Highest Horsepower dynos for SC Turbo and nitrous - post them here
Old Aug 7, 2009 | 11:53 PM
Brettus's Avatar
Boosted Kiwi
There once was a very popular thread that compared all the popular FI options against each other . That did turn into a bit of a shitfight after a while as it was supposed to be for BASE kits and there was always arguments about what should or shouldn't be included .
I would like this thread to be more of a no holds barred thread - lets see what people have done to get good power from their 8 whether it is supercharged Turboed or nitrous 4 port , 6port , AT or MT .
I'm hoping that people that have posted their dynos in the past will post them again in here if they meet the criteria .
Only rules are :
It must be a renesis engine with Forced Induction
Dyno must be of a members car - not a promotional dyno
Post as much information as you can about what was needed to get the power you did .
I will endevour to keep the first page updated with the top whp dynos for each particular setup .
Don't want to forget the ATs - want a 6 port AT dyno chart as well but have not seen any yet ....
Attached Thumbnails Highest Horsepower dynos for SC Turbo and nitrous - post them here-fi.jpg   Highest Horsepower dynos for SC Turbo and nitrous - post them here-tofu-sc.jpg
Old Aug 7, 2009 | 11:54 PM
Brettus's Avatar
Boosted Kiwi
Greddy turbos :
Brettus
Running with :
Upgraded greddy turbo
Hymee protuner
stock coils (dwell increased by 10%)
Stock Greddy intercooler
Auto exe leads
Custom cold air intake
Stock gutted midpipe
Trust Ti catback
New rx7 plugs
Blue 480cc injectors in P2 position
Synthetic 2 stroke premix @ 200:1
Greddy Turbo on 4 port AT
09Factor
Stock Greddy turbo :
To my knowledge this the most anyone has ever made from the stock Greddy turbo .
Old Aug 7, 2009 | 11:55 PM
Brettus's Avatar
Boosted Kiwi
other turbos:
Esmeril Turbo
Garret 3071R
Mazda Maniac
Chickenwafer 3071r @ 13.5 psi
Originally Posted by chickenwafer
SWEET! I'm so Baller Status
-Meth was Snow Boost Juice (51% water/49% methonal)
-Running Snow Stage 2 progressive water/meth kit with "medium" jet (not positive of the exact size will get it later), starts spraying at 3psi full spray at 9psi. Jet it right infront of throttle body
-Running crappy 91 Colorado pump gas
-Intercooler is custom, core is 30"x12"x3"
-running custom LS2 Yukon Ignition system with custom MSD plug wires
-NGK BUR9EQP FD Trailing plugs in the leading hole, OEM trailing plug in trailing
-GReddy E-01 electronic boost controller with MAXED OUT duty cycle...couldn't get boost to peak anything above 13.5 psi (might try another EBC or even a manual one now) Boost was falling FAST after 6500 or 7000rpms....that's why power trailed off like it did. I still held over 300-rwhp for over 3000rpm I think
-Running all stock injectors except for rebuild/flowmatched Denso 730cc P2s
Not sure what else would be relevant. Car feels like a beast!
Brettus's Avatar
Boosted Kiwi
superchargers:
Pettit Supercharger
Marsredr100 :
Old Aug 7, 2009 | 11:56 PM
Brettus's Avatar
Boosted Kiwi
nitrous :
Anyone remember Taj ? 65 wet shot of nitrous
Nitrous to NA comparison, 3rd gear
Easy E1 4 port AT with nitrous
Originally Posted by Easy_E1
So here is a pic of an old Dyno run with the 65 shot.168 WHP.With and without N2O.
It had hit 172 before this run. Added 40ftlbs of Torque and 40 WHP.
Watch out 6 ports,, it has a 75 shot now!
Old Aug 9, 2009 | 04:00 PM
Brettus's Avatar
Boosted Kiwi
Ported NA :
Charles Hill - ported + nitrous(blue line)see notes from charles below
Old Aug 9, 2009 | 07:39 PM
chickenwafer's Avatar
Nope
It's on his site.
I'm hitting up a local dyno soon.....
Old Aug 9, 2009 | 07:54 PM
mysql101's Avatar
har har. Take mine out. The wastegate wasn't even setup at the time.
