power steering problem PLEASE HELP!!
Old Aug 13, 2009 | 04:33 PM
x MazDA's Avatar
04 TG 6spd
MA power steering problem PLEASE HELP!!
hey guys starting this morning my 8 has no power steering. i don't exactly know why but i have no idea where to start looking. is there a power steering belt, fuse, or anything else mazda could have thought up? please help me guys the mazda dealership is booked for to long..
thnx
Cory
Old Aug 13, 2009 | 04:38 PM
dozer's Avatar
on his 3rd rx8
relax, relax, its ok DOZERs here, first off, your power steering is electric, thus no belts or no fluid...
alright now, right under your airbox and the tray that holds it, are 2 connectors, the bigger one on the right is for your power steering, pull it apart and clean the inside off both sides with keyboard duster (electronic cleaner) and dab a bit of dielectric grease on the 2 prongs, connect, start up and it should be gone....if the problem continues, it could be worse...
Old Aug 13, 2009 | 04:39 PM
Jon316G's Avatar
Grasshopper
I can tell you where to start... the "search" option at the top since this has been covered many times here before.
All you need to know is in this thread:
https://www.rx8club.com/showthread.p...power+steering
Old Aug 13, 2009 | 04:41 PM
dozer's Avatar
on his 3rd rx8
^thats the second solution...
Old Aug 13, 2009 | 04:49 PM
Jon316G's Avatar
Grasshopper
^True... some have been lucky and cleaning the connectors once did the trick.
I wasn't so lucky (as I explained in that thread) and had to clean them at least once a week.
Which is why my wires are now spliced together.
Old Aug 13, 2009 | 05:22 PM
x MazDA's Avatar
04 TG 6spd
dozer i love you i will be back on later to let u know if it worked thnx again
tear, tear, i was so scared...
Old Aug 14, 2009 | 11:41 PM
did it fix the problem? (permanently?)
Old Aug 15, 2009 | 01:03 AM
nothing is fixed permanently..
but it does fix it. i just went through this at 114k miles.. it took no time at all.
do it yourself..
Old Aug 15, 2009 | 09:28 AM
had mine go out yesterday.
I'm leaning towards coolant getting on the connectors since the coolant light came on as I started my car (quickly went off)
30 minutes later...PS is gone.
going to pick up the updated harness and see if that fixes it.
Old Aug 15, 2009 | 09:31 AM
Spinning Sushi's Avatar
I <3 Sushi
Pull out intake, pull out tray, pull apart the connector (It's the big one), clean it, add di-electric grease, reconnect the connector, start the car. If this solved it then proceed to put the tray back in, and put the intake back on. You might get a CEL for having the MAF disconnected after you start the car but that's nothing major for you since you have the Cobb AP to delete codes.
Old Aug 15, 2009 | 01:14 PM
04RX8man's Avatar
Rotary Powered Countryboy
mazda needs to put a longer hose on the overflow tank....
Old Aug 15, 2009 | 01:47 PM
^^^ YES they do!
Old Aug 15, 2009 | 01:48 PM
I <3 Sushi
Why not just buy a new longer hose for $2.99 a feet at AutoZone like I did to prevent this from happening? Cheap simple fix.
Old Aug 15, 2009 | 01:51 PM
that's already on my list of things to do when I fix the PS.
Old Aug 15, 2009 | 10:15 PM
04RX8man's Avatar
Already done RENESIS...but if MAZDA would fix it from the factory that's 2.99 I don't have to spend...damn that's like 1 beer....
Old Aug 18, 2009 | 03:36 PM
x MazDA's Avatar
04 TG 6spd
papa dozer...i dont know which plug to clean. please help again
Old Aug 18, 2009 | 03:39 PM
dozer's Avatar
on his 3rd rx8
none of those, youre gonna have to completely take out the airbox(intake box) the the tray underneath it to get to the plugs
Old Aug 18, 2009 | 03:44 PM
x MazDA's Avatar
04 TG 6spd
oh ok well thats a starting point then guess i know what i'll be doing later..thnx again i'll probably call for you again...:'(
Old Aug 18, 2009 | 03:46 PM
dozer's Avatar
on his 3rd rx8
no worries, just PM me if i dont post in this thread
Old Aug 18, 2009 | 03:56 PM
MazdaManiac's Avatar
Nice to see you didn't even read the thread that you were referred to.
Old Aug 18, 2009 | 04:33 PM
x MazDA's Avatar
04 TG 6spd
actually yes i did. im just very new to the car and still was a little lost and dozer was very nice about helping the extra bit. but yes i did read it and thank you for posting it
Old Aug 18, 2009 | 04:37 PM
dozer's Avatar
on his 3rd rx8
what i posted was just a quick fix, its worked fine for me, and im hoping it works for mazda, but if it doesnt then the next thing to do is whats in that thread
Old Aug 18, 2009 | 04:40 PM
04RX8man's Avatar
prob wouldn't hurt to clean the MAF either(the one on the left that you circled) but that has NOTHING to do with your P.S......
Old Aug 18, 2009 | 04:55 PM
^^^ and by cleaning the MAF sensor he means take it out, spray it with MAF cleaner (gently) and then let it dry.
don't get crazy scrubbing that thing.
drebbrnator
Dec 27, 2018 07:02 PM
Billy Marcial
Mar 1, 2018 06:50 AM
04rx8rotary
Sep 3, 2015 04:36 PM
HMSS013
Aug 28, 2015 03:08 PM
SIllver
Aug 1, 2015 07:34 PM
