pan.
Old Aug 23, 2009 | 08:46 PM
turborx8's Avatar
Boost 4 Life
Keep in mind, you can start using synthetic oil when using the sohn omp adapter.
Old Aug 23, 2009 | 10:19 PM
Vlaze's Avatar
The Angry Wheelchair
The Sohn Adapter does just that and doesn't take oil from the pan, but takes it fresh from a reservoir.
My question is has anyone taken an OMP off the 8 and cleaned it down when they did an oil change? If so how much of a PITA was it to bleed the system when you disconnected the lines? How did you clean it? And from what I've read the typical rate is 1 qt every 3k miles should be consumed or is that with the AP flash only. Since getting the car from the dealer used a few months ago I presume it should already have the latest flash that bumped the oil consumption rate up... but assumptions are a dangerous thing.
Old Aug 23, 2009 | 10:20 PM
I8U's Avatar
I8U
You could always use synthetic oil...sohn adapter or not.
Old Aug 23, 2009 | 10:22 PM
Vlaze's Avatar
Yes, but based on the history of the seals and burning with synthetic oil, it's not a good thing to do this. Which is exactly why it's another benefit using the adapter so you can run synthetic in the engine without getting it in the combustion chamber.