Old Aug 10, 2009 | 06:58 PM
Brettus's Avatar
Boosted Kiwi
added 4 port AT turbo
Is there a better turbo dyno on an AT than 09 Factor's one ?
Old Aug 10, 2009 | 08:45 PM
nuke0907's Avatar
Never Blend In
you'll have to wait for mine.
Old Aug 10, 2009 | 11:07 PM
Charles R. Hill's Avatar
Owner of BHR
For the record;
1) The porting Rotarygod did for me did not effect the overall airflow figures and only made a difference in the SHAPE of the torque curve, particularly through the midrange RPMs.
2) The nitrous was running for absolute **** that weekend because I screwed up my jetting calculations.
3) Once we get back around to developing nitrous applications and tweaking the ignition curves we should see F/I-like numbers from nitrous systems.
4) In the meantime, I would use the dyno sheets presented by "Punisher_RX8".
Old Aug 10, 2009 | 11:21 PM
suay's Avatar
Work hard Drive Hard!
How about chris from esmeril!? He's pushing 500HP so..... aren't his numbers the "Top numbers"? no offense charles.
Old Aug 10, 2009 | 11:38 PM
Nope
^Because he is yet to post a dyno showing that much power
Old Aug 11, 2009 | 12:27 AM
Brettus's Avatar
Boosted Kiwi
For the record;
can't find his dyno . I'll put tajs back up and use yours for a porting only dyno
Old Aug 11, 2009 | 01:15 AM
09Factor's Avatar
Original Turbo 'd Auto !!
Too bad we didn't know the fuel pump failed when we did this.
Wonder what the new setup will do..........
Old Aug 11, 2009 | 03:59 AM
Talic's Avatar
heres DNAMotorSport @10psi
in referance to my Procharged Version
owners.procharger.com/supercharged/67
http://www.forced-inductions.com/RX8.html
Old Aug 11, 2009 | 07:23 AM
Kane's Avatar
I can't find Punisher_RX8's either..... it was in the old dyno thread.
His car did pretty well.
Old Aug 11, 2009 | 09:36 AM
ChrisRX8PR's Avatar
13B-RE
Hmmm...Good thread....
I will have a new dyno within the next couple weeks.
I will make sure and post it here...
In the meanwhile here is our old dyno....this was with an out of the box kit and our ignition upgrade....I later found that the boost controller was not set up properly and it was falling on the top end down to the wastegate spring pressure boost of 11-12psi. That is the reason the curve falls towards the top end instead of keeping it up like the one at the bottom which was at only 13psi but it only fell to 12(boost controller was also set up improperly but wastegate pressure was close to desired pressure so it just dipped a bit).
Chris
Old Aug 11, 2009 | 02:54 PM
Brettus's Avatar
Boosted Kiwi
thanks for the dyno . I am trying to keep it limited to members of this site rather than promotional material . Do you have your own dyno ?
Old Aug 11, 2009 | 02:56 PM
Brettus's Avatar
Boosted Kiwi
Chris
thanks Chris . Your dyno is already up there - i took one that someone converted to rpm . Can't wait to see your next dyno
Old Aug 11, 2009 | 03:00 PM
bse50's Avatar
#50
Chris
Chris, i don't know how much your new set-up would fit in here since your engine is no longer running on stock internals\ports\manifolds! A comparison could be interesting though!
Old Aug 11, 2009 | 03:04 PM
Brettus's Avatar
Boosted Kiwi
As long as it is still a Renesis I think it is relevant . The details of what it took to do will be essential however as it could mislead people otherwise .
Old Aug 11, 2009 | 03:05 PM
Kane's Avatar
Can you overlay them Brettus?
Even just a simple excel file would be interesting to see.
Old Aug 11, 2009 | 03:08 PM
bse50's Avatar
#50
Yeah, i just thought that a bridge ported renny was no longer a renny
We will get to see how those new ports work then! I just thought that it was ok to point that issue out before falling again in the "but you" spiral that killed the other thread.
Old Aug 11, 2009 | 03:17 PM
Brettus's Avatar
Boosted Kiwi
Will probably do that at some stage but it wont be as elaborate as the last thread as my xl skillz are pretty basic.
